9 Replies Latest reply on Jan 28, 2011 7:49 AM by Claudiu Ursica
    Object assignments, What am I missing?
    mattcom Level 1
      So I must be missing something basic here.
      This works and recognizes data changes:
      <mx:Label text="Search Title: [{this.appData.userPositionSearch.SearchFilterTitle}]"/>
      But if I do this it doesn't recognize changes:
      [Bindable]
      private var UserSearchData:Object;
      private function changeHandler():void
           UserSearchData = this.appData.userPositionSearch;
      <mx:Label text="Search Title: [{UserSearchData.SearchFilterTitle}]"/>
      The reason I'm interested in having a variable to the object assignment, is that I can use the same form for different types of searches (objects).
      Thanks in advance for the help.
        • 1. Re: Object assignments, What am I missing?
          Claudiu Ursica Level 4
          private var UserSearchData:Object; ->
          Object is not an IEventDispatcher you going to have to wrap it inside
          ObjectProxy or create your won custom Bindable class.
          C
          • 2. Re: Object assignments, What am I missing?
            mattcom Level 1
            .appData.userPositionSearch is a custom bindable class.  Does that count?
            • 3. Re: Object assignments, What am I missing?
              I am assuming that when this line is happening you don't get the new changes:
              Right?
              C
              • 4. Re: Object assignments, What am I missing?
                mattcom Level 1
                Correct.  It only seems to stay at the default values of the VO.
                Also (this may be a clue) if I try this:
                [Bindable]
                private var UserSearchData:UserPositionSearchVO;
                UserSearchData.SearchFilterTitle = "blah";
                I get this:
                Error #1009: Cannot access a property or method of a null object reference
                • 5. Re: Object assignments, What am I missing?
                  Well the problem is that as I said Object cannot dispatch the "propertyChanged"
                  event since is not an IEventDispatcher. Your Object needs to be an
                  IEventDispathcer which if you use a custom Bindable class it will be since the
                  compiler will decorate/enhance it with the ability to dispatched events.
                  I am still not sure what you are trying to achieve so I am going to assume that
                  you want the generic Object so you can assign different object to it at runtime.
                  If that is the case you can have a bindable interface and drop in there the
                  properties that you want to observe changes on. So instead of
                  you will have:
                  private var UserSearchData:IMyBindableInterface; implemented by a bindable class
                  which fill fire your changes. The part that I don't see is who trigger your
                  changeHandler() to execute.
                  If you share more code details I will probably be able to understand better the
                  issue here. Right now I am just trying to make your Bindings execute.
                  C
                  • 6. Re: Object assignments, What am I missing?
                    mattcom Level 1
                    Thanks for your conitinued effort Claudiu.
                    I think something might be wrong with my SDK?  Following your suggestions I looked into ObjectProxy for a while and even the most basic examples are giving me errors.
                    import mx.events.PropertyChangeEvent;
                    import mx.utils.ObjectUtil;
                    import mx.utils.ObjectProxy;
                    import mx.utils.StringUtil;
                    var a:Object = { name: "Tyler", age: 5, ssnum: "555-55-5555" };
                    var p:ObjectProxy = new ObjectProxy(a);
                    p.addEventListener(PropertyChangeEvent.PROPERTY_CHANGE, trace("changed"));
                    p.name = "Jacey";
                    p.age = 2;
                    I keep getting "1120: Access of undefined property p"
                    Back to the bindable class...
                    I'm using Cairngorm and my VO is bound.
                    [Bindable]
                    public class UserPositionSearchVO
                    using the Cairngorm architecture, it allows me to use what is working from my first post:
                    <mx:Label text="Search Title: [{this.appData.userPositionSearch.SearchFilterTitle}]"/>  where this.appData.userPositionSearch is a clone of UserPositionSearchVO.  Which is why I tried to do
                    [Bindable]
                    and then in the change handler
                    UserSearchData = this.appData.userPositionSearch (which is updated every time the change handler is hit)
                    however the data just stays the same in UserSearchData, just as it did if I assigned it to UserSearchData:Object.
                    Perhaps I just can't explain it well.  After all, like I said in my first statement, this should work, and I must be missing something.
                    • 7. Re: Object assignments, What am I missing?
                      Who is triggering the changeHandler? where are you calling it ? I am pretty sure
                      there is a simpler way but I don;t understand thy whole picture.
                      what is wrong with this.
                      Or why do you want to change it.
                      Sorry need to run now, I'll look into it in the evening.
                      C
                      • 8. Re: Object assignments, What am I missing?
                        mattcom Level 1
                        So the change handler is hit when an search filter is selected in a combobox.
                        The reason I'm trying to handle it in a variable is the search box is a shared component that can search positions, alerts, and other things
                        so {this.appData.userPositionSearch.SearchFilterTitle}  may need to be {VO2.SearchFilterTitle} in another part of the application and {VO3.SearchFilterTitle} in another.
                        • 9. Re: Object assignments, What am I missing?
                          Did you fixed this? I was off for a couple of days did not have time to look
                          into it?
                          C
