11 Replies Latest reply on Jan 31, 2011 11:50 AM by Flex harUI
    ComboBox Issue
    Flexy Flex Level 1
      Clicking on the combobox rapidly is making it not to open. The only way I can open it from there after is to recreate the component again.
      I am using the combobox to be displayed in one of the state in the title window popup. This combobox is used as FormItem in a form.
      The dataprovider for the combobox is being populated in the creationComplete handler of the title window.
      Code sample of the dataProvider:
      [Bindable] private var dp :  ArrayCollection;
      private function onCreationComplete(event : Event):void{
                      dp = new ArrayCollection();
                      var obj: Object =    new Object();
                      obj.label = "Line1";
                      obj.id = "Line1";
                      obj.width = 8500;
                      obj.height = 11000;
                      obj.shape = "Line";
                      documentAC.addItem(obj);
                      obj=    new Object();
                      obj.label = "Line2";
                      obj.id = "Line2";
                      obj.width = 8500;
                      obj.height = 14000;
                      obj.shape = "Line";
                      obj=    new Object();
                      obj.label = "Circle1";
                      obj.id = "Circle1";
                      obj.width = 8300;
                      obj.height = 11700;
                      obj.shape = "Circle";
                      obj=    new Object();
                      obj.label = "Circle2";
                      obj.id = "Circle2";
                      obj.width = 2000;
                      obj.height = 2000;
                      obj=    new Object();
                      obj.label = "Square1";
                      obj.id = "Square1";
                      obj.width = 4000;
                      obj.height = 4000;
                      obj.shape = "Square";
                      obj=    new Object();
                      obj.label = "Square2";
                      obj.id = "Square2";
                      obj.width = 4000;
                      obj.height = 6000;
                      obj=    new Object();
                      obj.label = "Rectangle1";
                      obj.id = "Rectangle1";
                      obj.width = 4000;
                      obj.height = 6000;
                      obj.shape = "Rectangle";
      FormItem in which the combobox is used:
      <mx:FormItem id="shapeTypeFI" label="Shape Type">
              <mx:ComboBox id="shapeTypeCB" dataProvider="{documentAC}" labelField="label"
                          change="onShapeTypeCBChange(event)" selectedIndex="{documentTypeIndex}"/>
      </mx:FormItem>
      Amar.
        • 1. Re: ComboBox Issue
          miguel8312 Level 3
          is "documentAC" an array collection where is that in the code?
          Miguel
          Message was edited by: miguel8312
          • 2. Re: ComboBox Issue
            Flexy Flex Level 1
            Sorry dp itself is documentAC. I pasted dp for documentAC. My fault
            • 3. Re: ComboBox Issue
              miguel8312 Level 3
              also where is this function???
              "onShapeTypeCBChange(event)"  please post all your code is very hard to help when you only see half or less info.
              Miguel
              • 4. Re: ComboBox Issue
                Flexy Flex Level 1
                I see this issue only on clicking the combo rapidly and not while clicking selecting the label inside the combo.
                So in this scenario "onShapeTypeCBChange(event)" never gets called.
                Amar.
                • 5. Re: ComboBox Issue
                  miguel8312 Level 3
                  Amar
                  its very hard to replicate exactcly what you see unless i see your exact source code.
                  i try this and clicked the combo box like a mad man  everything worked fine for me?...
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" applicationComplete="onCreationComplete(event);" minWidth="955" minHeight="600">
                  <mx:Script>
                    <![CDATA[
                  import mx.collections.ArrayCollection;
                  [Bindable]
                     public var dp :  ArrayCollection;
                     //public var dp2 :  ArrayCollection;
                  private function onCreationComplete(event:Event):void{
                  var obj:Object =new Object();
                  obj.id = "Line1";
                  obj.width = 8500;
                  obj.height = 11000;
                  obj.shape = "Line";
                  dp.addItem(obj);
                  obj=    new Object();
                  obj.id = "Line2";
                  obj.width = 8500;
                  obj.height = 14000;
                  obj.shape = "Line";
                  dp.addItem(obj);
                  obj=    new Object();
                  obj.id = "Circle1";
                  obj.width = 8300;
                  obj.height = 11700;
                  dp.addItem(obj);
                  obj=    new Object();
                  obj.id = "Circle2";
                  obj.width = 2000;
                  obj.height = 2000;
                  dp.addItem(obj);
                  obj=    new Object();
                  obj.id = "Square1";
                  obj.width = 4000;
                  obj.height = 4000;
                  dp.addItem(obj);
                  obj=    new Object();
                  obj.id = "Square2";
                  obj.width = 4000;
                  obj.height = 6000;
                  dp.addItem(obj);
                  obj=    new Object();
                  obj.width = 4000;
                  obj.height = 6000;
                  dp.addItem(obj);
                  shapeTypeCB.dataProvider = dp;
                  </mx:Script>
                    <mx:ComboBox id="shapeTypeCB"  labelField="label"
                  </mx:FormItem>
                  </mx:Application>
                  perhaps your pc cant't render the ui so fast. what kind of pc you have you can try on another pc and see if the same behavior occurs...
                  Miguel
                  • 6. Re: ComboBox Issue
                    Flexy Flex Level 1
                    Here are the files. Load the application and click rapidly on the Document type combo without waiting for the combo to open.
                    Amar.
                    • 7. Re: ComboBox Issue
                      miguel8312 Level 3
                      where are teh files?
                      • 8. Re: ComboBox Issue
                        Flex harUI Adobe Employee
                        That's a bug that got fixed recently.  Should be in the Hero release.
                        • 9. Re: ComboBox Issue
                          Flexy Flex Level 1
                          Here is the code:
                          <!ComboTest.mxml>
                                              verticalGap="20"
                                              backgroundColor="0xFFFFFF" creationComplete="init()">
                               <mx:Script>
                                    <![CDATA[
                                         import mx.managers.PopUpManager;
                                         private function init():void{
                                              var dp:DocumentPopup = PopUpManager.createPopUp(this, DocumentPopup, true) as DocumentPopup;
                                              PopUpManager.centerPopUp(dp);
                               </mx:Script>
                          </mx:Application>
                          <!-- DocumentPopup.mxml -->
                          <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml"
                                              title="Document Dimension"
                                              headerColors="[#8C8C8C,#8C8C8C]" borderAlpha="1"
                                              backgroundAlpha="1" close="removePopupHandler()" creationComplete="onCreationComplete(event)"
                                              showCloseButton="true">
                               <mx:Script>
                                    <![CDATA[
                                         import mx.events.ItemClickEvent;
                                         import mx.events.ListEvent;
                                         import mx.resources.ResourceManager;
                                         public static const EVENT_LABEL_DIMENSIONS_POPUP_OK_BUTTON_CLICKED:String = "labelDimensionsPopupOkClicked";
                                         public static const EVENT_LABEL_DIMENSIONS_POPUP_CANCEL_BUTTON_CLICKED:String = "labelDimensionsPopupCancelClicked";
                                          private var documentAC :  ArrayCollection;
                                          private var documentBorderAC :  ArrayCollection;
                                          private var documentTypeIndex:int = 6;
                                          private var documentBorderIndex:int = 0;
                                         public var documentBottom : Number;
                                         public var documentRight : Number;
                                         public var documentOrientation : String;
                                         public var documentShape : String;
                                              documentAC = new ArrayCollection();
                                              var document : Object =     new Object();
                                              document.label = "Letter";
                                              document.id = "Letter";
                                              document.width = 8500;
                                              document.height = 11000;
                                              document.shape = "Rectangle";
                                              documentAC.addItem(document);
                                              document =     new Object();
                                              document.label = "Legal";
                                              document.id = " Legal ";
                                              document.height = 14000;
                                              document.label = "A4";
                                              document.id = "A4";
                                              document.width = 8300;
                                              document.height = 11700;
                                              document.label = "2X2";
                                              document.id = "2X2";
                                              document.width = 2000;
                                              document.height = 2000;
                                              document.shape = "Rounded Rectangle";
                                              document.label = "4X4";
                                              document.id = "4X4";
                                              document.width = 4000;
                                              document.height = 4000;
                                              document.label = "4X6";
                                              document.id = "4X6";
                                              document.height = 6000;
                                              document.label = "Custom";
                                              document.id = "Custom";
                                              portraitRB.selected = true;
                                              documentBorderAC = new ArrayCollection();
                                              documentBorderAC.addItem({label:"Rectangle",id:"Rectangle",value:"Rect angle"});
                                              documentBorderAC.addItem();
                                         private function onOkButtonClickHandler():void {
                                              PopUpManager.removePopUp(this);
                                              if(documentTypeCB.selectedItem.id == "file.menu.new.popup.documentType.combo.custom.label"){
                                                   documentOrientation = null;
                                                   var shapeObj:Object = documentBorderAC.getItemAt(documentBorderCB.selectedIndex);
                                                   documentShape = shapeObj.value;
                                              }else{
                                                   var obj : Object = documentTypeCB.selectedItem;
                                                   //documentType = obj.value as String;
                                                   if(orientationRBGroup.selection.value == "file.menu.new.popup.orientation.radioButton.portrait.label"){
                                                        documentBottom = obj.height;
                                                        documentRight = obj.width;
                                                   }else if(orientationRBGroup.selection.value == "file.menu.new.popup.orientation.radioButton.landscape.label"){
                                                        documentBottom = obj.width;
                                                        documentRight = obj.height;
                                                   documentShape = obj.shape;
                                              /Dispatching an event so its Handled in DataOutputContainer/
                                              var event:Event;
                                              event = new Event(EVENT_LABEL_DIMENSIONS_POPUP_OK_BUTTON_CLICKED);
                                              dispatchEvent(event);
                                         private function removePopupHandler():void {
                                              var event:Event;
                                              event = new Event(EVENT_LABEL_DIMENSIONS_POPUP_CANCEL_BUTTON_CLICKED);
                          • Event handler function to select the orientation based on the radio button clicked.
                                         private function orientationHandler(event:ItemClickEvent):void {
                                                   documentOrientation = "Portrait";
                                                   documentOrientation = "Landscape";
                                         private function onDocumentTypeCBChange(event : ListEvent=null):void{
                                                   currentState = documentTypeCB.selectedItem.id;
                                                   documentBottom = new Number(11000);
                                                   documentRight = new Number(6000);
                                              }else{
                                                   currentState = "";
                                                   documentRight = new Number(obj.width as Number);
                                                   documentBottom = new Number(obj.height as Number);
                                         private function onDocumentTypeCBClick(event:Event):void{
                                              documentTypeCB.setFocus();
                                         private function onDocumentBorderCBChange(event : ListEvent):void{
                                              /* if(documentBorderCB.selectedLabel == "Rectangle"){
                                              documentCornerRadius = LDConstants.DEFAULT_DOC_NO_CORNER_RADIUS;
                                              documentBorderStyle = LDConstants.DEFAULT_DOC_NO_BORDER_STYLE;
                                              }else if(documentBorderCB.selectedLabel == "Rounded-Rectangle"){
                                              documentCornerRadius = LDConstants.DEFAULT_DOC_CORNER_RADIUS;
                                              documentBorderStyle = LDConstants.DEFAULT_DOC_BORDER_STYLE;
                               </mx:Script>
                               <mx:transitions>
                                    <mx:Transition fromState="" toState="">
                                         <mx:Parallel targets="{[documentWidthFI,documentHeightFI,documentBorderFI]}">
                                              <mx:WipeDown duration="1000"/>
                                              <mx:Fade duration="1000"/>
                                         </mx:Parallel>
                                    </mx:Transition>
                                    <mx:Transition fromState="file.menu.new.popup.documentType.combo.custom.label" toState="*">
                                         <mx:Parallel targets="{[orientationFI]}">
                                              <mx:WipeUp duration="1000"/>
                                         </mx:Parallel>
                                    </mx:Transition>
                               </mx:transitions>
                               <mx:states>
                                    <mx:State name="file.menu.new.popup.documentType.combo.custom.label">
                                         <mx:RemoveChild target=""/>
                                         <mx:AddChild relativeTo="" position="after">                     <mx:FormItem id="documentWidthFI" label="Width">                          <mx:TextInput id="documentWidthTI" width="150" text="{documentRight/1000}"/>                     </mx:FormItem>                </mx:AddChild>                <mx:AddChild relativeTo="" position="after">
                                              <mx:FormItem id="documentHeightFI" label="Height">
                                                   <mx:TextInput id="documentHeightTI" width="150" text="{documentBottom/1000}"/>
                                              </mx:FormItem>
                                         </mx:AddChild>
                                              <mx:FormItem id="documentBorderFI" label="Document Border">
                                                   <mx:ComboBox id="documentBorderCB" dataProvider=""
        width="150" change="onDocumentBorderCBChange(event)" selectedIndex=""/>
                                              </mx:FormItem>
                                         </mx:AddChild>
                                    </mx:State>
                               </mx:states>
                               <mx:VBox width="100%" height="100%" horizontalAlign="center">
                                    <mx:Form id="documentForm" width="100%">
                                         <mx:FormItem id="documentTypeFI" label="Document Type">
                                              <mx:ComboBox id="documentTypeCB" dataProvider="" labelField="label"
                                                              change="onDocumentTypeCBChange(event)" selectedIndex=""/>
                                         </mx:FormItem>
                                         <mx:FormItem id="orientationFI" label="Orientation">
                                              <mx:RadioButtonGroup id="orientationRBGroup" itemClick="orientationHandler(event)"/>
                                              <mx:RadioButton groupName="orientationRBGroup" id="portraitRB" value="file.menu.new.popup.orientation.radioButton.portrait.label"
        label="Portrait"
        width="150" />
                                              <mx:RadioButton groupName="orientationRBGroup" id="landscapeRB" value="file.menu.new.popup.orientation.radioButton.landscape.label"
        label="Landscape"
        width="150"/>
                                         </mx:FormItem>
                                    </mx:Form>
                                    <mx:HBox horizontalAlign="center">
                                         <mx:Button label="Ok"
                                                      click="onOkButtonClickHandler()"/>
                                         <mx:Spacer width="20"/>
                                         <mx:Button label="Cancel"
                                                      click="removePopupHandler()"/>
                                    </mx:HBox>
                               </mx:VBox>
                          </mx:TitleWindow>
                          Amar.
                          • 10. Re: ComboBox Issue
                            Flexy Flex Level 1
                            This would be as part of next Flash or SDK release ?
                            • 11. Re: ComboBox Issue
                              Should be in the next SDK release.
