3 Replies Latest reply on Jul 11, 2007 2:49 AM by Nightfall_Blue
    database connection in CF8b
    Nightfall_Blue
      Are there any Vista and CF8b issues that would prevent CF connections to SQL2005. For some reason they wont connect. Ive had a SQL Dba look into the settings I gave SQL2005, which he's tested with an ODBC data source which worked. I know others have had the same issue but I guess they've been able to get through them whereas I cant
      Ive Enabled the TCP/IP and named pipes for the instance of SQL server etc.... Yet for some reason the 'data sources pages' in CF administrator will not connect. No matter how we jiggle about with the Server and port settings.
      Ive even used the ODBC connections that were tested by the dba (as ODBC socket) and they worked in the datasources page but failed in the application... the table name comes up as an invalid object name..
      I saw Ben Forta has highlighted some issues with IPv6 and CF8 but I'm not sure how to make this work still. If my machine is called MOLLY and my instance of SQL server is called VAIO_VEDB... what goes int he server field ? MOLLY /VAIO_VEDB.. 127.0.0.1/VAIO_VEDB .. [my internal IP]/VAIO_VEDB ??
        • 1. Re: database connection in CF8b
          ksmith Level 1
          The server is the machinename itself. So connecting to a local MSSQL server and a database named breeze, I use:
          Database - breeze
          Server - localhost
          And it works.
          Simplest way to start debugging a datasource issue is to create the datasource. Even if it fails to verify continue by creating a test cfm with any query using that DSN. Do a simple "select * from foo". Run the template with debugging and verbose error info on. Come back with the error if you cannot figure the problem out from there.
          • 2. Re: database connection in CF8b
            Nightfall_Blue Level 1
            Well, thats what I d normall do but its not working. all sorts of error messages
            server is my local machine so I'm using localhost, port 1433.. etc but no. not under CF8
            • 3. Re: database connection in CF8b
              SOLVED.... This may be of interest for those considering tinkering with CF8.
              tried all the normal settings. I was connecting to a duplicate of the db as my CF7 machine. so I knew all settings were correct... just wouldnt connect on my CF8 machine.. So I tried everything I could and got an array of error messages... until I noticed login failed for user sa.., 3rd from the bottom.
              so I corrected the password and it worked, went back in tried to verify and it failed. it seems to reset the password every time you visit the DSN configuration page. Is it just me and has this always happened, or is this a new feature of CF8 :-)
              CF Data Source Name : DSNNAME
              Database : database_name
              Server : 127.0.0.1
              Port : 1433
              User name: sa
              Password : **********
              Error establishing socket to host and port: 127.0.0.1:1433. Reason: Connection refused: connect.
              Server : ::1
              Port : 1433
              User name: sa
              Error establishing socket to host and port: 1:1433. Reason: Network is unreachable: connect.
              Server : localhost
              Port : 1433
              User name: sa
              Error establishing socket to host and port: localhost:1433. Reason: Connection refused: connect.
              Server : COMPUTERNAME\SQLSERVERINSTANCENAME
              Port : 1433
              User name: sa
              Login failed for user 'sa'..
              Server : SQLSERVERINSTANCENAME
              Port : 1433
              User name: sa
              Error establishing socket. Unknown host: SQLSERVERINSTANCENAME
              Port : 1433
              User name: sa
              coldfusion.sql.Executive$ConnectionVerificationFailedException: java.sql.SQLException: Timed out trying to establish connection.
