4 Replies Latest reply on Jan 31, 2011 6:24 AM by kglad
    Preloader Not Previewing
    Kwangle Level 1
      Hi All,
      I've written a simple preloader which I've put in its own movie clip. The code is as follows:
      yOrg = 14;
      yShift = 95;
      this.onEnterFrame = function() {
        byteTot = _root.getBytesTotal();
        byteLoa = _root.getBytesLoaded();
        loadVal = byteLoa/byteTot;
        loadPercent = Math.round(loadVal);
        if (loadPC>=1) {
            //starts movie
          _parent.play();
        } else {
          //moves masking object
          msk._y = yOrg-(yShift*loadVal);
          loadTxt.text= "LOADING "+loadPercent;
      The code works out a value between 0 and 1 called 'loadVal' this is used to animate a masking object a distance defined by a variable called 'yShift'. loadVal is rounded up to give a whole number that is displayed in a text field showing the percentage of the movie which has loaded.
      The preloader seems to be running and it will trigger the move to play when it completes but I can't see the preloader previewing in the Bandwidth Profiler, even when I set the data speed to be very slow. I've noticed this issue before and it is annoying as I need to see how the preloader looks and works.
      Any ideas?
