4 Replies Latest reply on Jan 29, 2011 8:54 AM by kiran7881
    Is it possible to skip executing  custom itemRenderer Configured for a Datagrid column ??
    kiran7881 Level 1
      Hi ,
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" horizontalAlign="center" verticalAlign="middle" xmlns:comps="comps.*">
          <mx:Array id="sampleData">
              <mx:String>Row 1</mx:String>
              <mx:String>Row 2</mx:String>
              <mx:String>Row 3</mx:String>
              <mx:String>Row 4</mx:String>
              <mx:String>Row 5</mx:String>
              <mx:String>Row 6</mx:String>
              <mx:String>Row 7</mx:String>
          </mx:Array>
          <mx:VBox>
              <mx:DataGrid width="500" height="227" dataProvider="{sampleData}">
                  <mx:columns>
                      <mx:DataGridColumn headerText="Actual Row"/>
                      <mx:DataGridColumn headerText="ItemRenderer" >
                            <mx:itemRenderer>
                              <mx:Component>
                                  <comps:RightTestRenderer>
                                  </comps:RightTestRenderer>
                              </mx:Component>
                            </mx:itemRenderer>
                      </mx:DataGridColumn>
                  </mx:columns>
              </mx:DataGrid>
          </mx:VBox>
      </mx:Application>
      RightTestRenderer.mxml
      <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%" horizontalAlign="left" verticalAlign="middle">
          <mx:VBox id="jai" height="100%" width="100%">
              <mx:Image source="images/canvas.png" visible="true" height="100%" width="100%"/>
          </mx:VBox>
      </mx:HBox>
      Based on some conditon , i want to skip executing  itemRenderer RightTestRenderer.mxml at Runtime ??
      Is this possible ??
      Please help .
        • 1. Re: Is it possible to skip executing  custom itemRenderer Configured for a Datagrid column ??
          Abhinav Sharma Level 2
          I didn't get your question properly. As much I understand you would have to handle it in ItemRender.
          One possible way (not the best):
          1. Create application Level public variable. say - boolShouldRender. This will be checked inside Item Renderer.
          2. Acces it in Item renderer and customize it according to requirement.
              <mx:VBox id="myvbox" visible="{parentApplication.boolShouldRender}">
                  <mx:Image source="images/canvas.png" />
              </mx:VBox>
          Thanks.
          Abhinav
          • 2. Re: Is it possible to skip executing  custom itemRenderer Configured for a Datagrid column ??
            kiran7881 Level 1
            Anyways , thanks for the reply .
                        <mx:columns>
                            <mx:DataGridColumn id="hh" headerText="ItemRenderer"  >
                                  <mx:itemRenderer >
                                    <mx:Component>
                                        <comps:RightTestRenderer  enabled="false"  includeInLayout = "false" visible = "false" show="false">
                                    </mx:Component>
                                  </mx:itemRenderer>
                        </mx:columns>
                    </mx:DataGrid>
            My question was actually depending on the condition , i dont to skip executing the itemRenderer on a condition . I dont want to execute this below .
            <mx:itemRenderer >
                                     <mx:Component>
                                     </mx:Component>
                                   </mx:itemRenderer>
            • 3. Re: Is it possible to skip executing  custom itemRenderer Configured for a Datagrid column ??
              saisri2k2 Level 4
              Are yu trying to hide something on a condition? like the Image in tis case?
              if so override the data property in the itemrenderer and validate te conditon in the data to show/not show the image.
              • 4. Re: Is it possible to skip executing  custom itemRenderer Configured for a Datagrid column ??
                kiran7881 Level 1
                Thanks , I have seen that . But my requirement is different .
                I have solved that , by chnaging ItemRenderer at runtime using ClassFactory .
