0 Replies Latest reply on Jan 19, 2011 11:43 AM by bon_t
    Sound Class - When is sound.length determined?
    bon_t
      Hi All,
      I am using ActionScript 3.0.  I am implementing a sound player with the requisite buttons.  I also have an audio slider and a volume slider.
      A teammate found the following code online:
      AbstractPlayer:
      package com.nuance.nlportal.audioplayer
          import com.nuance.nlportal.audioplayer.events.DownloadEvent;
          import com.nuance.nlportal.audioplayer.events.Id3Event;
          import com.nuance.nlportal.audioplayer.events.PlayProgressEvent;
          import com.nuance.nlportal.audioplayer.events.PlayerEvent;
          import flash.events.Event;
          import flash.events.EventDispatcher;
          import flash.events.IOErrorEvent;
          import flash.events.ProgressEvent;
          import flash.events.TimerEvent;
          import flash.media.Sound;
          import flash.media.SoundChannel;
          import flash.media.SoundTransform;
          import flash.utils.Timer;
          import mx.controls.Alert;
           * This class is the blueprint for the music player, it describes the rules by which player behave.
          public class AbstractPlayer extends EventDispatcher
              //  Variables
              protected var sound:Sound;
              protected var channel:SoundChannel;
              protected var soundPosition:Timer;
              protected var fileBytesTotal:Number;
               * Holds the pause position
              protected var mPausePosition:Number;
               * Flag indicating weather the track is in pause mode
              protected var mIsPause:Boolean = false;
               * Flag to indicate weather the track is currently playing
              protected var mIsPlaying:Boolean = false;
               * Play position in seconds
              private var mAudioPosition:Number;
               * Total song length in seconds
              private var mAudioLength:Number;
               * Song URL
              private var mAudioURL:String;
               * Player volume
              private var mVolume:Number = 1.0;
              //  Getters and setters
              public function get songPosition():Number
                  return mAudioPosition;
              public function set songPosition(val:Number):void
                  mAudioPosition = val;
              public function get songLength():Number
                  return mAudioLength;
              public function set songLength(val:Number):void
                  mAudioLength = val;
              public function get songURL():String
                  return mAudioURL;
              public function set songURL(val:String):void
                  mAudioURL = val;
              //  Constructor
              public function AbstractPlayer()
               * Method to play track, based on url.  The method handles cases where the user clicked on play after it is already playing and for
               * cases where the track was paused. Music file doesn't provide the lenght of the song right away, but it's changing during the progress
               * of the music file, so you can pass the lenght of the song, if you know it, other wise you can take if from the <code>PlayProgressEvent</code>
               * @param songUrl song url is the location of the music file.
               * @param songLenght downloading music file doesn't provide the lenght of the song right away, but after portion of the song downloaded
              public function playTrack(songUrl:String, songLenght:Number=0):void
              //public function playTrack(songUrl:String, position:Number=0, songLenght:Number=0):void
                  // needs to implement
               * Method to pause a track.
              public function pauseTrack():void
                  soundPosition.stop();
                  channel.stop();
                  mIsPause = true;
                  mPausePosition = channel.position;
                  // [Added by BT 21/12/10] - If mIsPlaying remains true, then the first thing that happens in playAudio()
                  // is to stopAudio() -> stopTrack() -> resetPlayer() -> mIsPause = false -> mIsPause check fails in playTrack().
                  mIsPlaying = false;
               * Stop track method
              public function stopTrack():void
                  channel.stop();
                  resetPlayer();
               * Method to change the position of the track
               * @param newPosition position is provided in milliseconds
              public function setTrackPosition(newPosition:Number):void
              //public function setTrackPosition(newPosition:Number, songUrl:String=null):void
                  /*if ( !mIsPlaying )
                      playTrack( songUrl, newPosition );
                      return;
                  channel.stop();
                  var currentPosition:Number = channel.position/1000;
                  var position:Number
                  if (newPosition<currentPosition)
                      position = newPosition*1000;
                  else
                      position = Math.min(sound.length, newPosition*1000);
                  channel = sound.play(position);
                  // [Added by BT 30/12/10] - sound.play(position) removes the SOUND_COMPLETE event listener.
                  channel.addEventListener(Event.SOUND_COMPLETE, trackCompleteHandler);
                  soundPosition.start();
               * Method to remove all listener and empty objecs once track stoped.
              protected function resetPlayer():void
               * Method to fast forward a track
               * @param timeInSeconds time to fast forward, default is 2 seconds
              public function fastforward(timeInSeconds:Number=2):void
                  setTrackPosition(timeInSeconds+currentPosition);
               * Method to rewind a track
               * @param timeInSeconds time to rewind, default is 2 seconds
              public function rewind(timeInSeconds:Number=2):void
                  setTrackPosition(currentPosition-timeInSeconds);
               * Method to adjust sound volume
               * @param vol volume in precentage between 0-1
              public function setVolume(vol:Number):void
                  mVolume = vol;
                  if (channel != null)
                      var transform:SoundTransform = new SoundTransform(vol);
                      channel.soundTransform = transform;
              public function getVolume():Number
                  return mVolume;
              public function isPlaying():Boolean
                  return mIsPlaying;
              //  Event handlers
               * Sends an event once the track position changed.
               * @param event
              protected function positionTimerHandler(event:TimerEvent):void
                  songPosition = Number((channel.position/1000).toFixed(2));
                  var totalPosition:Number = Number((this.sound.length/1000).toFixed(2));
                  if (songLength < totalPosition)
                      songLength = totalPosition;
                  if (songLength > 0 && songPosition > 0)
                      this.dispatchEvent( new PlayProgressEvent(songPosition, songLength) );
               * Download complete handler
               * @param event
              protected function downloadCompleteHandler(event:Event):void
                  sound.removeEventListener(Event.COMPLETE, downloadCompleteHandler);
                  sound.removeEventListener(ProgressEvent.PROGRESS, downloadProgressHandler);
                  this.dispatchEvent(new DownloadEvent(DownloadEvent.DOWNLOAD_COMPLETED, fileBytesTotal, fileBytesTotal));
               * ID3 information
               * @param event
              protected function id3Handler(event:Id3Event):void
                  this.dispatchEvent(event);
               * Method to handle io errors.
               * @param event
              protected function ioErrorHandler(event:Event):void
                  sound.removeEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
                  this.dispatchEvent(new PlayerEvent(PlayerEvent.PLAYER_ERROR, "Error loading music file, please check cross domain policy and that file exists."+event.toString()));
                  resetPlayer();
               * Progress handler
               * @param event
              protected function downloadProgressHandler(event:ProgressEvent):void
                  this.dispatchEvent(new DownloadEvent(DownloadEvent.DOWNLOAD_PROGRESS, event.bytesLoaded, event.bytesTotal));
                  fileBytesTotal = event.bytesTotal;
                  // check if ID3 information is avaliable, needed since id3 event doesn't always work correctly.
                  if (this.sound.id3.album != null || this.sound.id3.artist != null || this.sound.id3.songName != null || this.sound.id3.genere != null)
                      var evt:Id3Event = new Id3Event(this.sound.id3);
                      id3Handler(evt);
               * Track complete handler
               * @param event
              protected function trackCompleteHandler(event:Event):void
                  channel.removeEventListener(Event.SOUND_COMPLETE, trackCompleteHandler);
                  resetPlayer();
                  this.dispatchEvent(new PlayerEvent(PlayerEvent.TRACK_COMPLETED));
      Player:
          import flash.media.SoundLoaderContext;
          import flash.net.URLRequest;
           *  Dispatched while downloading a music file in progress
           *  @eventType com.elad.framework.musicplayer.events.DownloadEvent.DOWNLOAD_PROGRESS
          [Event(name="downloadProgress", type="com.nuance.nlportal.audioplayer.events.DownloadEvent")]
           *  Dispatched when music file was downloaded successfully
           *  @eventType com.elad.framework.musicplayer.events.DownloadEvent.DOWNLOAD_COMPLETED
          [Event(name="downloadCompleted", type="com.nuance.nlportal.audioplayer.events.DownloadEvent")]
           *  Dispatched when track playing is completed
           *  @eventType com.elad.framework.musicplayer.events.PlayerEvent.TRACK_COMPLETED
          [Event(name="playerError", type="com.nuance.nlportal.audioplayer.events.PlayerEvent")]
           *  Dispatched when there is an error playing a track
           *  @eventType com.elad.framework.musicplayer.events.PlayerEvent.PLAYER_ERROR
          [Event(name="trackCompleted", type="com.nuance.nlportal.audioplayer.events.PlayerEvent")]
           *  Dispatched while track progress playing
           *  @eventType com.elad.framework.musicplayer.events.PlayProgressEvent.PLAYER_PROGRESS
          [Event(name="playerProgress", type="com.nuance.nlportal.audioplayer.events.PlayProgressEvent")]
           *  Dispatched when data information is avaliable regarding a track
           *  @eventType com.elad.framework.musicplayer.events.ID3
          [Event(name="id3", type="com.nuance.nlportal.audioplayer.events.Id3Event")]
           * This class is the foundation for creating an audio music player.  The class includes all the methods needed such as
           * play, stop, pause as well as lunch event as the track is playing, downloading and catching track information.
           * @example The following example create a basic music player:
           * <listing version="3.0">
           *    <Script>
           *            import com.elad.framework.musicplayer.events.Id3Event;
           *            import com.elad.framework.musicplayer.events.PlayerEvent;
           *            import com.elad.framework.musicplayer.Player;
           *            import mx.events.SliderEvent;
           *            import com.elad.framework.musicplayer.events.DownloadEvent;
           *            import com.elad.framework.musicplayer.events.PlayProgressEvent;
           *            private var player:Player = new Player();
           *            private var songUrl:String;
           *            private function playSong():void
           *                player.addEventListener(PlayProgressEvent.PLAYER_PROGRESS, onPlayerProgress);
           *                player.addEventListener(DownloadEvent.DOWNLOAD_PROGRESS, onDownloadProgress);
           *                player.addEventListener(PlayerEvent.PLAYER_ERROR, onPlayerError);
           *                player.addEventListener(Id3Event.ID3, onTrackDataInformation);
           *                player.playTrack(songUrl);  // songLenght
           *            private function onTrackDataInformation(event:Id3Event):void
           *                songInfoText.text = event.id3.artist+" - "+event.id3.album;
           *            private function onPlayerProgress(event:PlayProgressEvent):void
           *                songSlider.value = event.playPosition;
           *                currentTimeText.text = Player.formatTimeInSecondsToString(event.playPosition);
           *                totalTimeText.text = Player.formatTimeInSecondsToString(event.total);
           *                songSlider.maximum = event.total;
           *            private function onPlayerError(event:PlayerEvent):void
           *                throw new Error(event.message);
           *            protected function dragStartHandler(event:SliderEvent):void
           *                player.removeEventListener(PlayProgressEvent.PLAYER_PROGRESS, onPlayerProgress);
           *            private function onDownloadProgress(event:DownloadEvent):void
           *                progressBar.setProgress(event.bytesLoaded, event.bytesTotal);
           *            protected function dragDropHandler(event:SliderEvent):void
           *                player.setTrackPosition(songSlider.value);
           *    </Script>
           *    <Text id="songInfoText" x="10" y="5" text="Artist - song name" />
           *    <HSlider id="songSlider" y="25" x="10" width="400" minimum="0" showTrackHighlight="true" liveDragging="true"
           *        thumbDrag="dragStartHandler(event)" thumbRelease="dragDropHandler(event)"/>
           *    <ProgressBar id="progressBar" y="45" x="15" width="390" height="1" minimum="0" maximum="100" labelWidth="0"
           *        direction="right" mode="manual"  />
           *    <Text y="45" x="420" text="Track Loader"/>
           *    <HBox y="30" x="420" horizontalGap="0">
           *        <Text id="currentTimeText" text="00:00"/>
           *        <Text text="/"/>
           *        <Text id="totalTimeText" text="00:00"/>
           *    </HBox>
           *    <HBox y="60" x="10" horizontalGap="12">
           *        <Button id="playButton" label="play" click="playSong();" enabled="false" />
           *        <Button label="pause" click="player.pauseTrack()" />
           *        <Button label="stop" click="songSlider.value=0; currentTimeText.text = '00:00'; player.stopTrack()" />
           *        <Button label="fastforward" click="player.fastforward();" />
           *        <Button label="rewind" click="player.rewind();" />
           *    </HBox>
           *    <FormItem y="90">
           *        <FormItem label="Music Url:" />
           *        <HBox>
           *            <TextInput id="textInput" width="200" height="20" text="http://www.YourServer.com"/>
           *            <Button label="Submit" click="this.songUrl=textInput.text; playSong(); playButton.enabled=true" />
           *        </HBox>
           *    </FormItem>
           * </listing>
           * @see flash.media.Sound
           * @see flash.net.URLRequest
           * @see flash.utils.Timer
           * @see com.elad.framework.musicplayer.IPlayer
           * @see com.elad.framework.musicplayer.AbstractPlayer
          public class Player extends AbstractPlayer implements IPlayer
              //  Constructor
              public function Player()
              //  Class methods
              override public function playTrack(songUrl:String, songLenght:Number=0):void
              //override public function playTrack(songUrl:String, newPosition:Number=0, songLenght:Number=0):void
                  if (mIsPause)
                      replay();
                      return;
                  if (mIsPlaying)
                      return;
                  songURL = songUrl;
                  songLength = Number((songLenght/1000).toFixed(2));
                  var request:URLRequest = new URLRequest(songUrl);
                  sound = new Sound();
                  var slc:SoundLoaderContext = new SoundLoaderContext;
                  slc.checkPolicyFile = true;
                  sound.addEventListener(Event.COMPLETE, downloadCompleteHandler);
                  sound.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
                  sound.addEventListener(ProgressEvent.PROGRESS, downloadProgressHandler);
                  sound.load(request, slc);
                  channel = sound.play();
                  var transform:SoundTransform = new SoundTransform(getVolume());
                  /*if ( newPosition != 0 )
                      channel.stop();
                      var position:Number
                      else
                  soundPosition = new Timer(50);
                  soundPosition.addEventListener(TimerEvent.TIMER, positionTimerHandler);
                  mIsPlaying = true;
              override protected function resetPlayer():void
                  this.mIsPause = false;
                  this.mIsPlaying = false;
                  soundPosition.removeEventListener(TimerEvent.TIMER, positionTimerHandler);
                  sound         = null;
                  channel       = null;
                  soundPosition = null;
               * Replay method used internally.
              private function replay():void
                  channel = sound.play(mPausePosition);
                  // [Added by BT 21/12/10] - sound.play(mPausePosition) removes the SOUND_COMPLETE event listener.
                  mIsPause = false;
               * Static method used to convert a time in seconds to the following format '0:00'.
               * @param time time in seconds
              public static function formatTimeInSecondsToString(time:Number):String
                  var retVal:String = "";
                  var timeString:String = (time/60).toFixed(2);
                  var timeArray:Array = timeString.split(".");
                  if (timeArray[1] == 60)
                      timeArray[0] += 1;
                      timeArray[1] -= 60;
                  var minutes:String = (timeArray[0].toString().length < 2) ? "0"+timeArray[0].toString() : timeArray[0].toString();
                  var seconds:String = (timeArray[1].toString().length < 2) ? "0"+timeArray[1].toString() : timeArray[1].toString();
                  retVal = minutes+":"+seconds;
                  return retVal;
      ISSUE
      With the code as is, I cannot drag the audio slider until after the Play button is pressed.  This functionality should be provided (as is the case for YouTube videos).  The problem is that the relevant components (Sound, Channel) are created only after Play is pressed.
      ATTEMPTED SOLUTIONS
      As you can see, I tried two solutions:
      1. In the AbstractPlayer.setTrackPosition method, I called playTrack at the beginning.  Unfortunately, the whole audio file gets played still.
      2. In the Player.playTrack method, I passed the new position as an argument.  I tried calculating the true new position after channel = sound.play().  However, it appears that, until the end of the method, sound.length is still 0.
      With the existing code, what changes do I need to make to be able to move the audio slider (i.e. change the current position of the audio file) without having to first press Play?  Either moving the slider would start playing the audio file, or moving the slider would just change the position and then this position can be passed to playTrack to properly calculate the new true position, is acceptable.
      Thank you for your insight and guidance!
      Bonnie
