I have searched around the forums and it seems I may be in the wrong area with this thread that I found (http://forums.adobe.com/thread/38858) but I have been unable to find a way to get to the developer side of things. If someone can direct me it would be great but if you have an answer even better 🙂
I have integrated WebHelp with our web application and can successfully launch context-sensitive help by itself. When I want to display a TOC, index or search with it, it seems I can only display the default topic and not the context sensitive one.
Successful: RH_ShowHelp(0, 'help/en-us/WebHelp/Index.htm>helpWin', HH_HELP_CONTEXT, 42);
Fail: RH_ShowHelp(0, 'help/en-us/WebHelp/Index.htm>helpWin', HH_DISPLAY_TOC, 42);
I have been around the internet and found various sites that talk about how it is not possible to have a TOC show anything but the default topic and it just seems a bit off that this is not possible. I have also found sites mentioning some hacks to the javascript files but it seems that that was for older versions of RoboHelp.
I am currently using WebHelp generated by RoboHelp 8. If anyone can help or at least direct me to a forum where I can get this question answered, it would be greatly appreciated.
Thank you 🙂
Matt
Welcome to our community, Matt
Have you looked at the link below?
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Nope. Will go there now!
Thanks 🙂
Matt
So I will semi-retract my nope and replace it with I saw part of it 🙂 I had found Tyler's article yesterday and had already heard back from him. I had attempted the Topic ID approach with no luck and have yet been unsuccessful with some of his other suggestions. I'm not giving up though! 🙂 If I do find an answer, I will repost it here (or a link to it).
If anyone else has any input, please add a reply!
Matt
So I did find my answer thanks to Tyler at a sub-link where you pointed me to Rick. I was implementing it with a bit of confusion from the RH_ShowHelp. I was using TopicID instead of TopicNumber so by changing one keyword, all was good 🙂 Also helps that Visual Studio 2010 allows javascript debugging 😉
HRef = "help/en-us/WebHelp/Index_csh.htm#TopicNumber=42,withnavpane=true"
I am, however, going to implement the TopicID way within my code when all is said and done. It provides much better readability.
Thanks!
Matt
