This content has been marked as final.
Show 1 reply
1. Re: Compatability between CS4 and CS5 PPro?
Bill Hunt Jan 26, 2011 8:00 AM (in response to cooleon)If you are dealing with Exported files, there should not be any issues.
If you are dealing with the Project files (PRPROJ), then there is a one-way street, that usually works, but that will depend on what is used in the CS4 Projects. One can usually Open, or Import a CS4 Project into CS5, but it will be converted, so that converted Project will never likely open in CS4. Also, CS5 created Projects will never likely Open in CS4.
With Exported AV files, there should not be an issue.
