2 Replies Latest reply on Jan 20, 2011 1:52 PM by chris.campbell
    SELECT COUNT(*)  bug
    Kristin95762
      I have a table named comments, with a column labeled book_id. In this column I have non-unique integer values (we'll say 2 rows contain the number 9)
      import flash.events.*;
      import flash.data.*
      import fl.controls.ComboBox;
      import flash.filesystem.File
      //Open database-------------------------------------------------------------
      var conn:SQLConnection = new SQLConnection();
      conn.addEventListener(SQLEvent.OPEN, openHandler);
      var dbFile:File = File.desktopDirectory.resolvePath("tarot.db");
      conn.openAsync(dbFile);
      //authorsCB.addEventListener(Event.CHANGE, loadBooks);
      function openHandler(event:SQLEvent):void
      var selectStmt:SQLStatement = new SQLStatement();
      selectStmt.sqlConnection = conn;
      // define the SQL text
      selectStmt.text = "SELECT COUNT(*) FROM comments2 WHERE book_id = 9";
      // register listeners for the result and failure (status) events
      selectStmt.addEventListener(SQLEvent.RESULT, readResultHandler);
      // execute the statement
      selectStmt.execute();
      // collect author data: author name and author ID. Populate authorCB with author name. authorID is used to match publications for the booksCB in the loadBooks() function
      function readResultHandler(event:SQLEvent):void
      var result:SQLResult = event.target.getResult();
      var numResults:int = result.data.length;
      for (var i:int = 0; i < numResults; i++)
      var row:Object = result.data[i];
      var bookID:uint = row.book_id;
      var book:String = row.book;
      var authorID:uint = row.author_id;
      //combo box named authorsCB
      authorsCB.addItem({label:bookID}); //assign table data to list box
      addChild(authorsCB);
      This code returns '0' even though my table contains two matching rows.
      If I change my select statement to "SELECT * FROM comments WHERE book_id = 9", that works.
      I'm trying to implement a query that will tell me if a particular value appears in this column. If that value appears in the table, then I want to run another query to extract the associated data.
      Ultimately I'm loading combo box 1 with author names, and combo box 2 with book titles. I then want to run a 3rd query against my comments table. My comments table contains notes about the various books, but I don't have notes about every title, so I need to test if there are comments in the table before I try to extract those comments in order to avoid throwing an error.
        • 1. Re: SELECT COUNT(*)  bug
          Kristin95762 Level 1
          Okay, I got it.
          It's very difficult to find documentation on precisely HOW Adobe AIR implements some of the more obscure functions in SQLite. Even though SELECT COUNT(*) works in the Firefox SQLite Manager, it doesn't work the same way in AIR.
          Through reviewing  the COUNT(*) function in "Learning SQL" by O'Reilly, there was an example utilized in which you point to the column you want counted BEFORE the COUNT(*) function.
          So, it becomes:
          SELECT columnName, COUNT(*)  someColumnName (optional) FROM someTable etc, etc.
          After the FROM clause you could use a WHERE, or a GROUP BY.
          Keep in mind that a GROUP clause runs after a WHERE clause.
          • 2. Re: SELECT COUNT(*)  bug
            chris.campbell Adobe Employee
            Thanks for following up and posting your solution!
            Chris
