New to his place so I hope I'm in the right place.
When downloading updates for CS5 I receive a message to 'close dynamiclinkmanager.exe'. Where is it and how do I exit it?
Start the Task Manager and check the Processes tab looking for dynamiclinkmanager.exe.
When you found it, terminate the process.
Thank you for this advice. I had just found this before you mail arrived and did what you said. It works!
Same problem on my Mac. What is the solution to close dynamic link manager on Mac?
Hi Chac57, not sure u solved your problem...you should go to your Activity Monitor, on your Mac and find this dynamic link manager and force quit the proccess.
Then should work fine!
Cheers!
Very helpful!! ur the best
