1 Reply Latest reply on Jan 27, 2011 8:58 PM by MTSTUNER
    Photoshop pdf Vs. Adobe pdf
    Geting_Started Level 1
      When I import a 3.5Kb pdf file into photoshop 9, even if I do not change anything, the pdf file I export from photoshop will be over 10Kb. I typically need to alter an image then save the file again as a pdf however these saved file sizes are 3 times the size of the original. Is there a setting that needs to be changed in my photoshop program? How can I reduce this file size? Even using the lowest quality setting I am over 10Kb.
