7 Replies Latest reply: Jan 26, 2011 5:23 AM by Rob Dillon RSS
    Dynamice Text adding Numbers
    Fumph Community Member
      I dont know why, but I am having the hardest time! All I want is for there to be a movieclip, and when I click it my textfield adds a number! I swear I have looked everywhere but nothing! Does anyone know how to do such? Thanks!
        • 1. Re: Dynamice Text adding Numbers
          Rob Dillon CommunityMVP
          What version of Flash are you using and which version of Actionscript are you using? What does you code look like now?
          • 2. Re: Dynamice Text adding Numbers
            Flash pro CS5 and AS3(Because I'm in the Actionscript 3 forum), but currently I have no code because every code I try just doesn't work. There will be compiler errors, text wont show, syntax error! I hope that helps!
            • 3. Re: Dynamice Text adding Numbers
              You might be surprised at how many people who post in this forum are actually using AS2. In any case, you could use something like this:
              buttonInstanceName.addEventListener(MouseEvent.MOUSE_UP,myUp);
              dynamicTextInstanceName.text = "0";
              function myUp(event:MouseEvent):void {
              var myTempNum:int = parseFloat(dynamicTextInstanceName.text);
              myTempNum += 1;
              dynamicTextInstanceName.text = myTempNum.toString();
              • 4. Re: Dynamice Text adding Numbers
                Haha I bet! So I tried this code in my project, but! It still doesn't count up! I am thinking it has to do with the fact that I go to a new scene once I click this button. Here is the code for my main scene:
                stop();
                goal1.addEventListener(MouseEvent.MOUSE_DOWN, shootBall1);
                goalCount.text = "0";
                function shootBall1(e:MouseEvent):void
                var myTempNum:int = parseFloat(goalCount.text);
                  myTempNum +=  1;
                  goalCount.text = myTempNum.toString();
                trace("Goal!");
                gotoAndPlay("shoot1","shootGoal");
                And once it goes back to my main scene it restarts the counting because of the "goalCount.text = "0";". I believe that's my problem, do you have any advice?
                • 5. Re: Dynamice Text adding Numbers
                  You can set the inital value of the text conditionally:
                  if(goalCount.text == "") {
                  • 6. Re: Dynamice Text adding Numbers
                    I'm sorry but, it still doesn't work. I don't know what is wrong with it but it doesn't count! Even when I took out the "gotoAndPlay". Its... being difficult! Do you think you could fix it?? Maybe I could e-mail you the FLA. But its okay if you cant.
                    • 7. Re: Dynamice Text adding Numbers
                      Sure, send me a private message and I'll send you an upload address to send the file to.
