5 Replies Latest reply on Jan 31, 2011 11:56 AM by heylawn
    InDesign 2.0 doesn't launch, but Automator does--???
    heylawn
      I know you must be thinking... InDesign CS2, but actually I am still using InDesign 2. Some files are just not built in anything too new that we receive.
      The issue is, when I have lately tried to launch ID2, Automator window comes up instead. I have no idea how to get out of the Automator mode to simply open ID2. I have ID2, IDCS and IDCS2 on one machine. Platform is Mac 10.4.11 (Tiger). The other versions seem to launch normally...
      Has anybody got a suggestion?
      Thanks.
        • 1. Re: InDesign 2.0 doesn't launch, but Automator does--???
          Muppet Mark-QAl63s Level 4
          You may be better off asking this in the ID general forum where it will reach a wider audience… You say your on a mac so have you done a "comm+i" on an ID CS2 file and set the "open with:" drop down the correct app? and apply/change all… If this fails to work then you may have to trash and remake your "launch services" pref's file. This should be located in your user preferences "com.apple.LaunchServices.plist"
          • 2. Re: InDesign 2.0 doesn't launch, but Automator does--???
            Harbs. Level 6
            Have you used 2.0 on this machine before? I have not tried to launch 2.0 in years, and I would not be surprised if it does not work on 10.4. I was created when OS 9 was still around...
            Harbs
            • 3. Re: InDesign 2.0 doesn't launch, but Automator does--???
              heylawn Level 1
              Muppet Mark:
              I can't check the get info command right now (Mac's at workplace).. but thank you for your suggestions. It might be that simple.
              • 4. Re: InDesign 2.0 doesn't launch, but Automator does--???
                heylawn Level 1
                Harbs
                To Harbs:
                I have actually used ID 2.0, but that has been months ago. Something has changed, but I'm not sure what exactly. With both yours and Muppet Mark's suggestions, I will try some more trouble shooting. Thanks.
                • 5. Re: InDesign 2.0 doesn't launch, but Automator does--???
                  heylawn Level 1
                  Harbs
                  Harbs, you have hit the nail on the head. I sheepishly admit my mistaken memory of having run InD 2 on current machine, but we have had musical Macs (remember musical chairs?) and the last swap I don't think I migrated my apps with that knowledge in mind. It definitely is not compatible with OS Tiger. It would not let me re-associate program at all and I see Adobe compatibility is only for up to Jaguar...
                  Sorry for the time-waster, I should have double checked all the obvious first steps before starting this thread...
