2 Replies Latest reply on Jul 30, 2011 12:51 PM by leonardohelman
    Flex Build using Maven with org.sonatype.flexmojos is failing
    Pstalwalkflex
      I am trying to create and build a flex library project (.swc) using maven .
      I am able to create directory structure but build is failing.
      Maven version : apache-maven-3.0.2
      Ø  mvn  archetype:generate
      -DarchetypeGroupId=org.sonatype.flexmojos
      -DarchetypeArtifactId=flexmojos-archetypes-library
      -DarchetypeVersion=3.8
      -DgroupId=com.testing
      -DartifactId=sampleflexproject2 –e
      This created the basic project skeleton as per my need.
      Ø  mvn clean install –e –X ,
      I get below exception while executing.  (I could see my local repo is getting build as well.)
      [ERROR] Failed to execute goal org.sonatype.flexmojos:flexmojos-maven-plugin:4.0
      -pre-alpha-1:compile-swc (default-compile-swc) on project sampleflexproject2: Th
      e parameters 'output' for goal org.sonatype.flexmojos:flexmojos-maven-plugin:4.0
      -pre-alpha-1:compile-swc are missing or invalid -> [Help 1]
      org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal o
      rg.sonatype.flexmojos:flexmojos-maven-plugin:4.0-pre-alpha-1:compile-swc (defaul
      t-compile-swc) on project sampleflexproject2: The parameters 'output' for goal o
      rg.sonatype.flexmojos:flexmojos-maven-plugin:4.0-pre-alpha-1:compile-swc are mis
      sing or invalid
              at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor
      .java:221)
      .java:153)
      .java:145)
              at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProje
      ct(LifecycleModuleBuilder.java:84)
      ct(LifecycleModuleBuilder.java:59)
              at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBu
      ild(LifecycleStarter.java:183)
              at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(Lifecycl
      eStarter.java:161)
              at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:319)
              at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
              at org.apache.maven.cli.MavenCli.execute(MavenCli.java:534)
              at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
              at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
              at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
              at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
      java:39)
              at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
      sorImpl.java:25)
              at java.lang.reflect.Method.invoke(Method.java:585)
              at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Laun
      cher.java:290)
              at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.jav
      a:230)
              at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(La
      uncher.java:409)
              at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:
      352)
      Caused by: org.apache.maven.plugin.PluginParameterException: The parameters 'out
      put' for goal org.sonatype.flexmojos:flexmojos-maven-plugin:4.0-pre-alpha-1:comp
              at org.apache.maven.plugin.internal.DefaultMavenPluginManager.validatePa
      rameters(DefaultMavenPluginManager.java:688)
              at org.apache.maven.plugin.internal.DefaultMavenPluginManager.populatePl
      uginFields(DefaultMavenPluginManager.java:580)
              at org.apache.maven.plugin.internal.DefaultMavenPluginManager.getConfigu
      redMojo(DefaultMavenPluginManager.java:525)
              at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(Default
      BuildPluginManager.java:98)
      .java:209)
      Do you foresee any obvious  issue in this ? I am building flex project using maven first time.
