2 Replies Latest reply on Jan 21, 2011 3:47 AM by longo69115
    Is it possible to generate a Screenshot from VideoDisplay Component?
    longo69115
      Hi Everybody,
      Is there a way to generate a screenshot from a video which is played in the VideoDisplay Component? We want to show a video and put some buttons over it after it is finished. That it all look good, we thought about the last frame from the video as a background image. Any suggestions? Or maybe waiting for Flash Builder 5?!
        • 1. Re: Is it possible to generate a Screenshot from VideoDisplay Component?
          MDubbs
          Call this function with your component and use the returned image.
          private function generateBitmap(component:UIComponent):Image {
          var width:Number = component.width;
          var height:Number = component.height;
          var bitmapData:BitmapData = new BitmapData(width, height, true, 0);
          bitmapData.draw(component);
          var image:Image = new Image();
          image.source = bitmapData;
          image.setActualSize(width, height);
          image.includeInLayout =
          false;
          image.cacheAsBitmap =
          true;
          image.x = component.x;
          image.y = component.y;
          image.alpha = component.alpha;
          return image;
          • 2. Re: Is it possible to generate a Screenshot from VideoDisplay Component?
            longo69115 Level 1
            Hi MDubbs,
            I tried your code, but it didn't work for me. The source from the *var image* was always [object BitmapData].
            I checked around and found the ImageSnapshot and the BitmapDrawable class which are made for that purpose.
            private function generateBackgroundImage(comp:IBitmapDrawable):void
                 var imageSnap:ImageSnapshot = ImageSnapshot.captureImage(comp);
                 var array:ByteArray = imageSnap.data as ByteArray;
                 AnswerBackgroundImage.source = array;      //Image-Component of the application
            This works, but it takes some time (1-2sec). Was your solution faster?
