3 Replies Latest reply on Jan 26, 2011 1:09 AM by Adam Cameron.
    Coldfusion webroot and multiple domain names
    funandlearning333 Level 1
      Hi All -
      I am new to this multiple domain thing. Am working on a project, where there multiple domain projects under on webroot. Like www.abc.com, www.def.com under one root. The folder structure is something like below:
      E:
      webroot
          --INCLUDES
          --IMAGES
            -- www.abc.com
               --folder1
                 --index.cfm
            -- www.def.com
      So the above two diff domains share two common folders. When I use an include file of form .cfm, I can get it to work. But somehow the images are not displayed. I tried the following syntaxes
      Suppose I want to access images from index.cfm under www.abc.com/folder1, i tried the following:
      <img src="../../IMAGES/image.gif">(does not work)
      <img src="E:/webroot/IMAGES/image.gif) (also does not work. The image symbol is shown but the entire image is not shown).
      Any thoughts on how to get this working?
        • 1. Re: Coldfusion webroot and multiple domain names
          Dave Watts Adobe Community Professional
          Well, first, it might be useful to figure out what exactly you mean by
          "webroot" here. Generally, it means the folder that actually maps to a
          web server's HTTP root directory. For example, if you have a single
          web server that corresponds to a single domain, you might have
          something like this:
          c:\inetpub\wwwroot\
          which maps to
          http://www.yoursite.com/
          In your above example, does the directory e:\webroot\www.abc.com map
          to http://www.abc.com/? If so, the webroot is e:\webroot\www.abc.com,
          not e:\webroot.
          Assuming that your webroot is e:\webroot\www.abc.com, neither of those
          image tags will work. The second won't work no matter what your webroot is,
          because a browser isn't going to be able to resolve a directory path
          on the server. You'd have to create a virtual directory for each of
          those virtual web servers (www.abc.com, www.def.com). Then, you'd be
          able to resolve URLs using the virtual directory as your starting
          point:
          <img src="/images/image.gif">
          Dave Watts, CTO, Fig Leaf Software
          http://www.figleaf.com/
          http://training.figleaf.com/
          • 2. Re: Coldfusion webroot and multiple domain names
            RobbHartzog
            It would be helpful to know exactly how you are accessing these domains from a web browser.
            Examples:
            http://www.somedomain.com/www.abc.com/
            or
            http://www.abc.com
            If its the first one, <img src="/images/image.gif"> will work.
            If its the second, the IMAGES folder would be below you're "webroot" and would not be accessible no matter what you did. What you could do in this case is create a "Virtual Directory - IIS" or a "SimLink - Linux"  linking to the IMAGES folder for each site. So that both sites would have access to the same IMAGES folder.
            • 3. Re: Coldfusion webroot and multiple domain names
              Adam Cameron. Level 5
              It's probably important to shift your thinking a bit here.  Theer are two different "roots" here (well: three, if you're looking at a default IIS install):
              * CF root;
              * web site root;
              * a directory called wwwroot
              Looking at your example:
              webroot
                  --INCLUDES
                  --IMAGES
                    -- www.abc.com
                       --folder1
                         --index.cfm
                    -- www.def.com
              webroot (which I am guessing is your C:\inetpub\wwwroot dir) in this case is not your "web root", it's your CF root, by the looks of it.  And the directories www.abc.com and www.def.com are your web roots for those two sites.
              Confusion often arises here because when one configures CF, the CF root is often mapped to C:\inetpub\wwwroot (or the htdocs dir or whatever the web root is of the web server's default site), so it seems like there's just the one "web root".  But there isn't.
              So CF will look for resources in the CF root; the web server will look for resources in the web root of the site being served.
              In your example, the websites cannot access IMAGES, because that directory is not in the web root of the site.  As someone else has suggested, you need to add a virtual directory within the website to map to the IMAGES dir.
              You cannot use .. notation to navigate up the file system to "above" the web root, because as far as the web site is concerned, the www.abc.com dir is the ROOT directory.  IE: that's as far up the file system the site can access.
              The reason why you E:\[etc] path does not work is because that path is requested by the web browser, which is going to be on a completely different computer to where the E: drive is.  The path needs to be a URL.
              Adam
