4 Replies Latest reply on Jun 26, 2007 11:22 AM by kglad
    setProperty doesn't work with movieclip inside of movieclip
    BigdaddyVELTRI
      I originally had this set up this way and it worked.
      var hita:Boolean = false;
      logotop.onEnterFrame = function() {
      hita = this.hitTest(this._parent.middle.hitme);
      if (hita == true) {
      setProperty ("logotop", _alpha, "0");
      Then I put everything in a new movieclip with the instance name "printme".
      Now it doesn't work and doesn't give me an error.
      printme.logotop.onEnterFrame = function() {
      hita = this.hitTest(this._parent.printme.middle.hitme);
      if (hita == true) {
      setProperty ("printme.logotop", _alpha, "0");
      Do you see anything wrong with the above code?
        • 1. Re: setProperty doesn't work with movieclip inside of movieclip
          remove the quotes around printme.logotop.
          • 2. Re: setProperty doesn't work with movieclip inside of movieclip
            Level 7
            BigdaddyVELTRI,
            > "printme".
            Okay, if I'm following you right, the "point of view" now is inside
            printme, right?
            So at this point, you're assigning a function to the
            MovieClip.onEnterFrame event of the logotop MovieClip instance (i.e., movie
            clip symbol) that exists inside printme.
            In this line, you're invoking MovieClip.hitTest() on the logotop
            instance and passing it the expression this._parent.printme.middle.hitme.
            Let's examine that a bit. In this context, the global "this" property
            refers to logotop, because that's how event handlers of this sort work in
            ActionScript 2.0. this._parent refers to the timeline or object that
            contains logotop; namely, printme. So this._parent.printme is possibly a
            problem. Does the printme movie clip contain within it another movie clip
            also instance named printme? If so, then this._parent.printme would indeed
            point to that inner printme (a sibling of logotop). If this isn't your
            aim -- if, say, middle is the sibling of logotop -- you may want to adjust
            the expression in that parameter.
            > if (hita == true) {
            The setProperty() function is actually pretty old. It was replace many
            versions ago with the (to my thinking) easier dot notation you're already
            using elsewhere in this script.
            The expression:
            ... is the same as this:
            printme.logotop._alpha = 0;
            Much easier to read and deal with, right? In fact, that may even help
            you sort out your pathing issue.
            David Stiller
            Co-author, Foundation Flash CS3 for Designers
            http://tinyurl.com/2k29mj
            "Luck is the residue of good design."
            • 3. Re: setProperty doesn't work with movieclip inside of movieclip
              BigdaddyVELTRI Level 1
              Thank you both for your help!
              This worked:
              hita = this.hitTest(printme.middle.hitme);
              if (hita == true) {
