1 Reply Latest reply on Jan 25, 2011 8:38 AM by UbuntuPenguin
    Files, directories and subdirectories count
    Pisti123 Level 1
      Hello,
      I'm currently building a small AIR application via Flash Builder 4 (FLEX 4) that will count the number of files (EVERY type of file)
      in a certain directory (choosen by the user) the problem gets when I have subdirectories,
      tried recursive (which is basicly the only solution) and got stuck and confused with myself, can anyone help a brother out here?
                  private var directory:File = File.documentsDirectory;
                  [Bindable]
                  private var count:int = 0;
                  public function browseForDirectory():void
                      directory.browseForDirectory("Select Directory");
                      directory.addEventListener(Event.SELECT, directorySelected);
                  public function directorySelected(event:Event):void
                      directory = event.target as File;
                      var files:Array = directory.getDirectoryListing();
                      for(var i:int = 0; i < files.length; i++)
                          myPath.text = directory.nativePath;
                  public function countFiles():void
                      for (var i:int = 0; i < files.length ; i++)
                          count++;
                          if (files[i].isDirectory)
                              count += countFiles();
                      myResult.text = count.toString();
      Hoping for a quick response, Thanks!
