12 Replies Latest reply on Aug 20, 2012 11:36 PM by Marcus Murphy
    Main difference between raid3 and raid5.
    thegt1 Level 1
      Hi guys, i've been doing quite a bit of reading on the topic of hard drive setup. And the one thing that is odd to me is the amount of controller cards that allow you to use raid5 and not raid3. My future system will have 6 disks, and really can't tell what is going up, but it seems like raid 3 is a dying implementation.
      Can ham or anyone be so kind to explain to me what is the main difference between this 2 configurations. thanks in advance.
        • 1. Re: Main difference between raid3 and raid5.
          Harm Millaard Level 7
          Look here: Adobe Forums: To RAID or not to RAID, that is the...
          Basically the difference is dedicated parity (3) versus distributed parity (5).
          Controller cards for raid3 are more difficult to make than raid5 controllers. Only Areca makes them.
          • 2. Re: Main difference between raid3 and raid5.
            Jim_Simon Level 9
            The second difference, resulting from the first, is that if a drive ever fails, a RAID 3 will keep most of it's performance during a rebuild, whereas a RAID 5 will slow down noticeably, possibly to the point where you couldn't edit while it was being rebuilt.
            The third difference is that with large file sequential reads/writes (which is what video is all about), RAID 3 is faster than a RAID 5.
            • 3. Re: Main difference between raid3 and raid5.
              thegt1 Level 1
              Thanks harm and jim for the explanation, things are a lot clear now.
              • 4. Re: Main difference between raid3 and raid5.
                ECBowen Most Valuable Participant
                The performance drop during rebuild is not nearly as bad as described or as bad as it use to be if you have an Enterprise Level Raid controller instead of the onboard. Background rebuild and initialization lets you decide what % of the controller cpu is set to rebuild and what is set to operations. By default that is 20% to rebuild which is very little overhead on the card. Rarely are you using over 80% of the card's cpu during operations. I have a client who records from 14 different security cams on a 5 drive raid 5. These security cams are constantly starting and stopping based on motion. The stream being recorded is H264 or motion jpeg. The raid handles that load without issue while rebuilding since they had a drive failure.
                The drive performance is correct for sequential files but it's not nearly as significant anymore with the changes to the way raid 5 is handled by the controller. Raid 5 arrays give you good performance for asyncronous or syncronous file operations. Overall it's the cost involved and tha raid 5 controllers are cheaper. Raid 6 is also better security and gives you close to the same performance as raid 5. You may want to consider that as well.
                Eric
                ADK
                • 5. Re: Main difference between raid3 and raid5.
                  thegt1 Level 1
                  So in terms of pure performance Only, let's say in a 6 disk setup ( c= os, apps one 300 gb / d = media, projects, pagefile, etc....   5 x 2tb seagate ) the speed of the system will be just about egual, or more than 20%.
                  To be honest if i can save some money in this build i'll take it.
                  • 6. Re: Main difference between raid3 and raid5.
                    Jim_Simon Level 9
                    Any chance you have some published benchmarks, Eric?  The one's I've seen show a different story (RAID 3 being significantly faster than RAID 5 on the same card), but they are a bit old.  Things may well have changed, and I'd love to see some new benchmarks.
                    • 7. Re: Main difference between raid3 and raid5.
                      JCschild Level 3
                      very little difference in performance if any now, 3 is too costly for what little
                      gains you may have.
                      guess we have to run some benchmarks again.
                      Scott
                      ADK
                      • 8. Re: Main difference between raid3 and raid5.
                        3 is too costly for what little gains you may have.
                        Why is that? The overhead in terms of disks is the same as 5, so there is no extra cost there. Controllers from Adaptec, Atto, 3Ware and Areca do not differ much in price (12+ port versions) and often Areca is a little bit less expensive, so there is no cost diference there either.
                        One thing that is a distinct and clear advantage of Areca over other controllers is the ability to expand the cache memory to 4 GB, where all the other brands are limited to 512 MB.
                        • 9. Re: Main difference between raid3 and raid5.
                          The controllers we use most of the time do not support raid 3 so I can't verify the 2 raids on the same controller. I compare benchmarks reported by others with raid 3 to the Intel with raid 5 and the results are not that far apart. These benchmarks were run when the Intel card when they first released. The performance now is better after optimizations.
                          Average transfer rate. Burst was over 1000mb/s
                          Intel SAS RS2PI080 8 Port controller with 512 DDR2 Ram
                          8X WD VelociRaptor 600 GB, SATA 6 Gb/s, 32 MB Cache, 10,000 RPM
                          8 Drive Raid 5 - 745MB/s read 735MB/s Write
                          8X WD 1TB SATA 6 Gb/s, 64 MB Cache, 7200 RPM
                          8 Drive Raid 5 - 703.8MB/s read 670MB/s Write
                          Revised: Sorry for some reason the last part of the copy kept getting cut off
                          Eric
                          ADK
                          • 10. Re: Main difference between raid3 and raid5.
                            JCschild Level 3
                            HI Harm,
                            the onboard ram has little to do with large file transfer once loaded its loaded. the onboard ram is about high transaction iops.
                            (server style multiple request). not video editing.
                            so added ram is a moot point in large file transfer, unless you do the no no of having your drives more than 60% full then it comes into play again.
                            you left out Intel.
                            12+ ports? now you are in the less than 5% of adobe users at best.
                            8 port cards are what most would buy. (also in the minority)
                            cheapest 8 port Sata 600 Areca $1049  (only one that does raid 3) ever wonder why?
                            Atto even more in the $1200 range.
                            3 ware $1269
                            i wouldnt touch adaptec at this point..
                            Intel $569
                            so thats $480 more for a 8 port controller that does raid 3
                            now in all fairness we have not benchmarked a SATA 600 Areca. last tests we did were with an Areca sata 300 (still have it here)
                            vs other sata 300 cards. (Intel, 3Ware, Atto)
                            but when we did the $480 gained you nothing..
                            Scott
                            • 11. Re: Main difference between raid3 and raid5.
                              Jim_Simon Level 9
                              Please post if you guys ever get that done.  I'd be interested.
                              • 12. Re: Main difference between raid3 and raid5.
                                Marcus Murphy Level 1
                                Now that the Areca ARC-1882i cards are around $600, would you guys be interested in revisiting the RAID5/6 vs RAID3 benchmarks?
                                The comparable Intel RS25DB080 is similarly priced except that Intel cards are unable to do RAID3 (nothing new).
                                Thanks!
