2 Replies Latest reply on Mar 7, 2011 5:49 AM by robamp
    Getting Started from the Administrator's Perspective
    robamp
      I'm new to Contribute. I have enabled WebDav on IIS 6 and can connect using Microsoft Explorer, which automatically passes my Active Directory credentials. Using CS5 to try and connect to the website virtual directory fails when I try to type in my Windows username and password in the Connection Wizard, saying "Please make sure that you have sufficient permissions. I'm a bit confused in the first place...do I need to install something else on the server (e.g. Contribute, or Contribute Publishing Server)? Is there a guide somewhere that deals with the administrative side of Contribute?
        • 1. Re: Getting Started from the Administrator's Perspective
          Krishna Prasad B V Level 3
               Can you enable Basic Authentication as well in IIS? And then check whether you are able to create connection to the website.
          • 2. Re: Getting Started from the Administrator's Perspective
            robamp Level 1
            Thanks for taking a try at this, but I've solved my issue (forgot about this thread though!).
            My solution:
            To Configure Contribute:
                 1. Install webDAV on server
                 2. Apply permissions for IIS6 server account on physical directory
                      a. Read
                      b. Read & Execute
                      c. List
                      d. Write
                      e. Modify
                      f. Write and Script Source access (to edit dynamic pages)
                 3. IIS Virtual Directory requires:
                      a. Read
                      b. Directory Browsing
                      c. Write
                      d. Indexing
            Turn on WebClient service to Automatic start on clients using Contribute
            Thanks!
