1 Reply Latest reply on Jul 18, 2006 4:07 PM by Newsgroup_User
    Flash list and variables
    Neokase
      Recently I discovered how to load multiple variables into a dynamic textbox using buttons. I'm wondering if I can do the same thing only with a list component.
      Here is the coding for the buttons
      myData = new LoadVars();
      myData.onLoad = function(){
      myText_txt.htmlText = this.myVariable;
      myData.load("myText1.txt");
      b1.onRelease = function() {
      myText_txt.text = _root.myData.myVariable;
      b2.onRelease = function() {
      myText_txt.text = _root.myData.myVariable2;
      Here is the coding I was trying with the list component of course it does not work
      myDP = new Array(
      {label:"myLabel1", data:"myVariable1"},
      {label:"myLabel2", data:"myVariable2"}
      ClistBox.dataProvider = myDP;
      function change(evt) {
      var mySelectedData = evt.target.selectedItem.data;
      myText_txt.text.load(mySelectedData);
      this.ClistBox.addEventListener("change", this);
      Any help would be greatly appreciated. Thanks
        • 1. Re: Flash list and variables
          Level 7
          No need to use an Array if you are adding items to a listBox.
          myLabel1 = "some label";
          myVariable1 = "some data";
          ClistBox.addItem({label:myLabel1, data:myVariable1});
          Dan Mode
          *THE online Radio* http://www.tornadostream.com
          *Must Read* http://www.smithmediafusion.com/blog
          *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
          "Neokase" <webforumsuser@macromedia.com> wrote in message
          news:e9j3o9$q6a$1@forums.macromedia.com...
          > textbox
          > component.
          > not
          > work
          > myDP = new Array(
          > {label:"myLabel1",
          > {label:"myLabel2",
          > data:"myVariable2"}
