4 Replies Latest reply on Jan 20, 2011 11:21 AM by abhinav1singhal
    Filter function problem in Tree
    abhinav1singhal Level 1
      Hi All,
      In the below code, I am trying to put filter function on parent. Now if I type "Ratings" and then again clear the search. the Bottom node gets lost. Please let me know ho can I retin the bottom node. Please note that bottom node also contains "Rating" wth one less "s".
      here is the code.
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
      viewSourceURL="
      srcview/index.html"
      creationComplete="init()"
      <mx:Script>
      <![CDATA[
      import vo.Person;
      import mx.collections.ArrayCollection;
      private function init():void{
      var person1:Person=new Person("Parent");
      var person2:Person=new Person("Watch Status");
      var chilPerson:Person=new Person("Ratings");
      var childPersion2:Person=new Person("rating");
      person1.children=
      new ArrayCollection([chilPerson]);
      person2.children=
      new ArrayCollection([childPersion2]);
      people.addItem(person1);
      people.addItem(person2);
      personsTree.dataProvider=people;
      Bindable]
      private var people:ArrayCollection = new ArrayCollection();
      private function refreshData():void{
      for (var i:int=0;i<this.people.length;i++){
      //reset the root node to its original unfiltered data
      people[i].children =
      new ArrayCollection(people[i].children.source);
      //start the recursion at the root node
      refreshRecursiveChildren(people.source[i]);
      //update the Tree after the data has been filtered
      personsTree.invalidateList();
      people.filterFunction=filterData;
      people.refresh();
      //end refreshData function
      private function refreshRecursiveChildren(person:Person):void{
      if(person.children){
      //loop through each child and filter its children
      for each(var _person:Person in person.children.source){
      refreshRecursiveChildren(_person);
      //reset each "children" ArrayCollection to its original unfiltered data
      person.children =
      new ArrayCollection(person.children.source);
      //set the filterfunction for the newly updated node
      person.children.filterFunction = filterData;
      //run the fitlerFunction
      person.children.refresh();
      //end refreshRecursiveChildren function
      public function filterData(item:Object):Boolean{
      //get the string to filter the nodes by
      var searchString:String = iNameFilter.text;
      //if string is found in node return true.
      //since the recursive filtering takes place from bottom up, if
      //a collection still has children after filtering, also return true
      if(searchString.length == 0 || item.name.toLowerCase().indexOf(searchString.toLowerCase()) >= 0)
      return true;
      else if(item.children != null && item.children.length > 0)
      return true;
      return false;
      //end filterData function
      </mx:Script>
      <mx:VBox width="200" height="300" paddingTop="10" paddingBottom="10" paddingLeft="5" paddingRight="5">
      <mx:Tree id="personsTree" dataProvider="{people}" labelField="name" width="100%" height="100%" />
      <mx:HBox>
      <mx:Label text="Filter the Tree:" />
      <mx:TextInput id="iNameFilter" change="refreshData()" />
      </mx:HBox>
      </mx:VBox>
      </mx:Application>
      Below is the Action script packge
      package
      vo{
      public class Person{
      public var name:String;
      public var children:ArrayCollection;
      public function Person(_name:String, _children:ArrayCollection = null){
      this.name = _name;
      if(_children != null)
      this.children = _children;
      //end Person constructor
      //end Person class
      //end package declaration
      Regards,
      Abhinav
        • 1. Re: Filter function problem in Tree
          Flex harUI Adobe Employee
          Tree does not support filters in the heirarchy.
          This post may contain useful tidbits:
          https://blogs.adobe.com/aharui/2008/12/tree_and_lazy_or_paged_data_1.html
          One of the tricks to trying to get this to work may involve a custom
          ITreeDataDescriptor.  You want to make sure the ArrayCollections the tree
          uses for the children are the same ones in your data structure.
          • 2. Re: Filter function problem in Tree
            As you can see I am using Array collection. Do you know any sample for the same? or canyou tweak this code to use ITreeDataDescriptor?
            Regards,
            Abhi.
            • 3. Re: Filter function problem in Tree
              I understand you are using ArrayCollection, but I would double-check to make
              sure the datadescriptor.getChildren() is returning the child AC.
              I don't have the bandwidth to debug your test case right now, especially
              since filtering isn't supported.  Maybe someone else on the forum will help.
              • 4. Re: Filter function problem in Tree
                Hi ,
                I was able to fix this issue for my purpose. Below is the code that beeds to be chnaged to.
                private
                this.people=new ArrayCollection(this.people.source);
                people.refresh();
                this.callLater(expandAllAvailable);
                Basically, I am reassigning the arraycollection to its source whenever a new character is typed in. This will do a proper filtering to complete new arrayCollection.
                Thanks for your prompt responses so far. I really appreciate it.
                Regards,
                Abhinav
