3 Replies Latest reply on Jan 30, 2011 12:11 AM by Flex harUI
    Flex kbd event help
    billiam407
      Using the example I found at http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf64a29-7fdb.html, I modified my Flex app to listen for keyboard shortcuts being pressed.  It works but only after the user clicks on a blank spot on the web page.  Why?  This is for accessibility and if I make my blind users click using a mouse, it defeats the purpose... Is there a fix for this so that the keystrokes are detected without clicking on the page or am I doing something wrong?
      Here is my code:
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx"
      creationComplete="init()"
      minWidth="
      955" minHeight="600">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script source="BGBasicPlay.as" >
      </fx:Script>
      <fx:Script>
      <![CDATA[
      import mx.core.FlexGlobals;
      protected function init():void {
      FlexGlobals.topLevelApplication.addEventListener(KeyboardEvent.KEY_DOWN,keysPressed);
      // has to set focus then click to work!!!
      protected function keysPressed(evt:KeyboardEvent):void {
      txtKeys.text = evt.keyCode +
      "/" + evt.charCode;
      var nKeyPressed:int = evt.keyCode;
      if (nKeyPressed == 80 && evt.shiftKey == true)
      PlaySong2();
      else {
      if (nKeyPressed == 80 && evt.shiftKey == false)
      PlaySong();
      </fx:Script>
      <s:Button x="250" y="105" label="Play Song" id="btnPlay" />
      <s:TextInput x="224" y="63" id="txtKeys"/>
      </s:Application>
        • 1. Re: Flex kbd event help
          Flex harUI Adobe Employee
          See past threads on browser focus
          • 2. Re: Flex kbd event help
            billiam407 Level 1
            After wading through over 100 posts, most were either unanswered or had general replies such as yours with no real useful information on how to do this.
            The closest answer I found was this:
            "This is a known bug of Flash Player/Mozilla browsers - SWF does not receive focus at start-up.
            I am not aware about any suitable workaround available. The closest workaround is to place a button and allow user to click on it which will give SWF a focus.
            PS It works in IE without any problem. Good old MS "
            That answer was posted in 2008.  It is now 2011 and you would think that this would have a fix by now... especially with all of the pressure for accessibility.  IE 8 apparently now has this problem as well.
            So, instead of sending me on a wild goose chase, it would really have been more helpful to have received an actual answer from you.
            • 3. Re: Flex kbd event help
              I'm not the expert in this area, and my impression is that the capabilities
              of the browsers is changing daily.  Therefore, I don't have a definitive
              answer for you.  I think I've written this summary before, but basically my
              understanding is this:
              The browsers tend to not give the flash player focus.  There is javascript
              you can run on IE and maybe a few other browsers to assign focus to the
              player.  I have seen conflicting reports on whether it works on recent
              versions of FireFox, it didn't work on older ones.
