1 Reply Latest reply on Jan 25, 2011 4:12 AM by Sharad Saxena
    installing fireworks demo
    Hey cookie
      Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 28 error(s), 25 warning(s)
      WARNING: Payload cannot be installed due to dependent operation failure
      ERROR: MsiConfigureProductEx failed with error: 1612
      ERROR: The following payload errors were found during install:
      ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
      ERROR:  - Microsoft_VC90_ATL_x86: Install failed
      ERROR:  - Adobe Media Player: Install failed
      ERROR:  - Microsoft_VC90_CRT_x86: Install failed
      ERROR:  - Microsoft_VC80_ATL_x86: Install failed
      ERROR:  - Adobe Fireworks CS5: Failed due to Language Pack installation failure
      ERROR:  - DeviceCentral_DeviceCentral3LP-en_US: Install failed
      ERROR:  - Adobe XMP Panels CS5: Install failed
      ERROR:  - Adobe Player for Embedding: Install failed
      ERROR:  - Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack: Install failed
      ERROR:  - AdobeHelp: Install failed
      ERROR:  - Microsoft_VC90_MFC_x86: Install failed
      ERROR:  - Suite Shared Configuration CS5: Install failed
      ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
      ERROR:  - AdobeTypeSupport CS5: Install failed
      ERROR:  - Adobe CSXS Extensions CS5: Install failed
      ERROR:  - AdobePDFL CS5: Install failed
      ERROR:  - HIL Help Search: Install failed
      ERROR:  - AdobeCMaps CS5: Install failed
      ERROR:  - Required Common Fonts Installation: Install failed
      ERROR:  - Microsoft_VC80_MFC_x86: Install failed
      ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
      ERROR:  - Recommended Common Fonts Installation: Install failed
      ERROR:  - Adobe Extension Manager CS5: Install failed
      ERROR:  - AdobeJRE: Install failed
      ERROR:  - Adobe AIR: Install failed
        • 1. Re: installing fireworks demo
          Sharad Saxena Level 3
          Installing the MSI files manually may help you out as you are facing the following error -
          Goto folder where you extracted the fireworks installer. Then double click to install the following msi -
          payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
          If it prompts for path, provide the path to msi itself. The msi would get installed successfully. Now run the fireworks installer again by double clicking Set-up.exe.
