4 Replies Latest reply on Jan 27, 2011 12:39 AM by Flex_Crazy
    Module Loader Problems In Flex....
    Flex_Crazy Level 1
      Everytime i load a Module from a tree menu in the Application, at time of exiting the module the main application needs to refreshed if not the next module loaded doesn't function properly (ComboBoxes don't get populated, Buttons don't execute the desired function...etc)
        • 1. Re: Module Loader Problems In Flex....
          Gaurav J Adobe Employee
          Which version of Flex SDK ?
          Post the code that you are using to load/unload modules.
          -Gaurav
          http://www.gauravj.com/blog
          • 2. Re: Module Loader Problems In Flex....
            Flex_Crazy Level 1
            Flex 3.2 SDK is the version that i'm using.....
            Flex Code:
            <mx:Application tabEnabled="false" tabChildren="true" xmlns:mx="http://www.adobe.com/2006/mxml" initialize="init()"
                applicationComplete="registerGlobalKeyHandler()"  layout="absolute" width="100%" height="100%"
                xmlns:model="com.citizen.cbs.model.*" xmlns:utils="flexed.utils.timeout.*">
            <mx:RemoteObject id="initInfoUCFlexRO" destination="initInfoUCFlexRO">
                <mx:method name="getInitInfo" result="handleGetInitInfoResult(event)" fault="handleGetInitInfoFault(event)" />
            </mx:RemoteObject>
            <mx:RemoteObject id="mainMenuUCFlexRO" destination="mainMenuUCFlexRO">
                <mx:method name="getXMLDocument" result="handlegetXMLDocumentResult(event)" fault="handlegetXMLDocumentFault(event)"/>
            </mx:RemoteObject>
            <mx:RemoteObject id="branchDetailsUCFlexRO" destination="branchDetailsUCFlexRO">
                <mx:method name="read" result="handleReadResult(event)" fault="handleReadFault(event)"/>
                <mx:method name="stnIP" result="handleStnIPResult(event)" fault="handleStnIPFault"/>
            </mx:RemoteObject>
            <mx:Script>
                <![CDATA[
                    import mx.controls.RadioButton;
                    import mx.events.CloseEvent;
                    import flexed.utils.timeout.*;
                    import mx.core.EdgeMetrics;
                    import mx.core.Container;
                    import com.citizen.cbs.vo.ApplicationInitInfo;
                    import com.citizen.cbs.CitizenApplication;
                    import mx.rpc.events.FaultEvent;
                    import mx.rpc.events.ResultEvent;
                    import mx.modules.IModuleInfo;
                    import mx.modules.ModuleManager;
                    import mx.events.ModuleEvent;
                    import mx.controls.Alert;
                    import mx.managers.CursorManager;
                    import mx.events.DynamicEvent;
                    private var info:IModuleInfo = null;
                    [Bindable]
                    private var XMLDocument:XML;
                    [Bindable]
                    private var branchCode:int;
                    //passed to the component as value of onTimeOut attribute
                        private function onTimeOutHandler(e:Event=null):void
                            Alert.show("The Client has been timed out due to inactivity","Timeout Message by Method call",(Alert.OK),this,autoLogout);
                        private function autoLogout(event:CloseEvent):void{
                            if(event.detail==Alert.OK){
                            var str:String="/citizenProject/LogoutServlet";
                            //var jscommand:String = "window.open('"+str+"','win','toolbar=no,scrollbars=yes,resizable=1');";
                            var url:URLRequest = new URLRequest(str);
                            navigateToURL(url, "_self");
                        //Fired when the appTimedOut event occurs in the component
                        private function appTimedOutHandler(devent:DynamicEvent):void{
                            var expiryTime:String = devent.expiryTime.toString();
                            //Alert.show("The Client has been timed out at "+expiryTime,"Timeout Message by Event trigger");
                    private function init():void
                        branchDetailsUCFlexRO.read();
                        branchDetailsUCFlexRO.stnIP();
                    public function unloadModule():void {
                        var ref:URLRequest=new URLRequest("javascript:location.reload(true)");
                        navigateToURL(ref,"_self");
                        treeBox.percentWidth = 25;
                        treeBox.enabled = true;
                        treeBox.visible = true;
                        formLoader.unloadModule();
                    private function handleGetInitInfoResult(event:ResultEvent):void {
                        CitizenApplication.initInfo = ApplicationInitInfo(event.result);
                        var user:String = CitizenApplication.initInfo.registeredUser.uamCode;
                        mainMenuUCFlexRO.getXMLDocument(branchCode, user);
                    private function handleGetInitInfoFault(event:FaultEvent):void {
                        Alert.show("Error in Getting Init Info : " + event.fault.faultString);
                    private function handleStnIPResult(event:ResultEvent):void
                        lblStn.text=String(event.result);
                    private function handleStnIPFault(event:FaultEvent):void
                        Alert.show("Error in Getting Station IP : " + event.fault.faultString);
                    private function handlegetXMLDocumentResult(event:ResultEvent):void
                        XMLDocument = event.result as XML;
                    private function handlegetXMLDocumentFault(event:FaultEvent):void
                        Alert.show("Error In Getting XML Document: "+event.fault.faultString,"ERROR!!!!");
                    private function handleReadResult(event:ResultEvent):void
                        branchDetailsVO = BranchDetails(event.result);
                        branchCode = branchDetailsVO.bdBranchNo;
                        initInfoUCFlexRO.getInitInfo();
                    private function handleReadFault(event:FaultEvent):void{
                        Alert.show(event.fault.faultString);
                   private function loadModule(selectedItem:Object):void                               //Loading Module
                        var moduleToOpen:String = selectedItem.@data;            /* ******* */
                        if (moduleToOpen.length == 0) {
                            return;
                        var parameters:String = selectedItem.@parameters;
                        var allParameters:Array = parameters.split(",");
                        CitizenApplication.menuParameters  = new Object();
                        for (var i:int = 0; i < allParameters.length; i++) {
                            var parameter:String = allParameters[i];
                            CitizenApplication.menuParameters[parameter.split("=")[0]] = parameter.split("=")[1];
                        var moduleurl:String = moduleToOpen+'?'+Math.random();
                        formLoader.url = moduleurl;
                        //Alert.show("URL: "+moduleurl,"Message!!!!");
                        formLoader.loadModule();
                        treeBox.enabled = false;
                        treeBox.visible = false;
                        treeBox.percentWidth = 0;
                    private function moduleEventHandler(event:ModuleEvent):void {
                        moduleCanvas.addChild(info.factory.create() as DisplayObject);
                    private function handleModuleLoaderError(event:ModuleEvent):void {
                        trace(event.errorText  + " - " + event.bytesLoaded + " -- " + event.bytesTotal + " -- " + event.module);
                   private function reloadpage(event:ModuleEvent):void        //This Function is required so that the modules work
            </mx:Script>
            <utils:ClientIdleTimeOut id="myTimeOut" onTimeOut="onTimeOutHandler" listenKeyStroke="true" listenMouseMove="true"
                timeOutInterval="5" confirmInterval="5"/>
            <model:BranchDetails id="branchDetailsVO"/>
            <mx:XML id="mainMenu" source="/assets/xml/mainmenu.xml" format="xml"/>
                <mx:DateFormatter id="df" formatString="DD-MM-YYYY" />
                <mx:ApplicationControlBar horizontalAlign="center" width="90%" x="60" y="0">
                    <!--<mx:MenuBar   dataProvider="{mainMenu}" labelField="@label" showRoot="false"  itemClick="loadModule(event.item)" />-->
                    <mx:Label text="Ver.No.: R1872" fontWeight="bold" fontSize="12" color="#000000"/>
                    <mx:Label text="Station No.:" color="#000000" fontFamily="san" fontWeight="bold"/>
                    <mx:Label text="--" color="#000000" id="lblStn" fontFamily="san" fontWeight="bold"/>
                    <mx:Spacer width="100%" />
                    <mx:Text fontWeight="bold" text="{CitizenApplication.initInfo.registeredUser.branchDetails.bdBankName}"  styleName="appctrl"/>
                    <mx:Text fontWeight="bold" text="-"  styleName="appctrl"/>
                    <mx:Text fontWeight="bold" text="{CitizenApplication.initInfo.registeredUser.branchDetails.bdBranchName.toUpperCase( )}"  styleName="appctrl"/>
                    <mx:Text fontWeight="bold" text="BRANCH"  styleName="appctrl"/>
                    <mx:Text fontWeight="bold" text="{CitizenApplication.initInfo.registeredUser.uamName}"  styleName="appctrl"/>
                    <mx:Text fontWeight="bold" text="|"  styleName="appctrl"/>
                    <mx:Text fontWeight="bold" text="{df.format(CitizenApplication.initInfo.registeredUser.branchDetails.bdCurrentWorkin gDt)}"  styleName="appctrl"/>
                </mx:ApplicationControlBar>
                <mx:HDividedBox id="divBox" width="100%" height="100%" shadowDirection="center" resizeToContent="true" liveDragging="true" horizontalGap="10" x="0" y="34">
                    <mx:VBox width="274" id="treeBox" borderStyle="solid" borderColor="#6699CC"><mx:Tree backgroundColor="#000000" color="#FFFFFF" width="100%" height="100%" id="treeMenu" dataProvider="{XMLDocument}" labelField="@label" showRoot="false"
                            itemClick="loadModule(treeMenu.selectedItem)"/>
                        <!--<mx:Tree backgroundColor="#000000" color="#FFFFFF" width="100%" height="100%" id="treeMenu" dataProvider="{XMLDocument}" labelField="@label" showRoot="false"
                            itemClick="loadModule(treeMenu.selectedItem)"/>-->
                    </mx:VBox>
                      <mx:Canvas id="moduleCanvas" width="100%" height="100%" styleName="mmc">
                     <mx:ModuleLoader backgroundColor="#000000" color="#FFFFFF" error="handleModuleLoaderError(event)"
                         updateComplete="treeMenu.height = moduleCanvas.height-2" loading="CursorManager.setBusyCursor()"
                         useHandCursor="true"   ready="CursorManager.removeBusyCursor()" autoLayout="true"
                         verticalAlign="middle" horizontalAlign="center" id="formLoader" width="100%" height="100%" />
                      </mx:Canvas>
                </mx:HDividedBox>
                <mx:Style source="CbsDesignFinal.css"/>
            </mx:Application>
            • 3. Re: Module Loader Problems In Flex....
              Do you see the update dmoduleurl when you click on a new item in the tree?
              Module url change also triggers a module load, so no need to do formLoader.loadModule(); after formLoader.url = moduleurl;
              -Gaurav
              • 4. Re: Module Loader Problems In Flex....
                Flex_Crazy Level 1
                                return;
                @Gaurav I think thats wat i have done already.....any other solution....
