3 Replies Latest reply on Jan 22, 2011 8:49 PM by $Nith$
    Insert Node into XML using XPATH
    Rob_RH Level 1
      I'm having problems inserting a node into a XML. After getting some attributes from the CRC result i'd like to store them in a temp xml variable.
      After that the parent node of the attributes should be inserterd in a goal XML with a repeating node structure.
      Whats the right way to set a node to a certain position in the goal XML?
      Now the only thing i'm getting is erros about transaction:
      Caused by: javax.resource.ResourceException: Transaction is not active: tx=TransactionImple < ac, BasicAction: a307d1e:fd15:4d35c503:1351f50 status: ActionStatus.ABORT_ONLY >
          at org.jboss.resource.connectionmanager.TxConnectionManager.getManagedConnection(TxConnectio nManager.java:304)
          at org.jboss.resource.connectionmanager.BaseConnectionManager2.allocateConnection(BaseConnec tionManager2.java:396)
      Etc..
      Thx!
