1 Reply Latest reply on Jan 28, 2011 6:59 AM by Jim_Babbage
    adjusting combined paths?
    mediafred Level 1
      I connected two lines drawn with the Line tool by using modify > combine paths > join
      however, when I use the the subselection tool to adjust the anchors the two line separate?
        • 1. Re: adjusting combined paths?
          Jim_Babbage Level 4
          I'd recommend using the Pen tool rather than the line tool for a bit more control pver the paths, but nonetheless, if I use the line tool and choose Join I am able to control any of the four control points independently. If you want a control point to to effect other points when you are alter it, the points must be connect physically, or you must select the other points at the same time by holding shift to select mutliple points.
