4 Replies Latest reply on Jan 27, 2011 6:08 PM by Super_Noodles
    Sound problem
    Super_Noodles Level 1
      On my first page I have got two checkboxes. One for sounds and one for music. This allows the user to choose whether they want the sound played before it suddenly starts and shocks them.
      This is the code i have for the Sounds checkbox:
      on beginSprite me
        if (sprite("checkbox_Sounds").hilite = TRUE) then
          sound(1).volume = 255
        else if (sprite("checkbox_Sounds").hilite = FALSE) then
          sound(1).volume = 0
        end if
      end
      and i have some audio on the page with this code (it is played when hovering over an item)
      sound(1).play(member("Blip2"))
      The code seems fine and with no errors but it does not work. I guess I'm doing something stupid but have spent too long trying to figure it out. Please help.
        • 1. Re: Sound problem
          Mike Blaustein Level 4
          For one thing, your code is on beginSprite which only happens once, when the sprite first appears.  So, clicking on the checkbox will never change the volume unless you leave the frame and go to a frame tht this checkbox is not in, then come back.  You probably want to also add some code to on mouseUp so that it adjusts the volume when it gets clicked.
          • 2. Re: Sound problem
            Oh right, I have now changed it back to MouseUp but still nothing is happening.
            I have also tried this if statement but it also has no effect
            if (sprite("checkbox_Sounds").selected=1) then
            • 3. Re: Sound problem
              put a few "put" statements into your code to see what is happening (or not happening)... for example:
              on mouseUp me
              put sprite(me.spriteNum).selected
              ... your other code here...
              end
              That will test to see if the button actually is getting pressed, and if the selected property is being correctly toggled... some Flash Component buttons don't work until you set the EventPassThrough to Always in the property inspector.
              • 4. Re: Sound problem
                Thanks for the help Mike!
                I'm finally getting to grips with Lingo now. I did make the silly mistake of having the component as Never not Always though :S
                Cheers
