0 Replies Latest reply on Jan 24, 2011 5:35 AM by Djarfogo
    Validate Javascript in static pdf
    Djarfogo
      hello!
      I created a form in LiveCycle designer has some validation, using JavaScript, such as adding a row in the table.
      When recording in static Adobe PDF format, when I open the acrobat pdf does not validate because you cannot read xml;
      If you save as adobe dynamic xml form, validates, but as I send this pdf to a specific program, this program cannot read data because it turns into a PDF file bipmap I percise continuing as text, because the program does type a document on the OCR to read the data.
      1-is there any way to validate data without the aid of JavaScript?
      2 - Is able to read JavaScript even saved as adobe pdf satic?
      thanks
