2 Replies Latest reply on Feb 4, 2011 1:33 PM by chris.campbell
    SQLErrorEvent problem
    Kristin95762 Level 1
      Not sure this is a performance issuer per se, but can't find an approriate venue.
      This is producing an error when I SELECT on a value which is not present in the database.
      Let's say, for simplicity, that my database table has columns authors.lName and authors.fName
      If I don't have a name that begins with some letter (let's say 'z') the program throws an error. The problem is that it's NOT using the error handler that is established. If I clear the default error window out, I can continue on with my program, but the default window is cryptic.
      Everything works fine until I enter a value that doesn't exist in the table. Ultimately I would just like the error handling to occur in the background and have the result return nothing to the listbox.
      Yes, this output appears in the output panel:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at testinputbox3_fla::MainTimeline/readResultHandler()[testinputbox3_fla.MainTimeline::frame 1:58]
      But I know it's bypassing my errorHandler because my literals are not in the error statement. i.e., my errorHandler function specifies trace("Error message: ", event.error.message);
      Of course, if I delete my error routine, the error outputs to the panel anyway.
      I feel I am in some way prevented from capturing this error so that I can handle it.
      what should I do?
      Here's my code:
      import flash.data.SQLConnection;
      import flash.data.SQLMode;
      import flash.data.SQLResult;
      import flash.events.SQLEvent;
      import flash.filesystem.File;
      import fl.data.DataProvider;
      import fl.controls.List;
      import flash.events.KeyboardEvent;
      import flash.events.Event;
      import flash.events.MouseEvent;
      import flash.net.URLRequest;
      import flash.display.Loader;
      import flash.display.NativeWindow;
      import flash.system.Capabilities;
      import flash.text.TextField;
      import flash.errors.SQLError;
      import flash.events.SQLErrorEvent;
      var appWindow:NativeWindow = this.stage.nativeWindow;
      appWindow.x = (Capabilities.screenResolutionX - appWindow.width) / 2;
      appWindow.y = (Capabilities.screenResolutionY - appWindow.height) / 2;
      var conn:SQLConnection = new SQLConnection();
      conn.addEventListener(SQLEvent.OPEN, readFromDatabase);
      conn.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      var dbFile:File = File.desktopDirectory.resolvePath("tarot.db");
      conn.openAsync(dbFile, SQLMode.UPDATE);
      txtIn.addEventListener(Event.CHANGE, changeHandler);
      var txtIn:TextField;
      txtIn.stage.focus = txtIn;
      var txtOut:String = "a";
      function readFromDatabase(event:Event):void
      var selectStmt:SQLStatement = new SQLStatement();
      selectStmt.sqlConnection = conn;
      // register listeners for the result and failure (status) events
      selectStmt.addEventListener(SQLEvent.RESULT, readResultHandler);
      selectStmt.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      // define the SQL text;
      selectStmt.text = "SELECT * FROM authors WHERE lName LIKE '" + txtOut + "%'";
      // execute the statement
      function readResultHandler(event:SQLEvent):void
      var result:SQLResult = event.target.getResult();
      var numResults:int = result.data.length;
      for (var i:int = 0; i < numResults; i++)
      var row:Object = result.data[i];
      var dataOut:String;
      dataOut = row.lName + ", " + row.fName;
      authorName.text = row.lName;
      function changeHandler(e:Event):void
      if (0 < txtIn.text.length)
      txtOut = txtIn.text;
      function errorHandler(event:SQLErrorEvent):void
      trace("Details: ", event.error.details);
