1 Reply Latest reply on Jan 19, 2011 9:28 AM by Steve Grisetti
    PE9 report when crashing on Mac
    Katia Enbuske
      Hi folks!
      An addition to the previous: this is the report PE prints when crashing. Can any computer wizard make sense out of this?
      Process:         Adobe Premiere Elements [1670]
      Path:            /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/Adobe Premiere Elements
      Identifier:      com.adobe.Adobe Premiere Elements.framework
      Version:         N224.08092010.240488 (9.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [89]
      Date/Time:       2011-01-19 11:04:40.118 -0500
      OS Version:      Mac OS X 10.6.6 (10J567)
      Report Version:  6
      Interval Since Last Report:          118661 sec
      Crashes Since Last Report:           9
      Per-App Interval Since Last Report:  70209 sec
      Per-App Crashes Since Last Report:   9
      Anonymous UUID:                      953B491E-1056-4052-AFB8-9B3AD5C31200
      Exception Type:  EXC_CRASH (SIGABRT)
      Exception Codes: 0x0000000000000000, 0x0000000000000000
      Crashed Thread:  39  Dispatch queue: com.apple.root.default-priority
      Application Specific Information:
      Assertion failed: (manager != 0), function operator new, file xercesc/util/XMemory.cpp, line 63.
      Thread 0:  Dispatch queue: com.apple.main-thread
      0   libSystem.B.dylib             0x920c00fa mach_msg_trap + 10
      1   libSystem.B.dylib             0x920c0867 mach_msg + 68
      2   com.apple.CoreFoundation      0x9967d37f __CFRunLoopRun + 2079
      3   com.apple.CoreFoundation      0x9967c464 CFRunLoopRunSpecific + 452
      4   com.apple.CoreFoundation      0x9967c291 CFRunLoopRunInMode + 97
      5   com.apple.HIToolbox           0x935b0004 RunCurrentEventLoopInMode + 392
      6   com.apple.HIToolbox           0x935afdbb ReceiveNextEventCommon + 354
      7   com.apple.HIToolbox           0x935afc40 BlockUntilNextEventMatchingListInMode + 81
      8   com.apple.AppKit              0x9509978d _DPSNextEvent + 847
      9   com.apple.AppKit              0x95098fce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
      10  com.adobe.dvaui.framework     0x005a82e6 dvaui::ui::OS_Dialog::WaitForNextEvent() + 182
      11  com.adobe.dvaui.framework     0x005a9c97 dvaui::ui::OS_Dialog::ModalLoop() + 71
      12  com.adobe.dvaui.framework     0x005a9a24 dvaui::ui::OS_Dialog::RunModal() + 196
      13  com.adobe.dvaeve.framework    0x00d004be dvaeve::UI_EveManager::DisplayView(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::istream&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*) + 1838
      14  com.adobe.dvaeve.framework    0x00cfc4f2 dvaeve::UI_Eve::ParseEveScript(std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >&) + 1170
      15  ...adobe.UIFramework.framework 0x010fd2af UIF::DialogBaseImpl::DoModal() + 111
      16  ...adobe.premiere-elements.HSL 0x09482678 HSL::RenderProgressDialog::DoRenderProgressDialog(ASL::InterfaceRef<ASL::IBatchOperation, ASL::IBatchOperation>) + 328
      17  ...adobe.premiere-elements.HSL 0x09482b25 HSL::RenderProgressDlg::DoRenderProgressDlg(ASL::InterfaceRef<ASL::IBatchOperation, ASL::IBatchOperation>) + 37
      18  ...adobe.premiere-elements.HSL 0x094b7a2c HSL::SequencePreviewRenderer::SyncRenderPreviews(ASL::InterfaceRef<BE::ISequence, BE::ISequence>, dvamediatypes::TickTime, dvamediatypes::TickTime) + 220
      19  ...adobe.premiere-elements.HSL 0x094ad678 HSL::SequencePlayer::GenerateSourceFiles(dvamediatypes::TickTime const&, dvamediatypes::TickTime const&, ASL::InterfaceRef<BE::IAudioRenderable, BE::IAudioRenderable>) + 120
      20  ...adobe.premiere-elements.HSL 0x094ae09c HSL::SequencePlayer::RenderSources(bool) + 460
      21  ...adobe.premiere-elements.HSL 0x094a9fb9 HSL::SequencePlayer::RenderSources() + 25
      22  ...adobe.premiere-elements.HSL 0x09412d01 HSL::Player::HandlePlayCommand(UIF::Command const&, dvamediatypes::TickTime const&) + 273
      23  ...be.HandlerMonitor.framework 0x0abd95f2 HandlerMonitor::ElementsProgramMonitorView::OnSequencePreview(UIF::Command const&) + 370
      24  ...be.HandlerMonitor.framework 0x0abe3b8f HandlerMonitor::ElementsProgramMonitorView::ObeyCommand(UIF::Command const&) + 1199
      25  ...adobe.UIFramework.framework 0x010a1e7c UIF::Commander::PostCommand(int) + 60
      26  com.adobe.Frontend.framework  0x060e8395 HandleMenuCommand(NSMenuItem*) + 117
      27  com.adobe.dvacore.framework   0x00075cf9 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 41
      28  com.adobe.dvacore.framework   0x00076088 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24
      29  com.adobe.Frontend.framework  0x0605e199 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 41
      30  com.adobe.dvacore.framework   0x00074c2f void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 159
      31  com.adobe.dvacore.framework   0x00076bac void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 92
      32  com.adobe.Frontend.framework  0x060e96d0 -[PremiereCocoaMacApplication handleMenuCommand:] + 144
      33  com.apple.AppKit              0x950d7c46 -[NSApplication sendAction:to:from:] + 112
      34  com.apple.AppKit              0x950d7af9 -[NSMenuItem _corePerformAction] + 435
      35  com.apple.AppKit              0x950d77eb -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 174
      36  com.apple.AppKit              0x950d76da -[NSMenu performActionForItemAtIndex:] + 65
      37  com.adobe.dvaui.framework     0x005e160a -[DVAMacMenu performActionForItemAtIndex:] + 58
      38  com.apple.AppKit              0x950d768d -[NSMenu _internalPerformActionForItemAtIndex:] + 50
      39  com.apple.AppKit              0x950d75f3 -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 97
      40  com.apple.AppKit              0x950d7537 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 336
      41  com.apple.AppKit              0x950cbc61 NSSLMMenuEventHandler + 404
      42  com.apple.HIToolbox           0x93582ecf DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      43  com.apple.HIToolbox           0x93582196 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      44  com.apple.HIToolbox           0x935a4a07 SendEventToEventTarget + 52
      45  com.apple.HIToolbox           0x935d0fd3 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
      46  com.apple.HIToolbox           0x935f5cc0 SendMenuCommandWithContextAndModifiers + 66
      47  com.apple.HIToolbox           0x935f5c75 SendMenuItemSelectedEvent + 121
      48  com.apple.HIToolbox           0x935f5b80 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
      49  com.apple.HIToolbox           0x935c534a MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
      50  com.apple.HIToolbox           0x935c4abc _HandleMenuSelection2 + 465
      51  com.apple.HIToolbox           0x935c48da _HandleMenuSelection + 53
      52  com.apple.AppKit              0x950c51a2 _NSHandleCarbonMenuEvent + 285
      53  com.apple.AppKit              0x95099d3e _DPSNextEvent + 2304
      54  com.apple.AppKit              0x95098fce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
      55  com.apple.AppKit              0x9505b247 -[NSApplication run] + 821
      56  com.adobe.Frontend.framework  0x060e8f66 FE::MacApplication::RunSelf(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 214
      57  com.adobe.Frontend.framework  0x06049a27 FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 1079
      58  com.adobe.Frontend.framework  0x060ec28a AppMain + 298
      59  com.adobe.Startup.framework   0x062cfd30 (anonymous namespace)::LaunchFrontendFramework(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 176
      60  ...Premiere Elements.framework 0x000038c6 (anonymous namespace)::CallStartupFramework(int, char const* const*) + 246
      61  ...Premiere Elements.framework 0x00003e85 main + 229
      62  ...Premiere Elements.framework 0x00003736 start + 54
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x920e6982 kevent + 10
      1   libSystem.B.dylib             0x920e709c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib             0x920e6559 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib             0x920e62fe _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib             0x920e5d81 _pthread_wqthread + 390
      5   libSystem.B.dylib             0x920e5bc6 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib             0x920ee0a6 __semwait_signal + 10
      1   libSystem.B.dylib             0x920edd62 _pthread_cond_wait + 1191
      2   libSystem.B.dylib             0x920ef9f8 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore 0x913d251e TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore 0x913bdea5 TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore 0x913b9873 MPWaitOnQueue + 250
      6   com.adobe.dvacore.framework   0x000ee3da dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      7   com.adobe.dvacore.framework   0x000ea26a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      8   com.adobe.dvacore.framework   0x00076c79 boost::function0<void>::operator()() const + 41
      9   com.adobe.dvacore.framework   0x000e6cdd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      10  com.adobe.dvacore.framework   0x000e7bd0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      11  ...obe.boost_threads.framework 0x0002f6ed thread_proxy + 141
      12  libSystem.B.dylib             0x920ed85d _pthread_start + 345
      13  libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 3:
      0   libSystem.B.dylib             0x920c0142 semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib             0x920edcfc _pthread_cond_wait + 1089
      2   libSystem.B.dylib             0x9213646f pthread_cond_wait + 48
      3   com.adobe.amt.services        0x145234ba C_AMTUISwitchSuppressUpdates + 16864
      4   com.adobe.amt.services        0x1451c49c C_EULA_SetState + 2166
      5   com.adobe.amt.services        0x14523520 C_AMTUISwitchSuppressUpdates + 16966
      6   libSystem.B.dylib             0x920ed85d _pthread_start + 345
      7   libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 4:
      6   ...e.Frameworks.ASL.Foundation 0x014e364e ASL::(anonymous namespace)::TaskProc(void*) + 94
      7   ...ple.CoreServices.CarbonCore 0x9139d85a PrivateMPEntryPoint + 68
      8   libSystem.B.dylib             0x920ed85d _pthread_start + 345
      9   libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 5:
      1   libSystem.B.dylib             0x92119ee5 nanosleep$UNIX2003 + 188
      2   ScriptLayer                   0x0be9e17b ScObjects::Thread::sleep(unsigned int) + 59
      3   ScriptLayer                   0x0be86e13 ScObjects::BridgeTalkThread::run() + 163
      4   ScriptLayer                   0x0be9e288 ScObjects::Thread::go(void*) + 168
      5   libSystem.B.dylib             0x920ed85d _pthread_start + 345
      6   libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 6:
      6   AdobeACE                      0x049b26f1 0x4978000 + 239345
      7   AdobeACE                      0x049b20ed 0x4978000 + 237805
      8   ...ple.CoreServices.CarbonCore 0x9139d85a PrivateMPEntryPoint + 68
      9   libSystem.B.dylib             0x920ed85d _pthread_start + 345
      10  libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      Thread 12:
      Thread 13:
      Thread 14:
      Thread 15:
      Thread 16:
      1   ...dobe.dvatransport.framework 0x0167e1e3 boost::asio::detail::kqueue_reactor<false>::run(bool) + 531
      2   ...dobe.dvatransport.framework 0x0167f409 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 489
      3   ...dobe.dvatransport.framework 0x0165b33e SkyConnectionEnv::MainLoop() + 94
      4   ...obe.boost_threads.framework 0x0002f6ed thread_proxy + 141
      Thread 17:
      3   ...dobe.dvatransport.framework 0x0167f6c2 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 1186
      4   ...dobe.dvatransport.framework 0x01680133 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 51
      5   ...dobe.dvatransport.framework 0x01664fa7 asio_detail_posix_thread_function + 23
      Thread 18:
      5   com.apple.audio.CoreAudio     0x9187796e HALRunLoop::OwnThread(void*) + 162
      6   com.apple.audio.CoreAudio     0x918634a4 CAPThread::Entry(CAPThread*) + 140
      7   libSystem.B.dylib             0x920ed85d _pthread_start + 345
      8   libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 19:
      0   libSystem.B.dylib             0x920c015a semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x920edce5 _pthread_cond_wait + 1066
      2   libSystem.B.dylib             0x9211cac8 pthread_cond_timedwait_relative_np + 47
      3   ...ple.CoreServices.CarbonCore 0x913bdecd TSWaitOnConditionTimedRelative + 242
      4   ...ple.CoreServices.CarbonCore 0x913b9873 MPWaitOnQueue + 250
      5   com.adobe.dvacore.framework   0x000ee3da dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      6   com.adobe.dvacore.framework   0x000ea26a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      7   com.adobe.dvacore.framework   0x00076c79 boost::function0<void>::operator()() const + 41
      8   com.adobe.dvacore.framework   0x000e6cdd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      9   com.adobe.dvacore.framework   0x000e7bd0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      10  ...obe.boost_threads.framework 0x0002f6ed thread_proxy + 141
      11  libSystem.B.dylib             0x920ed85d _pthread_start + 345
      12  libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 20:
      Thread 21:
      Thread 22:
      Thread 23:
      Thread 24:
      6   com.adobe.CameraRaw           0x33897158 0x33696000 + 2101592
      7   com.adobe.CameraRaw           0x33896a56 0x33696000 + 2099798
      Thread 25:
      Thread 26:
      Thread 27:
      3   com.adobe.CameraRaw           0x336dbdca 0x33696000 + 286154
      4   com.adobe.CameraRaw           0x33a01cd4 EntryFM + 894068
      5   com.adobe.CameraRaw           0x3379c606 0x33696000 + 1074694
      Thread 28:
      4   com.apple.CoreFoundation      0x996823a4 CFRunLoopRun + 84
      5   com.adobe.dvacore.framework   0x000d9867 dvacore::threads::RunPlatformEventLoop() + 103
      6   com.adobe.dvacore.framework   0x000df24a dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain(dvacore::threads::SyncPoint&) + 154
      7   com.adobe.dvacore.framework   0x000def27 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvacore::threads::(anonymous namespace)::EventLoopExecutor, dvacore::threads::SyncPoint&>, boost::_bi::list2<boost::_bi::value<dvacore::threads::(anonymous namespace)::EventLoopExecutor*>, boost::reference_wrapper<dvacore::threads::SyncPoint> > >, void>::invoke(boost::detail::function::function_buffer&) + 55
      Thread 29:
      0   libSystem.B.dylib             0x920cb442 open$UNIX2003 + 10
      1   com.adobe.Frontend.framework  0x06098646 FE::(anonymous namespace)::waitformsg(void*) + 86
      Thread 30:
      Thread 31:
      2   ...ple.CoreServices.CarbonCore 0x91465ac8 TS_exception_listener_thread + 160
      3   libSystem.B.dylib             0x920ed85d _pthread_start + 345
      4   libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 32:  com.apple.CFSocket.private
      0   libSystem.B.dylib             0x920df0c6 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation      0x996bcc83 __CFSocketManager + 1091
      Thread 33:
      Thread 34:
      Thread 35:
      3   com.apple.audio.CoreAudio     0x918633c7 CAGuard::WaitFor(unsigned long long) + 219
      4   com.apple.audio.CoreAudio     0x918663f9 CAGuard::WaitUntil(unsigned long long) + 289
      5   com.apple.audio.CoreAudio     0x91863cf6 HP_IOThread::WorkLoop() + 1892
      6   com.apple.audio.CoreAudio     0x9186358d HP_IOThread::ThreadEntry(HP_IOThread*) + 17
      7   com.apple.audio.CoreAudio     0x918634a4 CAPThread::Entry(CAPThread*) + 140
      Thread 36:
      5   com.apple.AVCVideoServices    0x2fd13afa AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 210
      Thread 37:
      0   libSystem.B.dylib             0x920e5a12 __workq_kernreturn + 10
      1   libSystem.B.dylib             0x920e5fa8 _pthread_wqthread + 941
      2   libSystem.B.dylib             0x920e5bc6 start_wqthread + 30
      Thread 38:  Dispatch queue: com.apple.root.default-priority
      0   ...re.Frameworks.ImageRenderer 0x0353b21e IR_CopyMemory. + 129
      1   ...re.Frameworks.ImageRenderer 0x0353e674 (anonymous namespace)::Copy8u(void const*, void*, int) + 34
      2   ...re.Frameworks.ImageRenderer 0x0354804b IR::LineConverter::Convert(void const*, void*, int) const + 41
      3   ...re.Frameworks.ImageRenderer 0x03477efe Motion::RenderRows(void const*, int, IR_PixelFormat, RECT const&, IR_POINTf, int, int, IR_ApplyMotionToField) + 736
      Thread 39 Crashed:  Dispatch queue: com.apple.root.default-priority
      0   libSystem.B.dylib             0x9212d4fe __semwait_signal_nocancel + 10
      1   libSystem.B.dylib             0x9212d3e2 nanosleep$NOCANCEL$UNIX2003 + 166
      2   libSystem.B.dylib             0x921a82aa usleep$NOCANCEL$UNIX2003 + 61
      3   libSystem.B.dylib             0x921c99c8 abort + 105
      4   libSystem.B.dylib             0x921b64fc __pthread_markcancel + 0
      5   libxerces-c-3.0.dylib         0x063b4fb5 xercesc_3_0::XMemory::operator new(unsigned long, xercesc_3_0::MemoryManager*) + 69
      6   libxerces-c-3.0.dylib         0x064bd866 xercesc_3_0::XMLReaderFactory::createXMLReader(xercesc_3_0::MemoryManager*, xercesc_3_0::XMLGrammarPool*) + 26
      7   ...obe.TitlerCreator.framework 0x0787c300 CG::TitleFromXML(unsigned long, void const*) + 144
      8   ...obe.TitlerCreator.framework 0x0787cc85 CG::CG_ReconstructTitle(CG::Title**, CG::Stream::Base*, bool*) + 533
      9   ...obe.TitlerCreator.framework 0x078b358c GXU::TitleFromBinary(MF::BinaryData const&) + 92
      10  ...obe.TitlerCreator.framework 0x07938e1a TitlerML::TitlerSource::SelectBestFrameFormat(dvamediatypes::TickTime const&, BE::FrameFormat&, MF::BinaryData const&) const + 26
      11  ...re.Frameworks.VideoRenderer 0x03aa0e26 ML::RenderableVideoSource::GetPrefetchesForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) + 326
      12  ...re.Frameworks.VideoRenderer 0x03a95790 ML::RenderableSourceScaler::GetPrefetchesForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) + 112
      13  ...re.Frameworks.VideoRenderer 0x03a70bb9 ML::MediaNodeProducer::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 809
      14  ...re.Frameworks.VideoRenderer 0x03a61bde ML::RenderableNodeMediaImpl::InternalGetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 190
      15  ...re.Frameworks.VideoRenderer 0x03a38136 ML::RenderableNodeCommonImpl::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 422
      16  ...re.Frameworks.VideoRenderer 0x03a4cb3c ML::RenderableNodeClipImpl::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 1244
      17  ...re.Frameworks.VideoRenderer 0x03a3839f ML::RenderableNodeCommonImpl::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 1039
      18  ...re.Frameworks.VideoRenderer 0x03a58c0f ML::RenderableNodeCompositorImpl::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 1263
      19  ...re.Frameworks.VideoRenderer 0x03a0d3e7 ML::GetPrefetchesForFrameFromCutlist(ASL::InterfaceRef<MF::IRenderableCutlist, MF::IRenderableCutlist> const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) + 343
      20  ...re.Frameworks.VideoRenderer 0x03a43b97 ML::RenderableCutlistSource::GetPrefetchesForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) + 135
      21  ...re.Frameworks.VideoRenderer 0x03a95790 ML::RenderableSourceScaler::GetPrefetchesForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) + 112
      22  ...re.Frameworks.VideoRenderer 0x03a9ebf5 ML::RenderableSourceTimeMix::GetPrefetchesForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) + 293
      23  ...re.Frameworks.VideoRenderer 0x03a70bb9 ML::MediaNodeProducer::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 809
      24  ...re.Frameworks.VideoRenderer 0x03a61bde ML::RenderableNodeMediaImpl::InternalGetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 190
      25  ...re.Frameworks.VideoRenderer 0x03a38136 ML::RenderableNodeCommonImpl::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 422
      26  ...re.Frameworks.VideoRenderer 0x03a4cb3c ML::RenderableNodeClipImpl::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 1244
      27  ...re.Frameworks.VideoRenderer 0x03a3839f ML::RenderableNodeCommonImpl::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 1039
      28  ...re.Frameworks.VideoRenderer 0x03a58c0f ML::RenderableNodeCompositorImpl::GetPrefetchesForFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) const + 1263
      29  ...re.Frameworks.VideoRenderer 0x03a0d3e7 ML::GetPrefetchesForFrameFromCutlist(ASL::InterfaceRef<MF::IRenderableCutlist, MF::IRenderableCutlist> const&, ML::CutlistRenderParams const&, std::vector<ASL::InterfaceRef<ML::IRenderableNodePrefetch, ML::IRenderableNodePrefetch>, dvacore::utility::SmallBlockAllocator::STLAllocator<ASL::InterfaceRef<ML::IRenderableNode Prefetch, ML::IRenderableNodePrefetch> > >&) + 343
      30  ...re.Frameworks.VideoRenderer 0x03ab9d23 ML::RenderFrameRequest::InitiatePrefetches() const + 915
      31  ...re.Frameworks.VideoRenderer 0x03aad822 ML::RenderFrameQueue::ProcessPendingRequests(bool) + 1362
      32  ...re.Frameworks.VideoRenderer 0x03ab2bfc boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, ML::RenderFrameQueue, bool>, boost::_bi::list2<boost::_bi::value<ASL::InterfaceRef<ML::RenderFrameQueue, ASL::ASLUnknown> >, boost::_bi::value<bool> > >, void>::invoke(boost::detail::function::function_buffer&) + 76
      33  com.adobe.dvacore.framework   0x000d8a89 dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function<void ()()> const&) + 41
      34  com.adobe.dvacore.framework   0x000d8f8e dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr<dvacore::threads::(anonymo us namespace)::SubExecutorImpl> const&) + 78
      35  com.adobe.dvacore.framework   0x000d29e4 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvacore::threads::(anonymous namespace)::SubExecutorImpl, boost::shared_ptr<dvacore::threads::(anonymous namespace)::SubExecutorImpl> const&>, boost::_bi::list2<boost::_bi::value<dvacore::threads::(anonymous namespace)::SubExecutorImpl*>, boost::_bi::value<boost::shared_ptr<dvacore::threads::(anonymous namespace)::SubExecutorImpl> > > >, void>::invoke(boost::detail::function::function_buffer&) + 52
      36  com.adobe.dvacore.framework   0x00076c79 boost::function0<void>::operator()() const + 41
      37  com.adobe.dvacore.framework   0x000f0927 dvacore::threads::(anonymous namespace)::WrapGCDAsyncCall(void*) + 23
      38  libSystem.B.dylib             0x920e62f2 _dispatch_worker_thread2 + 228
      39  libSystem.B.dylib             0x920e5d81 _pthread_wqthread + 390
      40  libSystem.B.dylib             0x920e5bc6 start_wqthread + 30
      Thread 40:
      3   ...diaCore.ExporterMPEGPreview 0x522ba12f ASL::WaitableGate::Wait(int) + 927
      4   ...diaCore.ExporterMPEGPreview 0x522b68fa ExporterMPEGPreview::ExporterMPEGPreview::DoExport() + 7130
      5   ...diaCore.ExporterMPEGPreview 0x522bac06 PrExporterModule<ExporterMPEGPreview::ExporterMPEGPreview>::ExportEntry(int, exportStdParms*, void*, void*) + 966
      6   ...diaCore.ExporterMPEGPreview 0x522ba5a4 xSDKExport + 68
      7   ...ore.Frameworks.ExporterHost 0x042d2089 ML::ExporterPluginModule::CallExportModule(int, void*, void*) + 121
      8   ...ore.Frameworks.ExporterHost 0x04241600 ML::Exporter::MovieExport(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::TickTime const&, dvamediatypes::TickTime const&) + 848
      9   ...ore.Frameworks.ExporterHost 0x04242bd9 ML::Exporter::BeginThreadExport() + 1433
      10  ...ore.Frameworks.ExporterHost 0x04245c29 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf0<void, ML::Exporter>, boost::_bi::list1<boost::_bi::value<ASL::InterfaceRef<ML::Exporter, ML::IExporter> > > >, void>::invoke(boost::detail::function::function_buffer&) + 57
      11  com.adobe.dvacore.framework   0x00076c79 boost::function0<void>::operator()() const + 41
      12  com.adobe.dvacore.framework   0x000ee46a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
      13  com.adobe.dvacore.framework   0x000ea26a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      14  com.adobe.dvacore.framework   0x00076c79 boost::function0<void>::operator()() const + 41
      15  com.adobe.dvacore.framework   0x000e6cdd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      16  com.adobe.dvacore.framework   0x000e7bd0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      17  ...obe.boost_threads.framework 0x0002f6ed thread_proxy + 141
      18  libSystem.B.dylib             0x920ed85d _pthread_start + 345
      19  libSystem.B.dylib             0x920ed6e2 thread_start + 34
      Thread 41:  Dispatch queue: com.apple.root.default-priority
      Thread 42:  Dispatch queue: com.apple.root.default-priority
      Thread 43:
      Thread 44:
      3   com.mainconcept.mc_bc_dec_avc 0x4051daa6 h264in_Video_GetAPIExt + 602364
      4   com.mainconcept.mc_bc_dec_avc 0x40496d9c h264in_Video_GetAPIExt + 50162
      Thread 45:
      Thread 46:
      Thread 47:
      Thread 48:
      Thread 49:
      0   libSystem.B.dylib             0x920e5ba8 start_wqthread + 0
      Thread 50:
      0   ...mainconcept.mc_enc_mp2v.004 0x57520904 0x57518000 + 35076
      1   ...mainconcept.mc_enc_mp2v.004 0x57558482 mpegOutVideoDefaults + 134266
      2   ...mainconcept.mc_enc_mp2v.004 0x575460fb mpegOutVideoDefaults + 59635
      3   ...mainconcept.mc_enc_mp2v.004 0x57546a83 mpegOutVideoDefaults + 62075
      4   ...mainconcept.mc_enc_mp2v.004 0x57546d4c mpegOutVideoDefaults + 62788
      5   ...mainconcept.mc_enc_mp2v.004 0x5758462f mpegOutVideoDefaults + 314919
      6   ...mainconcept.mc_enc_mp2v.004 0x57584730 mpegOutVideoDefaults + 315176
      Thread 51:
      2   libSystem.B.dylib             0x9213667c pthread_cond_timedwait + 47
      3   com.mainconcept.mc_mux_mp2    0x574640a8 mpegOutMP2MuxGetAPIExt + 112782
      4   com.mainconcept.mc_mux_mp2    0x57445b5d mpegOutMP2MuxChkSettings + 49119
      Thread 52:
      3   ...mainconcept.mc_enc_mp2v.004 0x575937c0 mpegOutVideoDefaults + 376760
      4   ...mainconcept.mc_enc_mp2v.004 0x5754b79b mpegOutVideoDefaults + 81811
      Thread 53:
      Thread 54:
      Thread 55:
      Thread 56:
      4   ...mainconcept.mc_enc_mp2v.004 0x5756fd2d mpegOutVideoDefaults + 230693
      Thread 57:
      Thread 58:
      Thread 59:
      Thread 39 crashed with X86 Thread State (32-bit):
        eax: 0x0000003c  ebx: 0x9212d349  ecx: 0xb0e3412c  edx: 0x9212d4fe
        edi: 0x0000003f  esi: 0xb0e34188  ebp: 0xb0e34168  esp: 0xb0e3412c
         ss: 0x0000001f  efl: 0x00000247  eip: 0x9212d4fe   cs: 0x00000007
         ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
        cr2: 0x064d3ab0
      Binary Images:
          0x1000 -     0x3ff3 +com.adobe.Adobe Premiere Elements.framework N224.08092010.240488 (9.0) <CB8EC92E-5E07-E764-529D-21859A900BF3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/Adobe Premiere Elements
          0xa000 -     0xeffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReport er
         0x15000 -    0x1bfef +com.adobe.boost_date_time.framework boost_date_time version 8.0.0 (8.0.0.0) <16B587FC-3B88-3CAC-EA49-49C8530A2284> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
         0x2d000 -    0x34ff2 +com.adobe.boost_threads.framework boost_threads version 8.0.0 (8.0.0.0) <52458199-9BBE-EA78-70CE-C078622684DE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x44000 -   0x1c1fef +com.adobe.dvacore.framework dvacore version 8.0.0 (8.0.0.0) <DFED1A19-6BB6-A397-64DB-0D803AE2A846> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x343000 -   0x65dff7 +com.adobe.dvaui.framework dvaui version 8.0.0 (8.0.0.0) <84648108-9211-3A28-8B3F-A37CD997DFDF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
        0x9c3000 -   0xa70fff +com.adobe.dvaworkspace.framework dvaworkspace version 8.0.0 (8.0.0.0) <8F322FAB-F0B4-89C5-5138-F9AD91704D3A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
        0xb43000 -   0xbe8fff +com.adobe.exo.framework exo version 8.0.0 (8.0.0.0) <94AB2A24-AFD5-25DB-EF10-260F1883A98B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/exo.framework/Versions/A/exo
        0xcde000 -   0xdc2fef +com.adobe.dvaeve.framework dvaeve version 8.0.0 (8.0.0.0) <B9C18986-07F5-D9F7-0A6B-1CAA9467E65A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
        0xec5000 -   0xf0efff +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 8.0.0 (8.0.0.0) <0806FC8B-9321-3C1E-4B94-E505FF1BC157> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
        0xf2f000 -   0xf87ff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
        0xf96000 -  0x1022fef +AdobeXMPFiles ??? (???) <A72BD678-CAD0-0C2A-0989-11E87B154AB5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
      0x1059000 -  0x124efef +com.adobe.UIFramework.framework ??? (1.0) <3CFEED6B-BFA2-2EEC-E57B-E62C1AD5E2C7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
      0x1458000 -  0x1479ff7 +com.adobe.dvamediatypes.framework dvamediatypes version 8.0.0 (8.0.0.0) <0FE20B37-7CEE-8FDE-573D-3EA193C705CB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
      0x149a000 -  0x149affb +PRM ??? (???) <383A4352-5FE9-0D73-8E23-06A12D83E7B4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
      0x14a1000 -  0x150bff1 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <72B48D53-00DF-8C82-C7AA-01A9C282EAE0> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
      0x15c9000 -  0x15defff +ASLMessaging ??? (???) <1425780D-FF58-9F45-8357-86E2344A8F7F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
      0x15fd000 -  0x15fefff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <ECBE5E96-AC61-6338-B7D8-80222B691F7E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
      0x1605000 -  0x1615ffd +ASLUnitTesting ??? (???) <1701C314-AEE9-7836-C783-3E8C97E3813E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
      0x162f000 -  0x1630ffb +com.adobe.boost_system.framework boost_system version 8.0.0 (8.0.0.0) <47EE4594-75B3-D887-7E1D-C47921C41436> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
      0x1638000 -  0x16a8fff +com.adobe.dvatransport.framework dvatransport version 8.0.0 (8.0.0.0) <D309BA02-0882-82AE-3B18-171E24E6CE8E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
      0x1728000 -  0x1762ffb +com.adobe.dvamarshal.framework dvamarshal version 8.0.0 (8.0.0.0) <A478730D-8D42-AA39-A941-E9D72DDB9CE5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
      0x17d8000 -  0x199dfe7 +com.adobe.dynamiclink.framework dynamiclink version 8.0.0 (8.0.0.0) <5167C3EA-0399-2029-DA70-9945BB53D9C2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
      0x1ac1000 -  0x1af5fe7 +com.adobe.MediaFoundation ??? (1.0) <60AC246A-218B-87F9-C52F-7C4AD0072191> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
      0x1b37000 -  0x1ba9ff7 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <E042D5B6-B5AD-8CCB-6D91-9F29D2DBC04A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
      0x1c3a000 -  0x2762fe7 +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <54EA6B9C-A74A-9FA5-8CAB-97F540A84D4F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
      0x3402000 -  0x358effd +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <089DE64B-D83A-2FCE-23C6-C96B0B1B1C04> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
      0x367b000 -  0x36b3ff3 +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <F8B76FB9-D7BA-67A9-6512-E55CC33BDA17> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
      0x3700000 -  0x374bff7 +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <B4B640A4-7579-758A-F8FD-F7E0DE667776> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
      0x3794000 -  0x37cdfff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <4771E7E4-21D9-BE94-6392-4D5A96C11DD7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
      0x380c000 -  0x3845fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <2BC72003-AF23-F10E-A351-12288F540EC1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
      0x3895000 -  0x38dafef +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <71378A35-591C-30DC-4612-C956B07B07B0> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
      0x3922000 -  0x3924ff3 +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <01A20771-3B4B-5B32-B063-CE3B49B1FDC2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
      0x392b000 -  0x3944ff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <5C442959-81F1-F837-5314-4B741851585D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
      0x396b000 -  0x399efef +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <2BE91FC6-0427-17B0-A14C-EEE21058AF7D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
      0x39fd000 -  0x3b16fff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <A41492DB-AE74-8CCB-9682-63FBAEDF51B9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
      0x3c71000 -  0x3e0afff +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <D5DC90DB-0C0B-C816-7220-E1614B45727A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
      0x3fb7000 -  0x4083fff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <309D712C-3663-F041-D848-A7C6D38EAECE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
      0x4139000 -  0x41d3ff3 +com.adobe.MediaCore.Frameworks.TimeWarpFilter 1.0 (1.0) <E88D632C-8F60-BE3B-1905-4D3C27920E6C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TimeWarpFilter.framework/Versions/A/TimeWarpFilter
      0x4238000 -  0x42fcfff +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <6F6A034B-CC8D-718A-2657-F8EB2A2DDF03> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
      0x440c000 -  0x4481fff +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <794A5DD8-FE64-6261-D575-A810CE87E711> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
      0x4514000 -  0x4583ff7 +com.adobe.MediaCore.Frameworks.RecorderHost 1.0 (1.0) <CB8C425E-AD82-BD69-FC27-3DF2FF3E7E5F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
      0x45fc000 -  0x4608ff7 +com.adobe.MediaCore.Frameworks.ProjectConverterHost 1.0 (1.0) <079087AB-3AAD-C1EC-72DA-08118629F791> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConvert erHost
      0x461b000 -  0x4628ff3 +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <213D4CF3-E724-A46C-B63B-0FEFC9F7526D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
      0x463c000 -  0x4653fff +com.adobe.AMEAppFoundation.framework ??? (1.0) <E0CCB9E9-76EA-B8AD-FC20-472E14BCB1DB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
      0x4674000 -  0x4695ffd +com.adobe.PostEncodeHost.framework ??? (1.0) <37AA1110-24C5-AC18-1909-26E1B0978560> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
      0x46c1000 -  0x46dcfff +AdobeBIB ??? (???) <6E3DC6A9-066C-B736-6465-7F91D18860FB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x46e6000 -  0x4773ff7 +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7471) <491BB523-30A6-E426-1C5D-799578012E33> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
      0x47b8000 -  0x4850fff +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7471) <ADBFBE50-AFEC-FFFE-B1C2-08EA2B3BE434> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
      0x48af000 -  0x4902ff2 +com.adobe.MediaCore.Frameworks.BravoInitializer 1.0 (1.0) <633C71E4-B4D6-40D9-3DFE-F9C508149808> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
      0x4978000 -  0x4a8cfff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x4aaf000 -  0x4dbeff7 +AdobeAGM ??? (???) <202752CE-8950-5114-DD17-D5B087297A1F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x4e74000 -  0x5166ff7 +AdobeCoolType ??? (???) <AEC9EB8F-2122-1708-3207-2A8BE3308FFA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x51ee000 -  0x52b2fff +AMEWrapper ??? (???) <D78F3EA9-0CBE-0A29-B22C-865792530CE1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
      0x5367000 -  0x5479fff +com.adobe.EncoderHost.framework ??? (1.0) <D19AC057-A2B1-D223-F601-9E816AECC162> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
      0x5571000 -  0x5bb5fff +com.adobe.Mezzanine.framework ??? (1.0) <B44A1811-D89D-0CD9-AAF5-7BE707AFC401> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
      0x6041000 -  0x6180ffb +com.adobe.Frontend.framework ??? (1.0) <147702DE-20F1-47F6-8741-F698C8CCC5E2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
      0x62cb000 -  0x62f8fef +com.adobe.Startup.framework ??? (1.0) <FC6A40F0-A58B-38DC-B905-5791B340CF9F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
      0x6316000 -  0x6356ff7  com.apple.vmutils 4.2 (106) <7AAF9FDA-AC1E-09FD-889E-68FFB5F94BA8> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0x636f000 -  0x6379ffd +com.adobe.boost_signals.framework boost_signals version 8.0.0 (8.0.0.0) <39CDA60E-525C-5D5D-F8B5-C0874C9210BF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
      0x638c000 -  0x661afec +libxerces-c-3.0.dylib ??? (???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libxerces-c-3.0.dylib
      0x679d000 -  0x679dff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
      0x67a0000 -  0x67caff3  com.apple.carbonframeworktemplate 1.0 (1.0) <19F5963C-F6A9-8012-A9DD-E26B1E10AF7C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
      0x6806000 -  0x682dfff +ameproperties ??? (???) <8E495A98-DA0B-DFF1-2FF6-D681C37620C8> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
      0x686e000 -  0x688fff7 +AdobeBIBUtils ??? (???) <5CD3EBDF-A36B-D8E4-587B-AE297DEB32AA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x689b000 -  0x689effc +com.adobe.AppServices.framework ??? (1.0) <4F73A218-468F-900C-2312-F7CA04DA0945> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
      0x68a9000 -  0x68ffffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.013) <0AD52D68-CDB5-CB04-2CDD-1FCF5CF6CABE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x6948000 -  0x69fdfe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
      0x6a43000 -  0x6b7efff +com.adobe.EUIFramework.framework ??? (1.0) <974AA901-74E7-833E-A18D-4F8AE5223C13> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/EUIFramework.framework/Versions/A/EUIFramework
      0x6cd8000 -  0x6ec2fff +com.adobe.SettingsUI.framework ??? (1.0) <3D9B681B-D5B0-42A5-896D-832C991B423B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
      0x70d9000 -  0x70eafff +com.adobe.DVDStructures.framework ??? (1.0) <093FD84B-330C-94B7-989A-936F12297C08> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/DVDStructures.framework/Versions/A/DVDStructures
      0x7107000 -  0x752cfef +com.adobe.AMocWrapper.framework ??? (1.0) <34ECBBFF-68ED-E7A3-F6C6-50A49178D7F6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMocWrapper.framework/Versions/A/AMocWrapper
      0x7750000 -  0x7757ff3 +com.adobe.ContentAnalysisDBCache.framework ??? (1.0) <78003AB9-2CF4-53CB-8EFB-FDDE0F069082> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisDBCache.framework/Versions/A/ContentAnaly sisDBCache
      0x7763000 -  0x77a6ff3 +com.adobe.ContentAnalysisData.framework ??? (1.0) <BCC67E4C-03C9-D29D-B039-C73FF039A85F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisData.framework/Versions/A/ContentAnalysis Data
      0x7808000 -  0x7838fff +com.adobe.ContentAnalysisHost.framework ??? (1.0) <09852D0F-1F7A-DBD4-B2AD-66F66B8444B6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisHost.framework/Versions/A/ContentAnalysis Host
      0x786b000 -  0x786ffff +com.adobe.BackendLegacyLib.framework ??? (1.0) <5850830D-48A5-27DA-EAD1-7A5A0E666471> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/BackendLegacyLib.framework/Versions/A/BackendLegacyLib
      0x7877000 -  0x7992fef +com.adobe.TitlerCreator.framework ??? (1.0) <AE329D7B-9784-C7FD-E261-612F3BE2F1EE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitlerCreator.framework/Versions/A/TitlerCreator
      0x7b14000 -  0x7e61ffb +com.adobe.premiere.TitleLayout 1.0 (1.0) <0CFBA6BD-2A55-FF49-D2A6-53B238E2E931> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
      0x840d000 -  0x8422fff +CAFilterUtils ??? (???) <1815CB67-8E4C-4792-1422-FE381D7AA2DA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/CAFilterUtils.framework/Versions/A/CAFilterUtils
      0x8437000 -  0x843dfff +com.adobe.IPLibrary.framework ??? (1.0) <D115D2C7-F6C9-3026-38D4-BC4524E00186> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/IPLibrary.framework/Versions/A/IPLibrary
      0x8446000 -  0x84f7ff3 +com.adobe.Descriptors.framework ??? (1.0) <0954EF40-080C-B04D-5EEC-32F4D8D075E3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Descriptors.framework/Versions/A/Descriptors
      0x8572000 -  0x8577ff3 +com.adobe.HeadlightsWrapper.framework ??? (1.0) <6E564A2A-A4E4-67A8-413F-02A34A97E971> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HeadlightsWrapper.framework/Versions/A/HeadlightsWrapper
      0x8581000 -  0x85dcfff +com.adobe.dvametadata.framework dvametadata version 8.0.0 (8.0.0.0) <AD79F718-1249-D410-5A37-59E0699390A7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
      0x865c000 -  0x86e7fff +com.adobe.dvametadataUI.framework dvametadataUI version 8.0.0 (8.0.0.0) <404F7BE8-8D03-35CD-2137-A00FD6CAC071> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
      0x877b000 -  0x891cfcf +AdobeOwl ??? (???) <710491D7-AD6A-47C5-92A0-E90151B60C9A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
      0x8982000 -  0x89f1ff7 +FileInfo ??? (???) <CED115CA-FEEE-9DEF-5759-72D9B9FEA892> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
      0x8a0e000 -  0x8a11ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0x8a17000 -  0x8a4bfe7 +com.adobe.TitlerUI.framework ??? (1.0) <4CACDAAE-001C-F5A1-898F-2B14D98FFFE3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitlerUI.framework/Versions/A/TitlerUI
      0x8a9d000 -  0x8afefff +com.adobe.premiere.FontEngine 1.0 (1.0) <FB2D387A-0F0E-013F-92E6-2E5E6084F787> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
      0x8b89000 -  0x8bb7ffd +com.adobe.premiere.TitleLayer 1.0 (1.0) <3D047AD6-39F7-B440-0D39-D316D66B6ED4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
      0x8da2000 -  0x8ed1fef +com.adobe.premiere.TitleCG 1.0 (1.0) <E015D8AD-C3A1-C861-748F-DEF0763C5413> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
      0x8f8f000 -  0x9036fe0 +com.adobe.premiere.TitleCharacterFactory 1.0 (1.0) <34DB2D94-8F74-7613-16FF-01AE4431BBBF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacte rFactory
      0x9091000 -  0x909dffb +com.adobe.premiere.TitleImageManager 1.0 (1.0) <C3F9477B-3A3A-EDEF-E8E3-12B025877DE5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
      0x90b4000 -  0x911effb +com.adobe.amtlib amtlib 3.5.0.20 (3.5.0.20) <0B8E82C2-3FAA-8E81-CEEA-BBFE29706530> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x9135000 -  0x91befff +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <0C5E995C-DA90-1F0E-B142-B5C3FC4CC906> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
      0x9232000 -  0x9817ff7 +com.adobe.premiere-elements.HSL ??? (1.0) <36197EE0-650B-886D-4CE0-07AB5783AE58> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
      0x9d48000 -  0x9ed6ffb +com.adobe.DVDCreator.framework ??? (1.0) <E643C53A-E360-6E54-E103-DB58EC502932> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/DVDCreator.framework/Versions/A/DVDCreator
      0xa053000 -  0xa109fff +com.adobe.HandlerAudioMixer.framework ??? (1.0) <A7F0782D-C13D-24C3-21D2-D7BEFBBD0156> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
      0xa1d2000 -  0xa1f6fff +com.adobe.HandlerAudioNarration.framework ??? (1.0) <AE6F7955-9C19-50AC-AD2B-EC2E02DEE615> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerAudioNarration.framework/Versions/A/HandlerAudioN arration
      0xa230000 -  0xa334fff +com.adobe.HandlerCapture.framework ??? (1.0) <ACA5E6D1-8430-F514-3365-0A4A65400480> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
      0xa446000 -  0xa77cff7 +com.adobe.HandlerEffectControls.framework ??? (1.0) <9378443B-038F-3A05-12CF-7086DFEA6EA4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffect Controls
      0xaa72000 -  0xaa80fff +com.adobe.HandlerEvents.framework ??? (1.0) <310A6DF6-0220-DF2C-EC3B-30814F5C9849> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
      0xaa9b000 -  0xaaaeffb +com.adobe.HandlerGetProperties.framework ??? (1.0) <941E8984-CC74-F069-1188-3F05E8B38CB1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProp erties
      0xaad0000 -  0xaae8ff7 +com.adobe.HandlerHistory.framework ??? (1.0) <15E02F92-25A5-2A61-B915-FD9C3A1FA23D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
      0xab13000 -  0xab48fff +com.adobe.HandlerInfo.framework ??? (1.0) <FD3317AB-F623-E1A0-C088-CEBBFC58ED41> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
      0xab80000 -  0xad32ff7 +com.adobe.HandlerMonitor.framework ??? (1.0) <4FC26F38-0E0E-489E-59C0-6A7988091956> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerMonitor.framework/Versions/A/HandlerMonitor
      0xaede000 -  0xb1bdff6 +com.adobe.HandlerProject.framework ??? (1.0) <E22BE716-3E82-5CF0-C62B-9F797BDE9590> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
      0xb4e3000 -  0xb743fff +com.adobe.HandlerTimeline.framework ??? (1.0) <1EE62095-F280-6C7A-49CF-94B565A29F1E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
      0xb96b000 -  0xb9c4ff7 +com.adobe.HandlerDVDLayout.framework ??? (1.0) <495EEB8D-9C35-927D-DD02-10A9F65E2195> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerDVDLayout.framework/Versions/A/HandlerDVDLayout
      0xba34000 -  0xba84fff +com.adobe.HandlerMovieTheme.framework ??? (1.0) <792629C8-A4D8-5187-69A5-E64FC9AC1587> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerMovieTheme.framework/Versions/A/HandlerMovieTheme
      0xbadc000 -  0xbc78fff +com.adobe.HandlerOrganizer.framework ??? (1.0) <C792AD1B-3F95-AAB6-D471-7F371265999A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerOrganizer.framework/Versions/A/HandlerOrganizer
      0xbe05000 -  0xbe24fff +com.adobe.HandlerSharingCenter.framework ??? (1.0) <8F4249BC-6E58-615A-D907-C707394E9209> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerSharingCenter.framework/Versions/A/HandlerSharing Center
      0xbe52000 -  0xbec5ffb +ScriptLayer ??? (???) <FFB6FD43-10B0-627D-A717-E5698FF141A6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
      0xbf1e000 -  0xbf40ff3 +com.adobe.PreRegistration.framework ??? (1.0) <94C61A84-5F2A-B564-AD2C-3FD5236DFD7E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PreRegistration.framework/Versions/A/PreRegistration
      0xbf5d000 -  0xbfc3ffb +com.adobe.OLS.framework ??? (1.0) <3E252689-2567-E85F-6F2F-61CC069DBD8A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/OLS.framework/Versions/A/OLS
      0xc01b000 -  0xc031ff7 +com.adobe.ARA.framework ??? (1.0) <FBD9EBC7-2A02-3F99-BC04-626A5AA7AD62> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ARA.framework/Versions/A/ARA
      0xc04d000 -  0xc061fff +UpdateManager ??? (???) <116FF8CB-8C96-FA63-F3A2-217093ADB095> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UpdateManager.framework/Versions/A/UpdateManager
      0xc069000 -  0xc07cffb +com.adobe.About.framework ??? (1.0) <5EE9AEF7-00EA-1E42-4CEF-B3969229AF5C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/About.framework/Versions/A/About
      0xc09c000 -  0xc0a4ffe +com.adobe.RoyaltyActivation.framework ??? (1.0) <2A936511-3BAD-5996-BEBC-6D41B685AED2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/RoyaltyActivation.framework/Versions/A/RoyaltyActivation
      0xc0b3000 -  0xc110ff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0) <68E6C383-CD4C-E602-8D48-EB2112D05B96> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
      0xc17e000 -  0xc1a4fff  libssl.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <9203FADE-F4F2-2245-A32E-BD88819D314D> /usr/lib/libssl.0.9.7.dylib
      0xc1b3000 -  0xc79dff7 +com.sonic.AS_Storage 4.26.7 (compatibility 1.0.0) <025EFB44-885B-5F07-70F2-3E382EE15EA4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AS_Storage.framework/Versions/A/AS_Storage
      0xcb04000 -  0xdb06fff +com.sonic.AuthorScriptHDMV 7.8.5 (1) <66242DA4-6A78-B73D-DDF8-9696CCF5B66D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AuthorScriptHDMV.framework/Versions/A/AuthorScriptHDMV
      0xf3a2000 - 0x100e6fff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <0A73AB2A-D09F-2F18-E2D1-BC35A8EED2A5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
      0x10425000 - 0x1193efe3 +com.adobe.AuthorScriptAPI.framework ??? (1.0) <B3F15D32-7B34-2F22-0505-008B74C313F3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AuthorScriptAPI.framework/Versions/A/AuthorScriptAPI
      0x12b96000 - 0x12bbcff6 +AdobeAXE8SharedExpat ??? (???) <62F48740-7712-3F35-BB04-D3B117F7CA64> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8Share dExpat
      0x12bcd000 - 0x12d05fe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
      0x12d47000 - 0x12daffcb +libDataCDUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libDataCDUtf8.dylib
      0x12e3a000 - 0x12ebbfd3 +libhpCDEUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libhpCDEUtf8.dylib
      0x12f59000 - 0x12f8dfd7 +libhpTAPEUtf8.dylib 2.2.1 (compatibility 2.2.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libhpTAPEUtf8.dylib
      0x12fe6000 - 0x13024fcf +libVideoDVDUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libVideoDVDUtf8.dylib
      0x1307e000 - 0x130cdff7 +com.adobe.SCCommon.framework ??? (1.0) <043B40C7-A6DA-4CCF-66BC-905500658C59> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCCommon.framework/Versions/A/SCCommon
      0x1311c000 - 0x13168fff +com.adobe.SCFlashDVD.framework ??? (1.0) <3E1C2A14-176C-8E07-E71C-0001C50BED07> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCFlashDVD.framework/Versions/A/SCFlashDVD
      0x131c3000 - 0x131fefff +com.adobe.SCDisc.framework ??? (1.0) <81352B65-189D-01D4-195C-456D71CFE639> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCDisc.framework/Versions/A/SCDisc
      0x13240000 - 0x1326bff7 +com.adobe.SCPC.framework ??? (1.0) <2AD4939C-F8E3-DB0D-90B3-7AA8B8CF776C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCPC.framework/Versions/A/SCPC
      0x13297000 - 0x132c0ff3 +com.adobe.SCMobile.framework ??? (1.0) <89DD9494-47EA-EDCE-3858-B6F4EAC08E49> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCMobile.framework/Versions/A/SCMobile
      0x132ec000 - 0x1334dff7 +com.adobe.SCWeb.framework ??? (1.0) <A3956DA8-00FD-093E-1D4F-FC3BA4F6A127> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCWeb.framework/Versions/A/SCWeb
      0x133b0000 - 0x133defff +com.adobe.PresetManager.framework ??? (1.0) <BD52C2A7-3400-1821-EEA7-B122C904CAA1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PresetManager.framework/Versions/A/PresetManager
      0x134bf000 - 0x134c0ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0x134e0000 - 0x134e8fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
      0x137c4000 - 0x137e8fe7  GLRendererFloat ??? (???) <1274B762-2FB9-48FE-EAFD-C459B2B4BECC> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
      0x14300000 - 0x14478fe7  GLEngine ??? (???) <3A6C5513-7428-2242-2892-B429C72343CB> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
      0x144fe000 - 0x14563fe7 +com.adobe.amt.services AMTServices 3.5.0.20 (BuildVersion: 3.5; BuildDate: Fri Jul 23 2010 21:49:00) (3.5.0.20) <9763F77A-D3BB-602B-E9B9-2C664CA32269> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0x1457f000 - 0x145effeb +com.adobe.adobe_caps adobe_caps 3.5.4.0 (3.5.4.0) <36D53A2C-0DAB-34C6-48C7-49D2ECF52D0D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
      0x2655a000 - 0x2695ffe7  libclh.dylib 3.1.1 C  (3.1.1) <745CBD72-DF1F-EC12-BE51-4EEA9847EADF> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
      0x26983000 - 0x272daff3  com.apple.driver.AppleIntelHDGraphicsGLDriver 1.6.26 (6.2.6) <ACD5A3C8-28DA-4098-3564-D0470FE9E0C6> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelH DGraphicsGLDriver
      0x2a73e000 - 0x2a750fff +com.adobe.pip ??? (5.0.0.2021) <5251926B-C2C0-282C-B3A9-94A9FEF0FCB8> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
      0x2ab74000 - 0x2ab76ffa +com.adobe.MediaCore.Opacity 1.0 (1.0) <63F5B0FA-8C5C-9EDF-6981-F5D41CE746E5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/Opacity.bundle/Contents/MacOS/Opacity
      0x2ab7c000 - 0x2ab7eff7 +com.adobe.MediaCore.Motion 1.0 (1.0) <6E0EBBD7-AD6A-841B-6929-355081DED061> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/Motion.bundle/Contents/MacOS/Motion
      0x2dd44000 - 0x2dd49ff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <4591F641-2C45-64A2-6C1C-C1722076B7F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
      0x2dd4e000 - 0x2dd64fff +com.adobe.MediaCore.DeviceControlFirewire 1.0 (1.0) <B0E9002A-0CF2-7E7F-4C8E-79463F600985> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/DeviceControlFireWire.bundle/Contents/MacOS/DeviceC ontrolFirewire
      0x2e935000 - 0x2e939ff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <6A211097-72ED-1461-4050-72C9101D79E4> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x2f1ca000 - 0x2f1eeff1 +com.mainconcept.mc_dec_dv 8.5 (8.5.0.24499) <38CCE568-A850-87C4-E9F7-E58787D658D2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
      0x2f208000 - 0x2f20effb  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <404165FF-1BA0-706B-F48A-10AC997162B1> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x2f305000 - 0x2f326ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.24499) <AFB082F8-C0A3-AEF0-795A-602ED161B259> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
      0x2f33b000 - 0x2f355fff  com.apple.carbonframeworktemplate 1.0 (1.0) <32C18346-63D3-40A8-CE94-4FC8D0B42759> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VXMLPresetReader.framework/vxmlpresetreader
      0x2f382000 - 0x2f3a8ff3 +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0) <ED4D25C9-22EF-C39D-CF9C-229AC6A2A55A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
      0x2f3d8000 - 0x2f3f3fff +com.adobe.MediaCore.ImporterPSA 1.0 (1.0) <D513F20E-C7D5-7587-E2B9-FEF7040307D6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterPSA.bundle/Contents/MacOS/ImporterPSA
      0x2f481000 - 0x2f487fef +libtbbmalloc.dylib ??? (???) <12F9EB2C-C80A-6170-E088-7DBDE36511E3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libtbbmalloc.dylib
      0x2f57d000 - 0x2f5b3fff +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0) <777F7F6D-ED06-AFB5-9463-79B84293920D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
      0x2f5e7000 - 0x2f5fdfff +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0) <304D1A7D-199A-9D91-8F64-24D34118854B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
      0x2f62b000 - 0x2f6dfffa +com.adobe.PremiereElements.PhotoshopAdapter 1.0 (1.0) <D4D185C2-85C4-89BD-B10A-376EACF31538> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PSA/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter
      0x2f80a000 - 0x2f884ff7 +com.adobe.MediaCore.PlayerMediaCore 1.0 (1.0) <51B4B720-6D18-5858-7F3E-24433AAD1A2C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCo re
      0x2fd03000 - 0x2fd34ff2  com.apple.AVCVideoServices 1.0 (42) <8E8CFE8F-9877-45EB-8E6A-A47376F209FD> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
      0x2fd61000 - 0x2fdbefef +aif_core ??? (???) <AF9EC89D-F9B4-E6A6-B55D-D61CE910B3CD> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
      0x2fddb000 - 0x2fdf5ff7 +image_runtime ??? (???) <8D487FD0-02CF-C361-67CB-4D613BE64322> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
      0x2fe11000 - 0x2fe33ff7 +libtbb.dylib ??? (???) <AAA2AFA2-789A-41B8-D03D-C03861305060> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libtbb.dylib
      0x2fe52000 - 0x2fe6dfff +com.adobe.MediaCore.AudioVideoIO 1.0 (1.0) <06DFAEC5-EB7B-0707-59DD-AE6DC73F9DB7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/AudioVideoIO
      0x2fec1000 - 0x2fed0fe8 +com.adobe.MediaCore.PremiereFiltersMetaPlugin 1.0 (1.0) <32340239-6068-936B-6D9B-315772F73D51> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/Premi ereFiltersMetaPlugin
      0x2fee9000 - 0x2fef7fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <AFA4C3C8-D752-EC96-FF56-6E2F8ABB391B> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0x30000000 - 0x3001affb +com.adobe.MediaCore.RecorderHDVMac 1.0 (1.0) <A0B52854-01A3-F2BC-40BF-2CE8341F7FC6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderHDVMac.bundle/Contents/MacOS/RecorderHDVMac
      0x30038000 - 0x3004bfe4 +com.adobe.MediaCore.TransitionsMetaPlugin 1.0 (1.0) <F483C239-B9FF-D716-13C4-E61183FE464A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/Transitio nsMetaPlugin
      0x30069000 - 0x30075ff7 +com.adobe.SceneDetectCAFilter.framework ??? (1.0) <589D349F-7048-8DDA-689A-124D0D6E3779> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/SceneDetectCAFilter.sd/SceneDetectCAFilter
      0x304fc000 - 0x30575fe7 +com.adobe.MediaCore.Frameworks.Display ??? (1.0) <F71E47B3-C7D1-4C41-CED4-6F54439EF979> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Display.framework/Versions/A/Display
      0x3120d000 - 0x3143effb +aif_ogl ??? (???) <A5F168B4-8DCC-37BF-0DA3-D51E0D287360> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
      0x3152a000 - 0x3155dfff +com.adobe.MediaCore.RecorderQTKit 1.0 (1.0) <60CF5F61-EB52-12B9-2A62-4D6104B5F5EB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderQTKit.bundle/Contents/MacOS/RecorderQTKit
      0x321dd000 - 0x322a3fef +com.adobe.MediaCore.IPPMPEGDecoder 1.0 (1.0) <ACB0B3C1-3B22-D9D7-8F9A-8E20313651ED> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
      0x322e9000 - 0x3231efe3 +com.adobe.MediaCore.RecorderWebCamQTKit 1.0 (1.0) <287BB18E-5C7E-C902-4297-EFCF4EB771BC> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderWebCamQTKit.bundle/Contents/MacOS/RecorderW ebCamQTKit
      0x3234a000 - 0x32367feb +AudioCAFilter ??? (???) <B1686B6C-01DF-4529-9D6B-E46A8B33ED2A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/AudioCAFilter.framework/AudioCAFilter
      0x32379000 - 0x32389fff +BlurCAFilter ??? (???) <F891B2EA-5208-8F6D-F144-78563BBBD59A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/BlurCAFilter.framework/BlurCAFilter
      0x3239b000 - 0x323a9fff +BrightnessContrastCAFilter ??? (???) <F4A5859D-E651-4BC2-6D46-5AF0FCE83276> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/BrightnessContrastCAFilter.framework/BrightnessContrastCAFilter
      0x323bb000 - 0x323e7ff7 +FaceDetectionCAFilter ??? (???) <A232DEA3-AD5D-50AF-750F-DFEB84A8BB93> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/FaceDetectionCAFilter.framework/FaceDetectionCAFilter
      0x32417000 - 0x324bcffb +FaceDetector ??? (???) <1275F007-B8A7-CA23-8F89-570E182FCBA8> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FaceDetector.framework/Versions/A/FaceDetector
      0x325db000 - 0x325f1fff +MotionCAFilter ??? (???) <6BD6EE6A-1580-9A9A-2579-D47877ACA255> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/MotionCAFilter.framework/MotionCAFilter
      0x32605000 - 0x32652fff +ObjTrackCAFilter ??? (???) <2981BC3B-1014-6B92-38AF-37E50435D226> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/ObjTrackCAFilter.framework/ObjTrackCAFilter
      0x3268e000 - 0x326a1ff7 +ShakeCAFilter ??? (???) <8B112F2F-9FA8-FEC1-DF66-EE530520C976> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/ShakeCAFilter.framework/ShakeCAFilter
      0x32734000 - 0x327c5ff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
      0x327e4000 - 0x327f6ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <08801444-00D2-E55B-AE80-B807B99BB0C6> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x3317e000 - 0x33197fff +com.adobe.MediaCore.ImporterPNG 1.0 (1.0) <D64F6813-0A7B-B5B8-C255-19C095DF3DD1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterPNG.bundle/Contents/MacOS/ImporterPNG
      0x33696000 - 0x33ee7fe7 +com.adobe.CameraRaw 6.1 (250) (6.1.0f250) <3A299A4B-A870-ED39-01E7-BC3B8CF56198> /Library/Application Support/Adobe/Plug-Ins/Elements 9/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
      0x34268000 - 0x3489cfeb +com.adobe.PDFL 9.9.0 (9.9.0.7414) <49D6D58A-1EBB-424A-4CB0-8F9691E0991D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
      0x34acf000 - 0x34ad3ffb +com.adobe.MediaCore.AEFilterCrop 1.0 (1.0) <01E09989-8A97-994C-185A-47EA87449E5B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/AEFilterCrop.bundle/Contents/MacOS/AEFilterCrop
      0x34cca000 - 0x34cf3feb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <E0F7666B-921D-C4D6-63B3-E8B445D26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
      0x34d03000 - 0x34e45fe7 +com.adobe.ols.library 4.0 (4.0) <4BC1EDD1-F363-2845-36E1-36692B624FCB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeOLS.framework/AdobeOLS
      0x35045000 - 0x35047fff +com.adobe.MediaCore.ImporterColorMatte 1.0 (1.0) <3B2866C1-9545-E066-D605-17AE1BB3C5C0> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterColorMatte.bundle/Contents/MacOS/ImporterCo lorMatte
      0x3504e000 - 0x35055fff +com.adobe.MediaCore.ObjectTracking 1.0 (1.0) <CD8E3D03-BC6B-A8B3-A2CD-455BA9C2BB52> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ObjectTracking.bundle/Contents/MacOS/ObjectTracking
      0x35ad7000 - 0x35b10ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.5.0.13 (1.5.0.13) <4F8229DD-D239-3773-1A53-51ECFA787463> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotific ations
      0x35be4000 - 0x35c08ff7 +com.adobe.MediaCore.ImporterMPEG 1.0 (1.0) <E2936BC2-52B3-84AE-A07B-EDC2E498100D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
      0x36dee000 - 0x36e0efff +com.adobe.MediaCore.ImporterFastMPEG 1.0 (1.0) <3F562922-B9C9-5147-0D0B-B5583135A622> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterFastMPEG.bundle/Contents/MacOS/ImporterFast MPEG
      0x37774000 - 0x37777ff3  libFontRegistryUI.dylib ??? (???) <8943206D-4B80-BE67-B17A-AF89D68C76DE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
      0x380b6000 - 0x38a66fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
      0x3b840000 - 0x3b902fec +com.mainconcept.mc_demux_mp2 8.5 (8.5.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_demux_mp2.framework/mc_demux_mp2
      0x3bd47000 - 0x3bd49ffb +com.adobe.MediaCore.AEFilterGaussianBlur 1.0 (1.0) <EDE9322D-71BE-64EA-CA6E-4E4A19022806> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/AEFilterGaussianBlur.bundle/Contents/MacOS/AEFilter GaussianBlur
      0x3e000000 - 0x3e046ff7  com.apple.glut 3.4.4 (GLUT-3.4.4) <DF15FD36-E1F5-D745-1BF6-DD3AEA2897E4> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
      0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <2ABF10A7-540A-06C8-21FA-186263931DF9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
      0x40483000 - 0x406b1ff7 +com.mainconcept.mc_bc_dec_avc 8.5 (8.5.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_bc_dec_avc.framework/mc_bc_dec_avc
      0x522af000 - 0x522c3ff7 +com.adobe.MediaCore.ExporterMPEGPreview 1.0 (1.0) <2AB62EBA-010B-0224-4411-B2E9E90A1A15> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterM PEGPreview
      0x52e2c000 - 0x52f18ffb +com.yourcompany.ems 1.0 (1) <2BD7FA47-A217-48B7-4F02-20E86E02A40E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ems.framework/ems
      0x52fa9000 - 0x52fd6ff3 +libcurl ??? (???) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libcurl.framework/libcurl
      0x57435000 - 0x574efff8 +com.mainconcept.mc_mux_mp2 8.5 (8.5.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/8.5/mc_mux_mp2
      0x57518000 - 0x57641fff +com.mainconcept.mc_enc_mp2v.004 8.6 (8.6.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_enc_mp2v.004.framework/mc_enc_mp2v.004
      0x8f0c8000 - 0x8f811ff7  com.apple.GeForceGLDriver 1.6.26 (6.2.6) <518182BB-5A3C-5F4C-3A84-17BB8E385BBF> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <749D24EE-54BD-D74B-D305-C13F5E6C95D8> /usr/lib/dyld
      0x90003000 - 0x90004ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x90131000 - 0x90131ff7  com.apple.Carbon 150 (152) <734BDB59-8B13-54FA-0653-AA8623DF9846> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x90145000 - 0x90156ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x90157000 - 0x90162ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <CB2510BD-A5B3-9D90-5917-C73F6ECAC913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x90163000 - 0x901a4ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <16DAE1A5-937A-1CA2-D98F-2AF958B62993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x901a5000 - 0x9024dffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x90281000 - 0x902beff7  com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x902bf000 - 0x902e9ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x902ea000 - 0x90321fe7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
      0x90322000 - 0x9037afe7  com.apple.datadetectorscore 2.0 (80.7) <F7416A84-E91C-5BDC-10E3-4940EB7AE5C9> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x9037b000 - 0x903dfffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x903e0000 - 0x903eeff7  com.apple.opengl 1.6.12 (1.6.12) <9F13B279-F289-18AC-5D86-DCD52BAF087D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x904da000 - 0x904fafe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <BF7FF2F6-5FD3-D78F-77BC-9E2CB2A5E309> /usr/lib/libresolv.9.dylib
      0x905da000 - 0x90623fe7  libTIFF.dylib ??? (???) <72AC8D6B-F187-1462-901F-999E68C24848> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x90736000 - 0x908effeb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <6D8C6C54-9F39-0D0F-564D-2ABA12E97BBC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x908f0000 - 0x90905fff  com.apple.ImageCapture 6.0.1 (6.0.1) <E7ED2AC1-834C-A44E-531E-EC05F0496DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x90907000 - 0x9090aff7  libCoreVMClient.dylib ??? (???) <973B9E1F-70B3-2E76-B14B-E57F306AD2DF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x90924000 - 0x90a25fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <ED8E45C6-B078-15E8-938D-99D8FD1EAE64> /usr/lib/libxml2.2.dylib
      0x90a26000 - 0x90a2eff7  com.apple.DisplayServicesFW 2.3.0 (283) <305F9514-2404-5CF7-AFB4-00BB4D2EA69E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x90a2f000 - 0x90a36ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <61A74CE1-750D-9CAB-B780-306841739EE1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x90a37000 - 0x90af0fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
      0x90af1000 - 0x90b0dfe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x90b0e000 - 0x90b0eff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x90b0f000 - 0x90b0fff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
      0x90b10000 - 0x90b49ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <E0D512DD-365D-46A0-F50C-435BC250424F> /usr/lib/libcups.2.dylib
      0x90b4a000 - 0x90b50ff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <DACD11D8-4B64-CD3B-C988-B1041E07D13A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
      0x90bc6000 - 0x90e39fe7  com.apple.Foundation 6.6.4 (751.42) <65F16BF4-D106-F2F5-53F3-5BFBC2FCE608> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x90e3a000 - 0x90e40fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x90e41000 - 0x912faffb  com.apple.VideoToolbox 0.484.20 (484.20) <E7B9F015-2569-43D7-5268-375ED937ECA5> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x912fb000 - 0x9133ffe7  com.apple.Metadata 10.6.3 (507.15) <A23633F1-E913-66C2-A073-E2B174C09B18> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x91350000 - 0x91376ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x91377000 - 0x91697ff3  com.apple.CoreServices.CarbonCore 861.23 (861.23) <96534EF7-C22E-0C01-C56F-FF7047E41224> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x91698000 - 0x917c7fe3  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x917cd000 - 0x91810ff7  libGLU.dylib ??? (???) <BB66EDB2-D5FE-61C9-21BE-747F9862819C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x91811000 - 0x91811ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x91812000 - 0x9181dff7  libGL.dylib ??? (???) <48405993-0AE9-292B-6705-C3525528682A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x9181e000 - 0x91842ff7  libJPEG.dylib ??? (???) <E064CF03-8CC2-C83E-C951-D46610834D1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x91843000 - 0x918bdfff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <A02CEAE9-943A-CBE2-2350-4631C1E7B0A7> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x918be000 - 0x918ceff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
      0x918d2000 - 0x918edff7  libPng.dylib ??? (???) <DF9BC42C-13E0-3080-A106-75121FD577CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x918fb000 - 0x9193dff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x9193e000 - 0x919ecff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x91a15000 - 0x91a19ff7  libGIF.dylib ??? (???) <FA466D54-68CF-D1AB-47A0-4134C8B1B6FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x91a1a000 - 0x91e4fff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x91e57000 - 0x91e7fff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
      0x91ee0000 - 0x91f5bfff  com.apple.AppleVAFramework 4.10.12 (4.10.12) <0B523224-8EE3-988D-04BE-D608953CC977> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x91f5c000 - 0x91f5eff7  com.apple.securityhi 4.0 (36638) <C7DA80C1-DCFD-C321-08DA-5E6946CA66E0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x91fad000 - 0x92077fef  com.apple.CoreServices.OSServices 357 (357) <F66F783A-9B51-953F-CAC9-509E1F550B4B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x92078000 - 0x920beff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
      0x920bf000 - 0x92266ff7  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <4FFBF71A-D603-3C64-2BC6-BFBFFFD562F0> /usr/lib/libSystem.B.dylib
      0x92267000 - 0x9231dff7  libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x9231e000 - 0x923bbfe3  com.apple.LaunchServices 362.2 (362.2) <F3952CAB-322F-A12F-57AF-8B91B1D76DDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x93356000 - 0x933a7ff7  com.apple.HIServices 1.8.2 (???) <F6EAC2D1-902A-9374-FC4B-43B50E054416> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x933a8000 - 0x933e0fe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <242954AD-3BE1-29E8-E2E0-08063201F105> /usr/lib/libcurl.4.dylib
      0x933e1000 - 0x9348efe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <C8925910-B927-968B-4B71-D83A4CEF8646> /usr/lib/libobjc.A.dylib
      0x934d2000 - 0x93504fe3  libTrueTypeScaler.dylib ??? (???) <6E9D1A50-330E-F1F4-F93D-9ECC8A61B21A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x93505000 - 0x93542ff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x93549000 - 0x9357aff7  libGLImage.dylib ??? (???) <E3EC8E92-4DDD-E7B8-3D38-C5A5160A4930> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x9357b000 - 0x9389ffef  com.apple.HIToolbox 1.6.4 (???) <4699C8BB-DE74-C530-564B-D131F74C9B54> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x938a0000 - 0x93971fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <631392F6-6E50-278C-70FF-7969E35C498D> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
      0x93972000 - 0x93972ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x943fe000 - 0x94412ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <0DBE17D5-17A2-8A0E-8572-5A78408B41C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x9442c000 - 0x94462fff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
      0x945d9000 - 0x945d9ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x946fd000 - 0x94706ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x94707000 - 0x94737ff7  com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
      0x94738000 - 0x94742fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x94794000 - 0x94794ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x9479d000 - 0x947aaff7  com.apple.NetFS 3.2.1 (3.2.1) <94A52A6D-F071-09D7-E80F-F633F17233FE> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x947b0000 - 0x947b6fe7  com.apple.CommerceCore 1.0 (6) <41C2A87D-93D8-56C1-9292-0400699F23C1> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
      0x947b7000 - 0x94818fe7  com.apple.CoreText 3.5.0 (???) <BB50C045-25F5-65B8-B1DB-8CDAEF45EB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x94819000 - 0x94857ff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x94858000 - 0x949dafe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
      0x949db000 - 0x949dcff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
      0x949dd000 - 0x94a56ff7  com.apple.PDFKit 2.5.1 (2.5.1) <A068BF37-03E0-A231-2791-561C60C3ED2B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x94a63000 - 0x94c3eff3  libType1Scaler.dylib ??? (???) <A7AB841A-3F40-E0B8-ADDD-44014C7287C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
      0x94d94000 - 0x94da6ff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <32CE2895-DAF0-2137-F9BE-8150359F43A1> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x94da7000 - 0x94e57ff3  com.apple.ColorSync 4.6.3 (4.6.3) <0354B408-665F-8B3F-87FF-64E6322276F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x94e58000 - 0x94e6cfe7  libbsm.0.dylib ??? (???) <821E415B-6C42-D359-78FF-E892792F8C52> /usr/lib/libbsm.0.dylib
      0x94e6d000 - 0x94e7dff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
      0x94e7e000 - 0x94facfe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x94fad000 - 0x94fadff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x94fae000 - 0x94fe1ff7  com.apple.AE 496.4 (496.4) <C73D124C-C722-41D8-3465-4CE0D0BA9307> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x94fe2000 - 0x95050ff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
      0x95051000 - 0x95931ff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x9595c000 - 0x959b6fe7  com.apple.CorePDF 1.3 (1.3) <EA168671-F44F-BFE4-AA7D-3801DA29A650> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x959b7000 - 0x95a04feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <E2632F3E-6B5C-2E92-CD11-15BC0CE109CA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x95a05000 - 0x95a48ff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x95a49000 - 0x95ab3fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x95ab4000 - 0x95b4fff7  com.apple.ApplicationServices.ATS 4.4 (???) <ECB16606-4DF8-4AFB-C91D-F7947C26040F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x95b50000 - 0x95b5aff7  com.apple.HelpData 2.0.4 (34) <001A7163-C977-C30F-1B4B-4F5647F72E96> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x95b82000 - 0x95c1afe7  edu.mit.Kerberos 6.5.10 (6.5.10) <DC19F49B-184E-FD0F-13F8-3A31924A3B66> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x95c1b000 - 0x95c9dffb  SecurityFoundation ??? (???) <2E1F1AF0-A258-D215-2600-5DF03896D1F1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x95c9e000 - 0x95d0dff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x95e1e000 - 0x95e1fff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <BE4C2495-B758-AD22-DCC0-56A6791E948E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x95e71000 - 0x95eeeff7  com.apple.iLifeMediaBrowser 2.5.4 (468.1.1) <3B7F5895-B48D-A2E0-D708-58EC58EB9514> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
      0x95eef000 - 0x95f33ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x95f34000 - 0x95f39ff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x95f3a000 - 0x95f3dfe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x95f3e000 - 0x95f45ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x95f46000 - 0x95f50ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x95f51000 - 0x96740557  com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x96741000 - 0x9686dffb  com.apple.MediaToolbox 0.484.20 (484.20) <D67788A2-B772-C5DB-B12B-173B2F8EE40B> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x9686e000 - 0x96c54ffb  com.apple.RawCamera.bundle 3.4.1 (546) <D966727B-B687-3029-067F-87FC6CCEBB55> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x96c55000 - 0x96c55ff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x96c56000 - 0x96c95ff7  com.apple.ImageCaptureCore 1.0.3 (1.0.3) <7E02D104-F31C-CF72-71B4-DA5DF7B48337> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x97014000 - 0x97064ff7  com.apple.framework.familycontrols 2.0.2 (2020) <AF7F86F1-F7BF-CBA8-7A4A-D8F7A19F9601> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x9735f000 - 0x97380fe7  com.apple.opencl 12.3 (12.3) <DEA600BF-4F54-66B5-DB2F-DC57FD518543> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x975b5000 - 0x97647fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x97648000 - 0x9768fffb  com.apple.CoreMediaIOServices 134.0 (1160) <D4F40A28-4E31-3210-7C2B-59D8A1903FB2> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
      0x97690000 - 0x976afff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x976b0000 - 0x976d7ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0x976d8000 - 0x976dbff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B624AACE-991B-0FFA-2482-E69970576CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x97791000 - 0x97893fef  com.apple.MeshKitIO 1.1 (49.2) <D0401AC5-1F92-2BBB-EBAB-58EDD3BA61B9> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
      0x97894000 - 0x97896ff7  libRadiance.dylib ??? (???) <68BF4654-B74A-C843-759F-7FC62385F251> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x978cc000 - 0x978dafe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
      0x978db000 - 0x97ad8ff7  com.apple.JavaScriptCore 6533.19 (6533.19.1) <85A6BFDD-CBB6-7490-748D-8EA8B9B7FDD8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x97ad9000 - 0x97b11ff7  com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
      0x97b12000 - 0x97b16ff7  libGFXShared.dylib ??? (???) <9E14BE2F-C863-40E9-41A6-1BE9045663A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x97b17000 - 0x97b39fef  com.apple.DirectoryService.Framework 3.6 (621.9) <3171B16F-E4E1-89AA-B846-D698E3D6D457> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x97b3a000 - 0x97d1cfff  com.apple.imageKit 2.0.3 (1.0) <B4DB05F7-01C5-35EE-7AB9-41BD9D63F075> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x97e12000 - 0x98075fff  com.apple.security 6.1.1 (37594) <B6F2A8BF-C1B7-A0E2-83FB-4FF265E9BDDC> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x981b9000 - 0x985cfff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x98681000 - 0x989ecff7  com.apple.QuartzCore 1.6.3 (227.34) <0B59EAF1-4892-C5CE-4A67-66EBD383359E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x989ed000 - 0x989f1ff7  IOSurface ??? (???) <235E7E3D-B6E5-0AAA-C41A-7AC1F54A7EBF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x98a59000 - 0x98ab6ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x98ab7000 - 0x98abaffb  com.apple.help 1.3.1 (41) <EF92C648-2085-C085-8EA7-A1AF37AE94F4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x98abb000 - 0x98b65fe7  com.apple.CFNetwork 454.11.5 (454.11.5) <DD575760-7A29-111D-5A69-EAFD3410F74D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x98b66000 - 0x98c72ff7  libGLProgrammability.dylib ??? (???) <A077BFEA-19C6-9F48-2F36-8E4E55376F49> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x98c73000 - 0x98f6cfef  com.apple.QuickTime 7.6.6 (1756) <3C041DD9-A5DB-60CA-8418-E58A78C9468E> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x98f6d000 - 0x9904aff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x99056000 - 0x99062ff7  libkxld.dylib ??? (???) <9D8378E0-1C58-EED8-EA00-F4515B8BE7A3> /usr/lib/system/libkxld.dylib
      0x99066000 - 0x990e6feb  com.apple.SearchKit 1.3.0 (1.3.0) <2F5DE102-A203-7905-7D12-FCBCF17BAEF8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x99156000 - 0x991acff7  com.apple.MeshKitRuntime 1.1 (49.2) <CB9F38B1-E107-EA62-EDFF-02EE79F6D1A5> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
      0x991ad000 - 0x993d8ff3  com.apple.QuartzComposer 4.2 ({156.28}) <62E864AD-3155-59B8-BA1F-8197360C8587> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x993d9000 - 0x994b4feb  com.apple.DesktopServices 1.5.9 (1.5.9) <CED00AC1-924B-0E45-7D5E-1CEA8929F5BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x9961d000 - 0x99635ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x99640000 - 0x997bbfe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x997bc000 - 0x998fffef  com.apple.QTKit 7.6.6 (1756) <8AE4C93B-6059-7B87-2FF6-8B225EBB21A7> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x99900000 - 0x9993bfeb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x9993c000 - 0x99a40fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
      0xb0000000 - 0xb0010ff8 +com.adobe.ahclientframework 1.6.0.5 (1.6.0.5) <8F89CE47-10C1-AE43-AB78-7BB2D24BA50B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
      0xba300000 - 0xba301fe7  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <80E8C2F7-3210-7A58-F083-F24AF7075E79> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
      0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <02CCC192-2AC9-73DF-4A40-0B3AF87B6372> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <8697CB9C-AC3B-301B-F1BD-382E30FA5642> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xc0000000 - 0xc0004ff9 +com.mainconcept.mc_enc_mp2v 8.6 (8.6.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/8.6/mc_enc_mp2v
      0xc1000000 - 0xc100fff7 +com.mainconcept.mc_enc_mpa 8.5 (8.5.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/8.5/mc_enc_mpa
      0xc4000000 - 0xc4073ff3 +com.mainconcept.mc_mfimport 8.5 (8.5.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_mfimport.framework/Versions/8.5/mc_mfimport
      0xca000000 - 0xca011fff +com.mainconcept.mc_dec_dd 7.5 (7.5.0.47396) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_dec_dd.framework/mc_dec_dd
      0xcc000000 - 0xcc186fef +com.mainconcept.mc_dec_mp2v 8.5 (8.5.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/8.5/mc_dec_mp2v
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <4FFBF71A-D603-3C64-2BC6-BFBFFFD562F0> /usr/lib/libSystem.B.dylib
      Model: MacBookPro6,2, BootROM MBP61.0057.B0C, 2 processors, Intel Core i5, 2.53 GHz, 4 GB, SMC 1.58f15
      Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 256 MB
      Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.10.131.36.1)
      Bluetooth: Version 2.3.8f7, 2 service, 19 devices, 1 incoming serial ports
      Network Service: Ethernet, Ethernet, en0
      Serial ATA Device: Hitachi HTS545050B9SA02, 465,76 GB
      Serial ATA Device: MATSHITADVD-R   UJ-898
      USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd100000
      USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd120000
      USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8507, 0xfd110000
      USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfa100000
      USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8218, 0xfa113000
      USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0xfa130000
      USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0237, 0xfa120000
