0 Replies Latest reply on Jan 27, 2011 2:39 AM by sauravjaiswal2010
    Is it possible to map fonts to xml tags, like styleToXML tag mapping?
    sauravjaiswal2010
      HI,
      I am working on InDesign server API to export xml from InDesign file, and i have need to map fonts to xml tags so that i can properly map the bold and italic styles, which is manually done by the pager at the time of paging, since i have applied logic to map styles to tag, but that logic doesn't work with the manual work done by the pager. So the solution is that to make mapping between fonts ang tag. So anyone can tell me that, is it possible through InDesignServer API.
      Suman Saurav
