4 Replies Latest reply on Jan 26, 2011 3:08 PM by Jhon Carlo
    How to increase the number of access to a list
    Jhon Carlo Level 1
      I have a list with many numbers, for example [234, 235, 236, 237 .....]. If I want access to  the first value of the list I can use for example the command: "put MyList [1]" and I get 234.
      Now I need to have a script that increases the number in square brackets of "MyList" by one unit (MyList[2]; MyList [3] etc..) in order to obtain 235, 236 etc.. If I use the command "setAt" or  "MyList [1] = MyList [1] + 1",  with "put MyList" I get the value 2, 3 etc.. and not 235, 236 ... that I need.
      What might be the way to the solution?
      Thanks.
        • 1. Re: How to increase the number of access to a list
          Production Monkey Level 3
          There is nothing wrong with the code "MyList [1] = MyList [1] + 1". It works as expected.
          What you want though is "MyList = MyList + 1".
          • 2. Re: How to increase the number of access to a list
            Jhon Carlo Level 1
            Thanks a lot Production Monkey for your reply,
            If I use "MyList = MyList + 1", if my list is equal to the following for example: [0, 11, 123, 234, 6443], the result will be: [1, 11, 123 234, 6443], but it is not what I want. I try to be more clear.
            MyList = [224, 336, 445, 224, 779 etc ...]
            Now, without changing the values of "MyList", I need to access the first, second, third .... etc value.
            The first hypothesis might be:
            MyList [1] (I obtain the value 224 and it is good)
            MyList [2] (I obtain the value 336 and it is good)
            MyList [3] (I obtain the value 445 and it is good)
            etc. .........
            but the list is very long and change, I would like a script, for example "on mouseUp me" to increase (not the value of the first list [224.336 etc]) but only the single value inside the brackets for example: MyList [4], MyList [5], MyList [6], MyList [7] ... [8] ... [9] and so on.
            How can I do?
            I apologize for my bad English.
            • 3. Re: How to increase the number of access to a list
              Do you mean something like:
              property pStartingIndex
              property MyList
              on beginSprite me
                MyList = [224, 336, 445, 224, 779]
                pStartingIndex = 1
              end
              on mouseDown me
                repeat with Index = pStartingIndex to MyList.count
                  put MyList[Index]
                end repeat
                pStartingIndex = pStartingIndex + 1
                if pStartingIndex > MyList.count  then pStartingIndex = 1
                put "______________"  -- add breaks between mousedowns
              end  mouseDown
              • 4. Re: How to increase the number of access to a list
                Jhon Carlo Level 1
                Thanks Production Monkey
                I tried to do a first test and it works.
                Thanks a lot!!!
