2 Replies Latest reply on Jan 27, 2011 9:12 AM by the_wine_snob
    audio levels before / after export???
    liquidmonkey1
      hi,
      i'm using a background audio track in one of my adventure videos and when i am in PProCS5, the audio is at a good level BUT after i export the video, the audio seems to have gone up a few notches.
      any ideas?
      i only edit the audio levels in PProCS5 down in the audio section of the timeline. i add keyframes and then drag the audio level up and down. is that the right way to do it? is it possible to increase / decrease the audio level by more than the allowable 6dB?
      am i missing a setting when i export the audio?
      i mean, it should all sound the same, in PPro and when i play it in VLC or on my TV?
      thanks!
        • 1. Re: audio levels before / after export???
          Jim_Simon Level 8
          Playback software like VLC can sometimes process the audio, normalizing the volume levels.  Create a DVD export and use that to check.
          • 2. Re: audio levels before / after export???
            the_wine_snob Level 9
            In PrPro, there are at least 3 ways to adjust the Levels/Volume of the Audio:
            • At the Clip-level, one can Rt-click and adjust the Audio Gain. This is often the least desirable method, but can be used.
            • At the Clip-level, one can use the fixed Effect>Volume, and easily Keyframe this Effect. This can be done on the Timeline, or via the Effects Control Panel, and this is the most common method. Remember, this is at the Clip-level, so those Keyframes will follow that Clip, should it be moved.
            • At the Audio Track-level, one can use the Audio Mixer to automate the Sends, and set Track Keyframes to control the Levels. This will apply Track Keyframes, which will remain on that Track, even if one replaces the Clips on that Track. The frequency of these Track Keyframes can be adjusted in Edit>Preferences. Remember, these are Track Keyframes, unlike the Clip Keyframes above.
            The display of either Clip, or Track Volume Keyframes can be toggled in the Track Header.
            There are several other Levels/Volume Effects, like Normalize, but they are really something a bit different.
            I agree with Jim's suggestion on doing a DVD (I use RW discs to test - no more coasters), and test the Levels on my reference audio system.
