2 Replies Latest reply on Jan 31, 2011 6:51 PM by m@rakame
    Missing base class Events (flash.events) | Flex 4.1 SDK | Flex Builder 3
    m@rakame Level 1
      Hello,
      I am experience the following problem, I am not able locate or find base class Events when I do "import flash.events;" - autocomplete does not work as well. in import flash. only available - flash.errors and flash.text
      However if I switch from Flex 4.1 SDK to Flex 3.2 SDK then no problem and I can add flash.events
      Flex 4.1 SDK version is 4.1.0.65265, I also tried Flex 4.0 SDK, the same problem not able to find events.
      Require flash player version I tried both: 10.0.0 and 10.1.0 nothing helped.
      Could you please suggest what might be wrong. Unfortunately not able to find this info in the forum or google
      Thank you
      Regards,
      Marakame
