5 Replies Latest reply on May 17, 2012 9:42 PM by Nirmalya Saha
    Calling parent application function from ItemRenderer
    linrsvp
      Hi, I have a spark list control whose data is rendered using an  itemrenderer. Basically the Item renderer lays out the data within a  Panel.
      The Panel has a LinkButton, which when clicked needs to pass an Id to  the parent application. In the parent application I have a function  that dispatches a custom event to its parent. I want to know how to call  this function from the ItemRenderer.
      I tried using parentDocument.outerfunction etc but it throws an error..
      Can I do this using custom events ? If so, how ? Please explain in detail
      Thanks ,...
        • 2. Re: Calling parent application function from ItemRenderer
          linrsvp Level 1
          Yes I tried dat too.. I get an error :"Use of underfined variable" ...
          • 3. Re: Calling parent application function from ItemRenderer
            Flex harUI Adobe Employee
            Post the relevant code.
            • 4. Re: Calling parent application function from ItemRenderer
              AntuanSoft Level 1
              You can Access via
              parentDocument.parentDocument;
              MainApp.MXML:
              <s:Application
              <s:Group width="100%">
                                            <s:HGroup left="40" top="40">
                                                      <s:List width="100%" dataProvider="{items}"
        itemRenderer="ServicesIR"
        contentBackgroundColor="#E6E7E8" borderVisible="false">
        <s:layout>
        <s:HorizontalLayout columnWidth="50" gap="5"/>
        </s:layout>
                                                      </s:List>
              </Application>
              ServicesIR.mxml
              <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                      xmlns:mx="library://ns.adobe.com/flex/mx"
                                                      autoDrawBackground="true">
              <fx:Script>
                                  <![CDATA[
                                            override public function set data(value:Object):void
                                                 var parent:MainApp =  parentDocument.parentDocument; //Instance of MainApp.mxml
                        </fx:Script>
              <s:ToggleButton id="tab" isAlerted="false"  label="{(data.name}" horizontalCenter="0" verticalCenter="0"/>
              </s:ItemRenderer>
              • 5. Re: Calling parent application function from ItemRenderer
                Nirmalya Saha Level 1
                You can also try with FlexGlobals.topLevelApplication.parentFunction();
                And for this add ------  import  mx.core.FlexGlobals;
