25 Replies Latest reply on Jan 24, 2011 9:31 PM by kglad
    Server time
    Ron Colmen Level 2
      I'm trying to create a clock which shows the time returned by the server. Help me to get this code working with the server time on..
      (E.g.: time.php returns 1295532770)
      server = new LoadVars();
      server.onData = function (src){
      clock_txt.onEnterFrame = time;
      this.time = Number(src);
      server.load("http://www.me.com/time.php");
      var seconds = this.time/1000
      var minutes = this.time/60
      var hours = this.time/60
      if (hours<12) {
      ampm = "AM";
      else{
      ampm = "PM";
      while(hours >12){
      hours = hours - 12;
      if(hours<10)
      hours = "0" + hours;
      if(minutes<10)
      minutes = "0" + minutes;
      if(seconds<10)
      seconds = "0" + seconds;
      clock_txt.text = hours + ":" + minutes + ":" + seconds +" "+ ampm;
        • 1. Re: Server time
          you have some problems with logic but to start, there's nothing returned from the php file.  use the trace function or a textfield to confirm.
          • 2. Re: Server time
            Ron Colmen Level 2
            Thanks.
            trace (this.time);
            outputs
            1295554175
            1295554175
            1295554176
            1295554176
            1295554176
            1295554176
            • 3. Re: Server time
              then use:
              var tl:MovieClip=this;
              var startTime:Number;
              tl.timeMS = Number(src);
              startTime=getTimer();
              clock_txt.onEnterFrame = timeF;
              function timeF(){
              var d:Date = new Date(tl.timeMS+getTimer()-startTime);
              if(d.getHours()>12){
              var hours:Number=d.getHours()-12;
              var ampm:String = "pm";
              } else if(d.getHours()==12){
              hours=12;
              ampm="pm"
              } else {
              hours=d.getHours();
              ampm="am";
              var hoursS:String = formatS(hours.toString());
              var minutes:String = formatS(d.getMinutes().toString());
              var seconds:String = formatS(d.getSeconds().toString());
              function formatS(s:String):String{
              while(s.length<2){
              s="0"+s;
              return s;
              • 4. Re: Server time
                Ron Colmen Level 2
                Thanks Kglad but nothing seems to appear.
                • 5. Re: Server time
                  then you don't have a textfield with visible text or you onData() method isn't being called.  use the trace() function or a textfield to see which it is.
                  • 6. Re: Server time
                    Ron Colmen Level 2
                    trace(tl.timeMS);
                    Outputs
                    1295568130
                    Also as you suggested I inserted a new dynamic text box with an instance name of clock_txt. But nothing is displayed.
                    • 7. Re: Server time
                      enable the border of your textfield.  can you see it when you test?  if not, you need to embed your font, check visible, check alpha.  if yes, check that the font color is different from the background and there's no textfield restriction.
                      • 8. Re: Server time
                        Ron Colmen Level 2
                        enable the border of your textfield.  can you see it when you test?  - YES
                        ...if yes, check that the font color is different from the background - YES IT IS.
                        ... and there's no textfield restriction - NO.
                        Strange. I wonder if there's something wrong in the code then?
                        trace(tl.timeMS);
                        function timeF(){
                        hours=12;
                        ampm="pm"
                        } else {
                        hours=d.getHours();
                        ampm="am";
                        clock_txt.text = hoursS + ":" + minutes + ":" + seconds +" "+ ampm;
                        while(s.length<2){
                        s="0"+s;
                        return s;
                        • 9. Re: Server time
                          if something were wrong with the code you'd still see something in the textfield even if it's undefined:undefined:undefined:undefined
                          but you can always test with:
                          clock_txt.text = "this is a test";
                          • 10. Re: Server time
                            Ron Colmen Level 2
                            clock_txt.text = "this is a test"; shows "this is a test";
                            But it's empty for the clock code. also when I did a trace for the following all those were empty.
                            trace (hours);
                            trace (minutes);
                            trace (seconds);
                            trace (ampm);
                            trace (d);
                            • 11. Re: Server time
                              are you testing locally?  do you get a return from that php when testing locally?  if yes and yes, copy the first several lines of your output panel after using:
                              function timeF(){
                              trace("timeMS "+tl.timeMS);
                              hours=12;
                              ampm="pm"
                              } else {
                              hours=d.getHours();
                              ampm="am";
                              trace("hours "+hours);
                              trace("hourS "+hourS);
                              trace(clock_txt+" "+clock_txt.text);
                              while(s.length<2){
                              s="0"+s;
                              return s;
                              • 12. Re: Server time
                                Ron Colmen Level 2
                                With that code nothing is been output.
                                but when I did this
                                the OUTPUT was
                                timeMS 1295689620
                                • 13. Re: Server time
                                  clock_txt is not a movieclip.  an onEnterFrame method can only be applied to a movieclip.  fix that.
                                  • 14. Re: Server time
                                    Ron Colmen Level 2
                                    oh ok. But still the time doesn't show up.
                                    function timeF(){
                                    OUTPUT
                                    timeMS 1295694898
                                    hours 5
                                    hourS undefined
                                    _level0.clock_txt 05:24:54 am
                                    timeMS 1295694898
                                    hours 5
                                    hourS undefined
                                    timeMS 1295694898
                                    hours 5
                                    hourS undefined
                                    _level0.clock_txt 05:24:55 am
                                    timeMS 1295694898
                                    hours 5
                                    hourS undefined
                                    timeMS 1295694898
                                    hours 5
                                    hourS undefined
                                    • 15. Re: Server time
                                      remove all the trace() statements.
                                      the code is working as expected.  clock_txt.text is correct.
                                      • 16. Re: Server time
                                        Ron Colmen Level 2
                                        oh! it works!!!
                                        Thank you very much Kglad.
                                        • 17. Re: Server time
                                          you're welcome.
                                          • 18. Re: Server time
                                            Ron Colmen Level 2
                                            There's something strange happening. Each time I open the swf the time starts from 5:28:01am? Why isn't it displaying the time returned by the server?
                                            • 19. Re: Server time
                                              use the trace() function to see if the number returned from the server changes.
                                              • 20. Re: Server time
                                                Ron Colmen Level 2
                                                yes, each time the number returned from the php changes to a higher value. but all ways the time starts at 05:29:11am
                                                trace (tl.timeMS);
                                                OUTPUT E.g.
                                                1295951360
                                                trace (tl.timeMS);
                                                server.load("http://www.myweb.com/time.php");
                                                function timeF(){
                                                hours=12;
                                                ampm="pm"
                                                } else {
                                                hours=d.getHours();
                                                ampm="am";
                                                _root.clock_txt.clock_txt.text = hoursS + ":" + minutes + ":" + seconds +" "+ ampm;
                                                while(s.length<2){
                                                s="0"+s;
                                                return s;
                                                • 21. Re: Server time
                                                  what exactly is returned by time.php?
                                                  • 22. Re: Server time
                                                    Ron Colmen Level 2
                                                    the time in miliseconds.
                                                    <?php
                                                    $tz =  new DateTimeZone('Europe/Warsaw');
                                                    $date = new DateTime('now', $tz);
                                                    $gettime = strtotime($date->format('Y-m-d H:i:s'));
                                                    echo ($gettime);
                                                    • 23. Re: Server time
                                                      it looks more like it's returning seconds, not ms.   try:
                                                      trace (tl.timeMS);
                                                      function timeF(){
                                                      var d:Date = new Date(tl.timeMS*1000+getTimer()-startTime);
                                                      hours=12;
                                                      ampm="pm"
                                                      } else {
                                                      hours=d.getHours();
                                                      ampm="am";
                                                      while(s.length<2){
                                                      s="0"+s;
                                                      return s;
                                                      • 24. Re: Server time
                                                        Ron Colmen Level 2
                                                        Thanks Kglad!
                                                        • 25. Re: Server time
                                                          you're welcome.
