0 Replies Latest reply on Jan 26, 2011 4:04 PM by GabMusic7
    drawRowBackground not refreshing the ADG
    GabMusic7 Level 1
      Hello everybody:
      I'm modifying a program that wasn't developed by me.  It uses a custom AdvancedDataGrid as follows:
      package myComponents
          import flash.display.Sprite;
          import mx.controls.AdvancedDataGrid;
          public class ColorADG extends AdvancedDataGrid
              public var rowColorFunction:Function;
              override protected function drawRowBackground(s:Sprite,
                  rowIndex:int, y:Number, height:Number, color:uint, dataIndex:int):void
                  if(rowColorFunction != null)
                      var item:Object;
                      if(dataIndex < dataProvider.length)
                          item = dataProvider[dataIndex];
                      if(item)
                          color = rowColorFunction(item, rowIndex, dataIndex, color);
                  super.drawRowBackground(s, rowIndex, y, height, color, dataIndex);
      In the actual module, the rowColorFunction is defined as follows:
      private function calcRowColor(item:Object, rowIndex:int, dataIndex:int, color:uint):uint
          switch(item.orderStatus) {
              case '0':
                  return color;
              case '1':
                  return 0xedfae3;
              case '2':
                  return 0xf2eef7;
              default:
                  return color;
      <myComponents:ColorADG rowColorFunction="calcRowColor"
          designViewDataType="flat" dataProvider="{orders}" id="adgOrders"/>
      The ADG draws fine when the module is loaded, but after I add, modify or delete a row,
      the data in the component isn't refreshed and the ADG shows no results at all.
      I've tryed validateNow(), dataprovider.Refresh() methods, and also re-setting and
      refreshing the Array.  Nothing worked.
      I can't identify the bug, so I'd appreciate if anyone could help me fix this problem.
      Thank you.
