4 Replies Latest reply on Jan 27, 2011 7:24 PM by saisri2k2
    Sum columns in datagrid
    jfb00 Level 3
      Hi All,
      I have a DG with multiple columns (Numbers), the values are coming from an array collection.
      What is the best way to sum couple columns? like
      Column01 + Column02 = ColumnTotal
      I try using a labelFuction in the column like:
      private function sumColumns(item:Object, col:DataGridColumn):String {
         var tempNumber:Number = parseFloat(item.column01) + parseFloat(item.column02);
         return tempNumber.toString();
      But the result doesn't reflect in the arraycollection. Should I create the column with values at the time of received the results?
      If I do this, when I change the value in any of the columns 01 or 02 it doesn't change the total.
      Thanks for your help.
      Johnny
