7 Replies Latest reply on Jan 27, 2011 9:06 AM by gkaiseril
    calculating totals: if, else statements
    CDBeyer Level 1
      OK, I have a form... with 7 fields called receipt1 through receipt7. I also have a total field called reimbursementTotal.
      I need a script to add all the receipt fields up and if the total is less than or equal to $150, give the reimbursementTotal field a value of the total, else give the reimbursementTotal a value of $150.
      I am not well versed in Adobe Scripting, some help would be appreciated.
      wtm
        • 1. Re: calculating totals: if, else statements
          George_Johnson MVP & Adobe Community Professional
          Try the following as the custom calculation script for the reimbursementTotal text field:
          // Custom calculation script
          (function () {
              // Calculate the total
              var total = 0;
              for (var i = 1, i < 8, i++) {
                  total += +getField("receipt" + i).value;
              // Set this field value based on the total
              event.value = (total > 150) ? 150 : total;
          • 2. Re: calculating totals: if, else statements
            CDBeyer Level 1
            SyntaxError: missing ; after for-looop initializer 6: at line 7
            it highlights: total += +getField("receipt" + i).value;
            • 3. Re: calculating totals: if, else statements
              You have to write a custom calculation script for the total.
              // define an array of field name to sum
              var aFields = new Array("FieldName0", "FieldName1", "FieldName2");
              // sum the values for the array of field names
              var nSum = 0; // variable for the sum
              var nValue; // variable for a specific field value
              // loop through each element of the field name array
              for(i = 0; i < aFields.length; i++) {
              nValue = this.getFeild( aFields[i] ).value; // get i element field value
              // see if value of field is a null string
              if( nValue.toString() == "") nValue = 0; // if null set to zero
              nSum = Number(nSum) + Number(nValue); // add value to sum
              } // end loop
              // set field value to the minimum of the or 150
              event.value = Math.min(nSum, 150);
              • 4. Re: calculating totals: if, else statements
                CDBeyer Level 1
                Console pops up with the following errors...
                this.getFeild is not a function
                8:AcroForm:reimbursementTotal:Calculate
                TypeError: this.getFeild is not a function
                • 5. Re: calculating totals: if, else statements
                  CDBeyer Level 1
                  Comma's were the issue on line 6...
                  Had to change code to the following
                  (function () {
                      var total = 0;
                      for (var i = 1; i < 8; i++) {
                  It worked!
                  Thanks so much,
                  wtm
                  • 6. Re: calculating totals: if, else statements
                    Oops! Sorry about that, but glad you got it working.
                    • 7. Re: calculating totals: if, else statements
                      The line:
                      Shoul read:
                      nValue = this.getField( aFields[i] ).value; // get i element field value
