2 Replies Latest reply on Jan 28, 2011 8:39 AM by nross_rain_83
    Spark Resize effect not working when used with resizeEffect style
    nross_rain_83
      I'm wanting to use the Spark Resize effect bound to the resizeEffect style property of a Panel component, but it doesn't animate when I resize the container.  If I change it to a MX Resize effect, it works perfectly.  Here's sample short sample code:
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx">
      <fx:Declarations>
      <s:Resize id="resizer" duration="500" />
      </fx:Declarations>
      <s:Panel id="panel"
      title="title"
      width="320"
      height="240"
      resizeEffect="{resizer}">
      <s:Button label="Grow" click="panel.width+=20; panel.height+=20" />
      </s:Panel>
      </s:WindowedApplication>
      This will not animate unless I change s:Resize to mx:Resize.  I assume the spark Resize effect is only intended to be used within Transitions or by using it's play() function programmatically in actionscript because both of those cases work fine.
      I would be ok with this, but I can't find anything on google that supports my theory.  Am I going crazy?
      Nate
