7 Replies Latest reply: Nov 29, 2011 10:13 AM by MichaelD443 RSS
    TOC Text alterations
    Missteach Community Member
      Hello,
      Unless I'm going mad, I can't see a way of altering the TOC text at the top of the block where it states:  'Slide Title'..  Is this possible?  Please see screenshot to see the text I refer to.  Thanks.
        • 1. Re: TOC Text alterations
          imagic2010
          @wodehouse Great question that I'd love the answer to, as well. On a related note, how were you able to remove the duration and status columns/fields from the TOC? I'm looking to do that for a project I'm working on to free up character space for Topic Titles.
          TIA!
          • 2. Re: TOC Text alterations
            rgcunningham Community Member
            Actually, it is possible to change that text.  Create a simple text file named TOCStrings.ini and place it in the Captivate install folder (C:\Program Files\Adobe\Adobe Captivate 4  for Captivate 4 or C:\Program Files\Adobe\Adobe Captivate 5 for Captivate 5.)  I used Windows Notepad to create the file.  In the text file, add text like the following:
            [TOCStrings]
            SlideTitle=Slide
            Duration=Length
            Status=Visited
            ClearToolTip=Erase Check Mark
            This will not effect any Captivate projects you have already created, but for any new projects, the text strings will be replaced.
            If you don't want slide duration to show at all, in the Skin Editor, TOC tab, click the Settings button and click the checkbox to deselect Show Duration.
            I hope this helps.
            Mister C.
            (I just tried this in Captivate 5 and the changes do effect existing projects.  In Captivate 4 it only effects new projects.)
            Message was edited by: rgcunningham
            • 3. Re: TOC Text alterations
              imagic2010 Community Member
              That's a huge help. Thanks!!
              • 4. Re: TOC Text alterations
                Mister C,
                Is there additional documentation on customizations to the TOC or Skin Editor like this somewhere? This would seem ilke fairly deep knowledge but wondering if I can read up on it somewhere.
                TIA,
                Jay
                • 5. Re: TOC Text alterations
                  Lilybiri CommunityMVP
                  Hello,
                  About the ini-file there was a posting in the Captivate blog for CP4 somewhere.
                  Lliybiri
                  • 6. Re: TOC Text alterations
                    Hi Jay.  Unfortunately, there really isn't any other documentation.  My other sources are generally these forums, plus the Adobe Captivate Blog.  As a matter of fact, the solution I posted here came from the Captivate Blog at http://blogs.adobe.com/captivate/2009/02/changing_default_captions_in_t.html.  If you use the Adobe Community Help feature, you can search through both Adobe reference materials and online sources like the blog.
                    Hope this helps.
                    Mister C.
                    • 7. Re: TOC Text alterations
                      MichaelD443 Community Member
                      CPT v5.5
                      Win7(64)
                      Firefox browser v7.01
                      Clearing the checkmark for "Duration" removes the times for each slide but leaves the duration at the bottom of the TOC. Is there another way to get rid of the duration entirely? The CPT module proceeds with learner mouse clicks so the duration is superfluous.
                      Thanks.
                      Skin Editor TOC Duraton Screen Clip.pngTable of Contents Duration Screen Clip.png
