4 Replies Latest reply on Apr 12, 2011 8:17 AM by kjsapci
    Reade X and command line
    Ashard
      I work using Windows XP SP3 and Acrobat Reader X.
      I have create a service that control a directory, when a pdf file is copy in this directory the service execute the command line “AcroRd32.exe /t FileName PrinterName”.
      If I start the service with the logon user when execute the command line in the task manager appears one AcroRd32 and the print execute correctly.
      If I start the service with a user that are different to logon user (I test with other administrative user, local service or lan service) when execute the command line in the task manager appears two AcroRd32 and don’t execute the print.
      The same operation with Acrobat Reader 9.x work correctly.
      I have already try to disable the Protected Mode, but the problem persist. Please could you help me?
        • 1. Re: Reade X and command line
          kjsapci
          I'm experiencing the same problem when using the /p print flag on the command line (acrord32.exe /p filename.pdf).  In my case, disabling Protected Mode and restarting adobe reader caused the issue to go away, but that is not a solution as I'm calling the command line programmatically, and cannot disable this protected mode programmatically.  This issue doesn't occur on Windows 7, but it is a big problem that it happens on Windows XP as so many people are still using XP.
          • 2. Re: Reade X and command line ==>Alternative solution
            CBrunois
            Problem  with command line  protected mode  on Windows XP PRO sp3 and adobe reader 10X
            Try to create a little console dotnet application
            using System;
            using System.Collections.Generic;
            using System.Text;
            namespace Adobe10CmdLine
                class adobe10cmdline
                    static void Main(string[] args)
                        if (args.GetUpperBound(0) == -1)
                            System.Console.WriteLine("Le nom de fichier n'est pas renseigné");
                        else
                            string fil = args[0].ToString().Replace("\\", @"\");
                            string adobepath = System.Environment.GetEnvironmentVariable("ProgramFiles")+@"\Adobe\Reader 10.0\Reader\Acrord32.exe";
                            System.Diagnostics.Process.Start(adobepath, fil);
            Compile it
            Replace command line with acrord32.exe   [myfile.pdf]     by  Adobe10CmdLine.exe  [myfile.pdf]
            it ld be normally  OK
            Christophe
            • 3. Re: Reade X and command line - Alternative solution
              CBrunois Level 1
              using System;
              using System.Text;
                          else
              Compile it
              Christophe
              • 4. Re: Reade X and command line
                kjsapci Level 1
                Thanks so much for the information.  I ended up solving my issue by using
                the activex control instead of the command line.  This gave me more control
                of what displayed to the user when printing, so it was a better solution in
                the end.  It took a little bit of gymnastics to make it work in WPF, but
                nothing major.
                Thanks again, this would be great information to have available out on the
                web for others in the situation I was in.
                Keith
