7 Replies Latest reply on Jan 26, 2011 10:58 PM by Flex harUI
    A bug about Module
    moo213
      Recently I am reading the book "Adobe Flex 3: Training from the source". I ran the code in lesson 20 but got a error. Then I spent one day on picking up it.
      Then I found it and I wrote a simpler example.
      it seems that if the module is bigger than a size(actually not very big, just a form as you see in mymodule.mxml),  there will be an error(often nullpointer at some ui class).
      But if the red line deleted, or the yellow line deleted(to cut the size of mymodule), the error will disappear.
      Actually I want to call the function  myinithello() when the module has complete loading,  but even though the function myinithello() has not been called(as the test.mxml) , the error will also appear.
      test.mxml:
      <?xml version="1.0"?>
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx">
      <fx:Script>
        <![CDATA[
        private function myinithello():void {
         m1.child as ChildModule1;
      </fx:Script>
      <mx:ModuleLoader url="mymodule.swf" id="m1"  />
      </s:Application>
      mymodule.mxml
      <mx:Module
      width="100%" height="100%">
      <mx:VBox>
        <mx:Form>
         <mx:Label text="hello" />
         <mx:FormItem label="item1">
         </mx:FormItem>
         <mx:FormItem label="item2">
         </mx:FormItem>
        </mx:Form>
      </mx:VBox>
      </mx:Module>
      报错信息:
      TypeError: Error #1009: 无法访问空对象引用的属性或方法。
      at mx.core::UIComponent/getStyle()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\UI Component.as:10372]
      at mx.core::UIComponent/getTextFieldClassName()[E:\dev\4.0.0\frameworks\projects\framework\s rc\mx\core\UIComponent.as:11905]
      at mx.core::UIComponent/createInFontContext()[E:\dev\4.0.0\frameworks\projects\framework\src \mx\core\UIComponent.as:11870]
      at mx.controls::Label/http://www.adobe.com/2006/flex/mx/internal::createTextField()[E:\dev\4.0.0\frameworks\proj ects\framework\src\mx\controls\Label.as:1506]
      at mx.controls::Label/createChildren()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\con trols\Label.as:1319]
      at mx.core::UIComponent/initialize()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\ UIComponent.as:7250]
      at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\core\UIComponent.as:7142]
      at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\core\Container.as:3951]
      at mx.core::Container/addChildAt()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Co ntainer.as:2616]
      at mx.containers::Form/addChildAt()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\contai ners\Form.as:293]
      at mx.core::Container/addChild()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Cont ainer.as:2534]
      at mx.containers::Form/addChild()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\containe rs\Form.as:282]
      at mx.core::Container/createComponentFromDescriptor()[E:\dev\4.0.0\frameworks\projects\frame work\src\mx\core\Container.as:4371]
      at mx.core::Container/createComponentsFromDescriptors()[E:\dev\4.0.0\frameworks\projects\fra mework\src\mx\core\Container.as:4160]
      at mx.core::Container/createChildren()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cor e\Container.as:3187]
      at mx.core::Container/initialize()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Co ntainer.as:3129]
      at ChildModule1/initialize()
      at mx.modules::ModuleLoader/moduleReadyHandler()[E:\dev\4.0.0\frameworks\projects\framework\ src\mx\modules\ModuleLoader.as:468]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at ModuleInfoProxy/moduleEventHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\mo dules\ModuleManager.as:1168]
      at ModuleInfo/readyHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\modules\Modul eManager.as:812]
      at mx.core::FlexModuleFactory/update()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cor e\FlexModuleFactory.as:433]
      at mx.core::FlexModuleFactory/docFrameHandler()[E:\dev\4.0.0\frameworks\projects\framework\s rc\mx\core\FlexModuleFactory.as:582]
      at mx.core::FlexModuleFactory/docFrameListener()[E:\dev\4.0.0\frameworks\projects\framework\ src\mx\core\FlexModuleFactory.as:126]
        • 1. Re: A bug about Module
          Gaurav J Adobe Employee
          Your example does not compile. Post the complete test case that is giving the RTE.
          -Gaurav
          http://www.gauravj.com/blog
          • 2. Re: A bug about Module
            moo213 Level 1
            red line in test.mxml:    m1.child as ChildModule1;
            Yellow line in mymodule.mxml:   <mx:Label text="hello" />
            test.mxml:
            <s:Application
            <fx:Script>
              <![CDATA[
            </fx:Script>
            </s:Application>
            mymodule.mxml
            <mx:Module
            <mx:VBox>
              <mx:Form>
               </mx:FormItem>
               </mx:FormItem>
              </mx:Form>
            </mx:VBox>
            </mx:Module>
            TypeError: Error #1009: Cannot access a property or method of a null object reference
            at mx.core::UIComponent/getStyle()[E:\dev\4.0.0\frameworks\projects\fram ework\src\mx\core\UIComponent.as:10372]
            at mx.core::UIComponent/getTextFieldClassName()[E:\dev\4.0.0\frameworks\ projects\framework\src\mx\core\UIComponent.as:11905]
            at mx.core::UIComponent/createInFontContext()[E:\dev\4.0.0\frameworks\pr ojects\framework\src\mx\core\UIComponent.as:11870]
            at mx.controls::Label/http://www.adobe.com/2006/flex/mx/internal::createTextField()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\controls\Label.as :1506]
            at mx.controls::Label/createChildren()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\controls\Label.as:1319]
            at mx.core::UIComponent/initialize()[E:\dev\4.0.0\frameworks\projects\fr amework\src\mx\core\UIComponent.as:7250]
            at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\UIComponent. as:7142]
            at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Container.as :3951]
            at mx.core::Container/addChildAt()[E:\dev\4.0.0\frameworks\projects\fram ework\src\mx\core\Container.as:2616]
            at mx.containers::Form/addChildAt()[E:\dev\4.0.0\frameworks\projects\fra mework\src\mx\containers\Form.as:293]
            at mx.core::Container/addChild()[E:\dev\4.0.0\frameworks\projects\framew ork\src\mx\core\Container.as:2534]
            at mx.containers::Form/addChild()[E:\dev\4.0.0\frameworks\projects\frame work\src\mx\containers\Form.as:282]
            at mx.core::Container/createComponentFromDescriptor()[E:\dev\4.0.0\frame works\projects\framework\src\mx\core\Container.as:4371]
            at mx.core::Container/createComponentsFromDescriptors()[E:\dev\4.0.0\fra meworks\projects\framework\src\mx\core\Container.as:4160]
            at mx.core::Container/createChildren()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\core\Container.as:3187]
            at mx.core::Container/initialize()[E:\dev\4.0.0\frameworks\projects\fram ework\src\mx\core\Container.as:3129]
            at mx.modules::ModuleLoader/moduleReadyHandler()[E:\dev\4.0.0\frameworks \projects\framework\src\mx\modules\ModuleLoader.as:468]
            at ModuleInfoProxy/moduleEventHandler()[E:\dev\4.0.0\frameworks\projects \framework\src\mx\modules\ModuleManager.as:1168]
            at ModuleInfo/readyHandler()[E:\dev\4.0.0\frameworks\projects\framework\ src\mx\modules\ModuleManager.as:812]
            at mx.core::FlexModuleFactory/update()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\core\FlexModuleFactory.as:433]
            at mx.core::FlexModuleFactory/docFrameHandler()[E:\dev\4.0.0\frameworks\ projects\framework\src\mx\core\FlexModuleFactory.as:582]
            at mx.core::FlexModuleFactory/docFrameListener()[E:\dev\4.0.0\frameworks \projects\framework\src\mx\core\FlexModuleFactory.as:126]
            • 3. Re: A bug about Module
              Flex harUI Adobe Employee
              You are using the ChildModule1 class in the main application.  This links
              ChildModule1 into the main app which defeats the purpose of modules and
              causes style calculation errors.  Use an interface to talk to the module
              from the main app.
              • 4. Re: A bug about Module
                moo213 Level 1
                sorry, "ChildModule"->"MyModule"
                The code was modifeid from the first example of "Accessing modules from the parent application" in http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf64277-7fea.html
                i just add a form to the module..
                red line in test.mxml:    m1.child as MyModule;
                Yellow line in MyModule.mxml:   <mx:Label text="hello" />
                test.mxml:
                <s:Application
                <fx:Script>
                  <![CDATA[
                </fx:Script>
                <mx:ModuleLoader url="MyModule.swf" id="m1"  />
                </s:Application>
                MyModule.mxml
                <mx:Module
                <mx:VBox>
                  <mx:Form>
                   </mx:FormItem>
                   </mx:FormItem>
                  </mx:Form>
                </mx:VBox>
                </mx:Module>
                • 5. Re: A bug about Module
                  moo213 Level 1
                  I think that add a interface can solve the problem. It seems that the cast "m1.child as MyModule" cause memory leak. But the segment has never run and the function has never been called.  Why?
                  • 6. Re: A bug about Module
                    you didn't call it.
                    You should attach a ready event handler to your moduleLoader. Something like:
                    <mx:ModuleLoader url="mymodule.swf" id="m1"  ready="readyHandler(event)"/>
                    and
                    import mx.events.ModuleEvent;
                    private function myinithello(e:ModuleEvent):void {
                    -Gaurav
                    • 7. Re: A bug about Module
                      I don't think it will cause a memory leak, but it will cause the exception
                      you are describing.  The doc example correctly uses an interface.  You are
                      not.  You can find several past threads on this forum where folks had the
                      same problem.  The code does not have to run to cause linking issues that
                      result in the exception.
