4 Replies Latest reply on Feb 25, 2011 10:49 AM by Scott-C-UK
    Crashes when bouncing down
    Scott-C-UK
      I've had NUMEROUS problems over the last month or so with bouncing down at the end of a session.
      The bounce will start, and in some instances, the progress will get to 100% before crashing, though the file is created and put in the Bounced Files folder.
      Other times, the bounce crashes after only 20 or 30% and no file is created.
      This has become quite a problem and is now the norm, rather than an unexpected event.
      I seem to have more success and don't encounter a crash when:
      - I delete as many unused tracks as possible.
      - I close all unused media
      - I remove any audio from the timeline AFTER the actual part of the audio that I want to bounce
      - I zoom to make the view as close to just the audio I am bouncing down as possible.
      I save my finished files by bouncing to a new track and then saving the resulting file, but mixing down to a new file has had a similar effect in the past when I have had problems.
      Included here is a crash report.  Any suggestions why this could be?  It is driving me crazy.
      best
      sc
      Process:         Adobe Audition [186]
      Path:            /Applications/Adobe Audition.app/Contents/MacOS/Adobe Audition
      Identifier:      com.adobe.Audition.4.0
      Version:         4.0x10 (4.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [106]
      Date/Time:       2011-01-28 10:25:59.053 +0000
      OS Version:      Mac OS X 10.6.6 (10J567)
      Report Version:  6
      Interval Since Last Report:          109147 sec
      Crashes Since Last Report:           2
      Per-App Interval Since Last Report:  50056 sec
      Per-App Crashes Since Last Report:   1
      Anonymous UUID:                      407C9472-0847-4483-B6F1-2E0B2311DDC5
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000858ce10
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   libSystem.B.dylib             0x912d00c5 small_malloc_from_free_list + 133
      1   libSystem.B.dylib             0x912ccad9 szone_malloc_should_clear + 2271
      2   libSystem.B.dylib             0x912d0e93 szone_realloc + 2251
      3   libSystem.B.dylib             0x912d0588 malloc_zone_realloc + 88
      4   com.apple.CoreGraphics        0x92eea220 mem_heap_realloc + 69
      5   com.apple.CoreGraphics        0x92e7ecb9 shape_union + 547
      6   com.apple.CoreGraphics        0x92e7ea8b shape_union_with_bounds + 151
      7   com.apple.CoreGraphics        0x92e7e967 CGSUnionRegionWithRect + 511
      8   com.apple.AppKit              0x9884fa84 -[NSRegion addRect:] + 215
      9   com.apple.AppKit              0x9884f87b -[NSWindow _setNeedsDisplayInRect:] + 387
      10  com.apple.AppKit              0x9884e6f8 -[NSView setNeedsDisplayInRect:] + 340
      11  com.adobe.dvaui.framework     0x00649628 dvaui::ui::OS_View::UI_Invalidate(dvacore::geom::RectT<int> const*, dvacore::utility::Flags<unsigned int>) + 440
      12  com.adobe.dvaui.framework     0x00627b40 dvaui::ui::UI_SubView::UI_Invalidate(dvacore::geom::RectT<int> const*, dvacore::utility::Flags<unsigned int>) + 816
      13  com.adobe.dvaui.framework     0x00627b40 dvaui::ui::UI_SubView::UI_Invalidate(dvacore::geom::RectT<int> const*, dvacore::utility::Flags<unsigned int>) + 816
      14  com.adobe.dvaui.framework     0x005b0ff9 dvaui::ui::UI_Node::UI_DisabledStateChanged() + 41
      15  com.adobe.dvaui.framework     0x005bf40a dvaui::ui::UI_Node::UI_SetDisabled(bool) + 42
      16  AuUI                          0x03aeeca6 aui::SelectionViewControls::EnableUI() + 54
      17  AuUI                          0x03b00d4f boost::detail::function::void_function_obj_invoker2<boost::_bi::bind_t<void, boost::_mfi::mf2<void, aui::SelectionViewControls, boost::intrusive_ptr<app::Document>, bool>, boost::_bi::list3<boost::_bi::value<aui::SelectionViewControls*>, boost::arg<1> (*)(), boost::arg<2> (*)()> >, void, boost::intrusive_ptr<app::Document>, bool>::invoke(boost::detail::function::function_buffer&, boost::intrusive_ptr<app::Document>, bool) + 95
      18  AuApplication                 0x026b68cf boost::function2<void, boost::intrusive_ptr<app::Document>, bool>::operator()(boost::intrusive_ptr<app::Document>, bool) const + 79
      19  AuApplication                 0x026b7920 boost::signal2<void, boost::intrusive_ptr<app::Document>, bool, boost::last_value<void>, int, std::less<int>, boost::function<void ()(boost::intrusive_ptr<app::Document>, bool)> >::operator()(boost::intrusive_ptr<app::Document>, bool) + 2496
      20  AuApplication                 0x026b2912 app::Document::SendBusyStateChangedSignal() + 50
      21  AuApplication                 0x0270454b app::MultitrackDocument::OnJobProcessingFinished(boost::intrusive_ptr<abe::AsyncOperation >, bool) + 91
      22  AuApplication                 0x0276c95f boost::detail::function::void_function_obj_invoker2<boost::_bi::bind_t<void, boost::_mfi::mf2<void, app::MultitrackDocument, boost::intrusive_ptr<abe::AsyncOperation>, bool>, boost::_bi::list3<boost::_bi::value<app::MultitrackDocument*>, boost::arg<1> (*)(), boost::arg<2> (*)()> >, void, boost::intrusive_ptr<abe::AsyncOperation>, bool>::invoke(boost::detail::function::function_buffer&, boost::intrusive_ptr<abe::AsyncOperation>, bool) + 95
      23  AuApplication                 0x0265b2ab boost::function2<void, boost::intrusive_ptr<abe::AsyncOperation>, bool>::operator()(boost::intrusive_ptr<abe::AsyncOperation>, bool) const + 75
      24  AuApplication                 0x0265c6c0 boost::signal2<void, boost::intrusive_ptr<abe::AsyncOperation>, bool, boost::last_value<void>, int, std::less<int>, boost::function<void ()(boost::intrusive_ptr<abe::AsyncOperation>, bool)> >::operator()(boost::intrusive_ptr<abe::AsyncOperation>, bool) + 2496
      25  AuApplication                 0x02659418 app::Asset::NotifyProcessingJobFinished(boost::intrusive_ptr<abe::AsyncOperation>, boost::intrusive_ptr<app::Asset>) + 120
      26  AuApplication                 0x0265a2a9 boost::detail::function::void_function_obj_invoker1<boost::_bi::bind_t<void, void (*)(boost::intrusive_ptr<abe::AsyncOperation>, boost::intrusive_ptr<app::Asset>), boost::_bi::list2<boost::arg<1> (*)(), boost::_bi::value<boost::intrusive_ptr<app::Asset> > > >, void, boost::intrusive_ptr<abe::AsyncOperation> >::invoke(boost::detail::function::function_buffer&, boost::intrusive_ptr<abe::AsyncOperation>) + 57
      27  com.adobe.aubackend.framework 0x01ff0550 boost::function1<void, boost::intrusive_ptr<abe::AsyncOperation> >::operator()(boost::intrusive_ptr<abe::AsyncOperation>) const + 64
      28  com.adobe.aubackend.framework 0x01ff13d8 boost::signal1<void, boost::intrusive_ptr<abe::AsyncOperation>, boost::last_value<void>, int, std::less<int>, boost::function<void ()(boost::intrusive_ptr<abe::AsyncOperation>)> >::operator()(boost::intrusive_ptr<abe::AsyncOperation>) + 2472
      29  com.adobe.aubackend.framework 0x01feb726 abe::AsyncOperation::NotifyProcessFinished() + 54
      30  com.adobe.aubackend.framework 0x01ff388d boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::intrusive_ptr<abe::AsyncOperation>, abe::AsyncOperation::AsyncOperationStatus, abe::AsyncOperationError), boost::_bi::list3<boost::_bi::value<boost::intrusive_ptr<abe::AsyncOperation> >, boost::_bi::value<abe::AsyncOperation::AsyncOperationStatus>, boost::_bi::value<abe::AsyncOperationError> > >, void>::invoke(boost::detail::function::function_buffer&) + 77
      31  com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      32  com.adobe.dvacore.framework   0x00133ee4 dvacore::threads::(anonymous namespace)::FunctionQueue::ExecuteOneFunction(bool) + 756
      33  com.adobe.dvacore.framework   0x0012f58e boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<bool, boost::_mfi::mf1<bool, dvacore::threads::(anonymous namespace)::FunctionQueue, bool>, boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::(anonymous namespace)::FunctionQueue> >, boost::_bi::value<bool> > >, void>::invoke(boost::detail::function::function_buffer&) + 62
      34  com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      35  com.adobe.dvacore.framework   0x00134337 dvacore::threads::(anonymous namespace)::RunLoopAdaptor::Execute(__CFRunLoopTimer*, void*) + 23
      36  com.apple.CoreFoundation      0x97467adb __CFRunLoopRun + 8059
      37  com.apple.CoreFoundation      0x97465464 CFRunLoopRunSpecific + 452
      38  com.apple.CoreFoundation      0x97465291 CFRunLoopRunInMode + 97
      39  com.apple.HIToolbox           0x91873004 RunCurrentEventLoopInMode + 392
      40  com.apple.HIToolbox           0x91872dbb ReceiveNextEventCommon + 354
      41  com.apple.HIToolbox           0x91872c40 BlockUntilNextEventMatchingListInMode + 81
      42  com.apple.AppKit              0x9887678d _DPSNextEvent + 847
      43  com.apple.AppKit              0x98875fce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
      44  com.apple.AppKit              0x98838247 -[NSApplication run] + 821
      45  com.adobe.exo.framework       0x01924c87 exo::app::OS_AppBase::RunEventLoop() + 71
      46  AuUI                          0x03469460 AudMacMain(int, char**) + 608
      47  com.adobe.Audition.4.0        0x00002ecd main + 93
      48  com.adobe.Audition.4.0        0x00002c66 start + 54
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x912ee982 kevent + 10
      1   libSystem.B.dylib             0x912ef09c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib             0x912ee559 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib             0x912ee2fe _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib             0x912edd81 _pthread_wqthread + 390
      5   libSystem.B.dylib             0x912edbc6 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib             0x912f60a6 __semwait_signal + 10
      1   libSystem.B.dylib             0x912f5d62 _pthread_cond_wait + 1191
      2   libSystem.B.dylib             0x912f79f8 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore 0x90aa951e TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore 0x90a94ea5 TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore 0x90a90873 MPWaitOnQueue + 250
      6   com.adobe.dvacore.framework   0x001442fa dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      7   com.adobe.dvacore.framework   0x0014018a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      8   com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      9   com.adobe.dvacore.framework   0x0013cbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      10  com.adobe.dvacore.framework   0x0013daf0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      11  ...obe.boost_threads.framework 0x0005d6fd thread_proxy + 141
      12  libSystem.B.dylib             0x912f585d _pthread_start + 345
      13  libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 3:
      Thread 4:
      0   libSystem.B.dylib             0x912c80fa mach_msg_trap + 10
      1   libSystem.B.dylib             0x912c8867 mach_msg + 68
      2   com.apple.CoreFoundation      0x9746637f __CFRunLoopRun + 2079
      3   com.apple.CoreFoundation      0x97465464 CFRunLoopRunSpecific + 452
      4   com.apple.CoreFoundation      0x97465291 CFRunLoopRunInMode + 97
      5   com.apple.audio.CoreAudio     0x95d8496e HALRunLoop::OwnThread(void*) + 162
      6   com.apple.audio.CoreAudio     0x95d704a4 CAPThread::Entry(CAPThread*) + 140
      7   libSystem.B.dylib             0x912f585d _pthread_start + 345
      8   libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 5:
      2   ....audio_hijack_server.hermes 0x067453cf ah_serv_loop + 161
      3   libSystem.B.dylib             0x912f585d _pthread_start + 345
      4   libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 6:
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      0   com.adobe.aubackend.framework 0x02031d9d abe::afs::AudioFileCache::Service(bool) + 77
      1   com.adobe.aubackend.framework 0x0204196a abe::afs::AudioFileSystem::CacheServices() + 122
      2   com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      3   com.adobe.dvacore.framework   0x0014438a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
      4   com.adobe.dvacore.framework   0x0014018a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      5   com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      6   com.adobe.dvacore.framework   0x0013cbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      7   com.adobe.dvacore.framework   0x0013daf0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      8   ...obe.boost_threads.framework 0x0005d6fd thread_proxy + 141
      9   libSystem.B.dylib             0x912f585d _pthread_start + 345
      10  libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 11:
      Thread 12:
      Thread 13:
      Thread 14:
      Thread 15:
      2   libSystem.B.dylib             0x912f58b5 pthread_cond_timedwait$UNIX2003 + 72
      3   com.adobe.aubackend.framework 0x02032a7a abe::afs::AudioFileCache::GetBlock(unsigned int, unsigned int, bool, bool) + 1178
      4   com.adobe.aubackend.framework 0x0204d31a abe::afs::VirtualAudioFile::ReadBlock(unsigned int, void*, unsigned int, unsigned int) + 90
      5   com.adobe.aubackend.framework 0x0204dd79 abe::afs::VirtualAudioFile::SeekRead(long long, unsigned int, void*, unsigned int) + 889
      6   com.adobe.aubackend.framework 0x0204e409 abe::afs::VirtualAudioFile::ReadChannels(long long, long long, std::vector<float*, std::allocator<float*> > const&, unsigned int, unsigned int) + 409
      7   com.adobe.aubackend.framework 0x02077718 abe::AudioSource::GetAudioData(long long, long long, float*) const + 184
      8   com.adobe.aubackend.framework 0x0207fa64 abe::AudioSourceChannel::GetAudioData(long long, long long, float*, bool) + 948
      9   com.adobe.aubackend.framework 0x0207ff11 abe::AudioSourceChannel::RecalcPeakData(boost::intrusive_ptr<abe::pk::PeakChannel>, long long, long long) + 177
      10  com.adobe.aubackend.framework 0x0208d0b4 abe::AudioSourceSequence::CalcPeakData(long long, long long, bool) + 996
      11  com.adobe.aubackend.framework 0x0209ae4c abe::AudioSourceSequence::GeneratePeakDataImpl(long long, long long, bool) + 604
      12  com.adobe.aubackend.framework 0x0205a9b5 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::intrusive_ptr<abe::AudioSourceSequence>, long long, long long, bool), boost::_bi::list4<boost::_bi::value<boost::intrusive_ptr<abe::AudioSourceSequence> >, boost::_bi::value<int>, boost::_bi::value<long long>, boost::_bi::value<bool> > >, void>::invoke(boost::detail::function::function_buffer&) + 85
      13  com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      14  com.adobe.dvacore.framework   0x0014438a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
      15  com.adobe.dvacore.framework   0x0014018a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      16  com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      17  com.adobe.dvacore.framework   0x0013cbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      18  com.adobe.dvacore.framework   0x0013daf0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      19  ...obe.boost_threads.framework 0x0005d6fd thread_proxy + 141
      20  libSystem.B.dylib             0x912f585d _pthread_start + 345
      21  libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 16:
      3   com.adobe.aubackend.framework 0x0228f9f0 abe::spectral::SpectralDataManager::Process() + 720
      5   com.adobe.dvacore.framework   0x0014438a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
      6   com.adobe.dvacore.framework   0x0014018a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      7   com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      8   com.adobe.dvacore.framework   0x0013cbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      9   com.adobe.dvacore.framework   0x0013daf0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      10  ...obe.boost_threads.framework 0x0005d6fd thread_proxy + 141
      11  libSystem.B.dylib             0x912f585d _pthread_start + 345
      12  libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 17:
      0   libSystem.B.dylib             0x912c815a semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x912f5ce5 _pthread_cond_wait + 1066
      2   libSystem.B.dylib             0x91324ac8 pthread_cond_timedwait_relative_np + 47
      3   ...ple.CoreServices.CarbonCore 0x90a94ecd TSWaitOnConditionTimedRelative + 242
      4   ...ple.CoreServices.CarbonCore 0x90a90873 MPWaitOnQueue + 250
      5   com.adobe.dvacore.framework   0x001442fa dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      Thread 18:
      3   com.adobe.aubackend.framework 0x022b32f6 abe::ThreadUtils::SynchronousWrapper::Execute(dvacore::threads::AsyncEventLoopAdaptor*) + 438
      4   com.adobe.aubackend.framework 0x01febb43 abe::AsyncOperation::ProcessStart(bool) + 547
      5   com.adobe.aubackend.framework 0x01ff5b3b boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, abe::AsyncOperation, bool>, boost::_bi::list2<boost::_bi::value<abe::AsyncOperation*>, boost::_bi::value<bool> > >, void>::invoke(boost::detail::function::function_buffer&) + 59
      7   com.adobe.dvacore.framework   0x0014438a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
      8   com.adobe.dvacore.framework   0x0014018a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      9   com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
      10  com.adobe.dvacore.framework   0x0013cbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      11  com.adobe.dvacore.framework   0x0013daf0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      12  ...obe.boost_threads.framework 0x0005d6fd thread_proxy + 141
      13  libSystem.B.dylib             0x912f585d _pthread_start + 345
      14  libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 19:
      Thread 20:
      Thread 21:
      Thread 22:
      Thread 23:
      1   libSystem.B.dylib             0x91321ee5 nanosleep$UNIX2003 + 188
      2   ...adobe.auscripting.framework 0x03106ea1 ScObjects::Thread::sleep(unsigned int) + 65
      3   ...adobe.auscripting.framework 0x030ef483 ScObjects::BridgeTalkThread::run() + 179
      4   ...adobe.auscripting.framework 0x03106fce ScObjects::Thread::go(void*) + 174
      5   libSystem.B.dylib             0x912f585d _pthread_start + 345
      6   libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 24:
      3   com.apple.audio.CoreAudio     0x95d703c7 CAGuard::WaitFor(unsigned long long) + 219
      4   com.apple.audio.CoreAudio     0x95d733f9 CAGuard::WaitUntil(unsigned long long) + 289
      5   com.apple.audio.CoreAudio     0x95d70cf6 HP_IOThread::WorkLoop() + 1892
      6   com.apple.audio.CoreAudio     0x95d7058d HP_IOThread::ThreadEntry(HP_IOThread*) + 17
      7   com.apple.audio.CoreAudio     0x95d704a4 CAPThread::Entry(CAPThread*) + 140
      8   libSystem.B.dylib             0x912f585d _pthread_start + 345
      9   libSystem.B.dylib             0x912f56e2 thread_start + 34
      Thread 25:  com.apple.CFSocket.private
      0   libSystem.B.dylib             0x912e70c6 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation      0x974a5c83 __CFSocketManager + 1091
      Thread 26:  com.apple.coremedia.scheduledfileio
      3   com.apple.CoreMedia           0x90100cff WaitOnCondition + 19
      4   com.apple.CoreMedia           0x90100fdd FigSemaphoreWaitRelative + 173
      5   com.apple.CoreMedia           0x900fefee FigScheduledFileIOThread + 6254
      6   com.apple.CoreMedia           0x9010200b figThreadMain + 340
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000007  ebx: 0x0890fa00  ecx: 0x0000cfed  edx: 0x000000cf
        edi: 0x00000000  esi: 0x0858ce10  ebp: 0xbfffd0b8  esp: 0xbfffd060
         ss: 0x0000001f  efl: 0x00010202  eip: 0x912d00c5   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x0858ce10
      Binary Images:
          0x1000 -     0x2ff7 +com.adobe.Audition.4.0 4.0x10 (4.0) <1987E7D4-6A62-4AD7-0CC0-57AAFBF937C0> /Applications/Adobe Audition.app/Contents/MacOS/Adobe Audition
         0x12000 -    0x16ffc +com.adobe.AdobeCrashReporter 2.5 (3.0.20090403) /Applications/Adobe Audition.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReport er
         0x1c000 -    0x38fd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Audition.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
         0x43000 -    0x49fef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.227407) <43FFF5DD-EB22-BA79-ADA7-CE764691A3FA> /Applications/Adobe Audition.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
         0x5b000 -    0x62ff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.227407) <A4543C73-7576-87A8-0F82-EDA4399AA816> /Applications/Adobe Audition.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x72000 -    0x7cffd +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.227407) <008D30F2-1FA5-2CB6-47D4-B681C4271647> /Applications/Adobe Audition.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
         0x8f000 -    0x90ffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.227407) <B5F6001A-DDB9-28D0-200C-784CEA3867A1> /Applications/Adobe Audition.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
         0x98000 -   0x225fef +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.227407) <1A2036D5-23CA-97DD-1CC9-197CA598B90A> /Applications/Adobe Audition.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x3a3000 -   0x705fff +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.227407) <4CCEF8A1-AEF9-A025-E127-0A8B053E76BE> /Applications/Adobe Audition.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
        0xaa8000 -   0xe25ff3 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.227407) <C2CA6AAF-79FB-41DC-ECF2-9B5D05789E11> /Applications/Adobe Audition.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
      0x1394000 -  0x1441fff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.227407) <35F0D2FF-1AA9-B4EB-7C86-86B3AA51A24C> /Applications/Adobe Audition.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
      0x1514000 -  0x1536ff7 +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.227407) <B9489EB1-6251-C8FA-5ABE-B1D2835371F0> /Applications/Adobe Audition.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
      0x1557000 -  0x15b6fff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.227407) <706687D1-99B2-D6A6-6D77-6E61F9204AB6> /Applications/Adobe Audition.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
      0x163f000 -  0x1697ff7 +AdobeXMP ??? (???) <FC80E7A2-D150-D5A8-9AEE-879B05153A34> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
      0x16a6000 -  0x174cff3 +AdobeXMPFiles ??? (???) <CB814673-A68C-01E2-84A9-500FA0D0E902> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
      0x1788000 -  0x181afff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.227407) <8242B12A-1DA3-0097-9D67-3914F3525A8E> /Applications/Adobe Audition.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
      0x18b3000 -  0x18fcfff +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.227407) <89DD2C45-7B77-63BE-08AB-C65F62D8BB16> /Applications/Adobe Audition.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
      0x191d000 -  0x19c7fff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.227407) <3AFC9275-FC8A-12BA-9DEE-12E06A84346F> /Applications/Adobe Audition.app/Contents/Frameworks/exo.framework/Versions/A/exo
      0x1ac1000 -  0x1adfff3 +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0 (5.0.0.227407) <CEFB69C2-2B6F-4803-1E76-2A7C27DB7365> /Applications/Adobe Audition.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
      0x1b09000 -  0x1b14fff +com.adobe.aucore.framework 1.0 (1.0) <5138C72A-D709-15C9-C7CF-2DFB0BB63557> /Applications/Adobe Audition.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
      0x1b21000 -  0x1cf8ff2 +com.adobe.audsp.framework 1.0 (1.0) <1D00C1BB-2239-0682-A7D4-7C0EB91D746F> /Applications/Adobe Audition.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
      0x1d89000 -  0x1ebefef +com.adobe.auaudiocomponents.framework 1.0 (1.0) <CAD732EE-D001-D483-B0B0-DDAB3CB7632E> /Applications/Adobe Audition.app/Contents/Frameworks/AuAudioComponents.framework/Versions/A/AuAudioComponents
      0x1fb6000 -  0x232aff7 +com.adobe.aubackend.framework 1.0 (1.0) <839C916A-0B01-35CB-481D-1A11B58A2708> /Applications/Adobe Audition.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBackEnd
      0x263c000 -  0x2643fff +com.adobe.dvaundo.framework dvaundo version 5.0.0 (5.0.0.227407) <C879499B-14BE-2A58-E3A9-16A22BCB8599> /Applications/Adobe Audition.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
      0x264f000 -  0x2980fef +AuApplication ??? (???) <B85693EC-7B9B-8FF2-8224-A867FDADE88A> /Applications/Adobe Audition.app/Contents/Frameworks/AuApplication.framework/Versions/A/AuApplication
      0x2c4f000 -  0x2d32feb +com.adobe.auuitoolkit.framework 1.0 (1.0) <11FC9733-4040-4DF9-7BAD-2AAF1C698681> /Applications/Adobe Audition.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuUIToolkit
      0x2e7a000 -  0x2f12ffb +AdobeExtendScript 4.0.0 (compatibility 4.0.0) <46913918-DC81-801B-64CA-20859142B7CD> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
      0x2f71000 -  0x2ff7ff7 +com.adobe.AdobeScCore ScCore 4.0.5 (4.0.5.3233) <C43541AF-83A7-E11D-50FB-1EC7D6120AE9> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
      0x3038000 -  0x3149ffb +com.adobe.auscripting.framework 1.0 (1.0) <9F05F5C5-D1DA-4C5F-E8CA-EF6062622853> /Applications/Adobe Audition.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuScripting
      0x32d2000 -  0x3341fff +com.adobe.auaudiocomponentsui.framework 1.0 (1.0) <FB33D5F0-5DD9-CD3D-4FDB-97354B9B1C97> /Applications/Adobe Audition.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versions/A/AuAudioComponen tsUI
      0x33df000 -  0x3d5afef +AuUI ??? (???) <2A0283CA-D85F-B907-8C85-F1A53E4C902D> /Applications/Adobe Audition.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
      0x4671000 -  0x46b1ff7  com.apple.vmutils 4.2 (106) <7AAF9FDA-AC1E-09FD-889E-68FFB5F94BA8> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0x46ca000 -  0x46d4ff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.227407) <C782506A-EB8B-535F-9FAA-DD68C619DC75> /Applications/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
      0x46e8000 -  0x4765fe2 +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.227407) <F3CC925C-2244-6042-FA7D-27B548CD668A> /Applications/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
      0x47ca000 -  0x489efef +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.227407) <DBD4A2D4-2153-724E-DB7A-E7CEF3F4298E> /Applications/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
      0x4998000 -  0x49c1fe3  com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
      0x49d2000 -  0x4abaccb +iZBase ??? (???) <773F066F-8FBE-4947-BA51-D3A1BC62D2E1> /Applications/Adobe Audition.app/Contents/Frameworks/iZBase.framework/Versions/A/iZBase
      0x4b37000 -  0x4b9be48 +iZDSPBase ??? (???) <C1575F2E-CE46-43AD-8F48-D15B7097F082> /Applications/Adobe Audition.app/Contents/Frameworks/iZDSPBase.framework/Versions/A/iZDSPBase
      0x4bb4000 -  0x4c4a3a6 +iZotope_Radius ??? (???) <B6AF5A0A-6CFD-4298-8450-9FD830471654> /Applications/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZotope_Radius
      0x4c87000 -  0x4cddffb +com.adobe.headlights.LogSessionFramework ??? (2.1.0.1075) <ABE97AAF-C5A9-C729-63D9-73FFB791BDE2> /Applications/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x4d26000 -  0x4fb4fec +libxerces-c-3.0.dylib ??? (???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
      0x5137000 -  0x51ecfe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
      0x5232000 -  0x5355ff7 +AdobeACE ??? (???) <6B4856DC-3D41-CEF7-CB70-D02EEA97B8D2> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x5378000 -  0x5a52ff3 +AdobeAGM ??? (???) <FE943B4D-ED58-F753-8AE8-54E753A773BD> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x5b17000 -  0x5b34ff7 +AdobeBIB ??? (???) <6CC35ACF-5CCD-1509-B4BB-3B48AD140526> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x5b3b000 -  0x5b61ffb +AdobeBIBUtils ??? (???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x5b68000 -  0x5e97ff3 +com.adobe.CoolType AdobeCoolType 5.10.7.10201 (5.10.7.10201) <6810A678-B1DF-F96D-2560-25AE3FDA923A> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x5ee9000 -  0x5f56ffb +com.adobe.amtlib amtlib 3.5.0.34 (3.5.0.34) <8C1EBC9E-DDFF-660B-03FB-196CE8A4CED8> /Applications/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x5f6d000 -  0x5f71ff3 +com.adobe.dvaflashview.framework dvaflashview version 5.0.0 (5.0.0.227407) <93CDD4AA-187D-5C06-1BA3-EA414516018B> /Applications/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
      0x5f7b000 -  0x5f7eff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0x6740000 -  0x674cff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.7 (2.2.7) <ED8425EF-125A-BDC9-E862-0A9F431AF3D9> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
      0x6795000 -  0x6799ff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F402CF88-D96C-42A0-3207-49759F496AE8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x679e000 -  0x67a4ffb  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <82BFF5E9-2B0E-FE8B-8370-445DD94DA434> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x83ae000 -  0x83e1fe3 +com.adobe.pip ??? (5.5.0.0) <6FCBB4C5-7EEF-1AF8-02C6-38E429E66EA9> /Applications/Adobe Audition.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
      0x83ee000 -  0x8455fe7 +com.adobe.amt.services AMTServices 3.5.0.34 (BuildVersion: 3.5; BuildDate: Tue Sep 14 2010 21:49:00) (3.5.0.34) <F56D7855-B0F7-4E7E-1997-D4FC2F5ACB2D> /Applications/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0x85ad000 -  0x85aeff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0x1d14b000 - 0x1d16ffe7  GLRendererFloat ??? (???) <1274B762-2FB9-48FE-EAFD-C459B2B4BECC> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
      0x1d251000 - 0x1d252ff7 +com.sophos.cmplugin 7.2.0 (7.2.0) <9ABA7BA0-ACD4-CEFE-D477-1DD8DE551CF1> /Library/Contextual Menu Items/Sophos Anti-Virus.plugin/Contents/MacOS/Sophos Anti-Virus
      0x205e6000 - 0x2075efe7  GLEngine ??? (???) <3A6C5513-7428-2242-2892-B429C72343CB> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
      0x20790000 - 0x20b95fe7  libclh.dylib 3.1.1 C  (3.1.1) <745CBD72-DF1F-EC12-BE51-4EEA9847EADF> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
      0x20c0d000 - 0x21564ff3  com.apple.driver.AppleIntelHDGraphicsGLDriver 1.6.26 (6.2.6) <ACD5A3C8-28DA-4098-3564-D0470FE9E0C6> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelH DGraphicsGLDriver
      0x21f78000 - 0x21fc6ffb +com.adobe.SesxNative.bundle 1.0 (1.0) <D95F8CB9-96FE-E515-FD10-35E0020FBDDF> /Applications/Adobe Audition.app/Contents/Session Plug-Ins/SesxNative.bundle/Contents/MacOS/SesxNative
      0x2200d000 - 0x22026fef +com.adobe.AmioWav.bundle 1.0 (1.0) <1E0D749D-B1D0-7CD1-6B26-2AE69B9129E8> /Applications/Adobe Audition.app/Contents/Amio Plug-Ins/AmioWav.bundle/Contents/MacOS/AmioWav
      0x224f0000 - 0x224f7ff7  com.apple.qldisplay.Music 2.3 (327.6) <9BA4906D-2810-2CD9-9224-BCAE26913FFE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/Resources/DisplayBundles/Music.qldisplay/Contents/MacOS/Music
      0x26c08000 - 0x26c15fe7 +com.getdropbox.finderplugin ??? (169) <DC86A475-1C47-7285-D1DC-52A50D0321A7> /Users/scott/Library/Contextual Menu Items/DropboxPlugin.plugin/Contents/MacOS/DropboxPlugin
      0x70000000 - 0x700cbff3  com.apple.audio.units.Components 1.6.3 (1.6.3) <5DA35A22-1B05-6BD3-985A-26A7A2CD6289> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
      0x8f0c8000 - 0x8f811ff7  com.apple.GeForceGLDriver 1.6.26 (6.2.6) <518182BB-5A3C-5F4C-3A84-17BB8E385BBF> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <39AC3185-E633-68AA-7CD6-1230E7F1CEF4> /usr/lib/dyld
      0x90007000 - 0x90029fef  com.apple.DirectoryService.Framework 3.6 (621.9) <F2EEE9D7-D4FB-14F3-E647-ABD32754F557> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x900df000 - 0x9011cff7  com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x9011d000 - 0x90128ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <CB2510BD-A5B3-9D90-5917-C73F6ECAC913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x90129000 - 0x901a6ff7  com.apple.iLifeMediaBrowser 2.5.4 (468.1.1) <3B7F5895-B48D-A2E0-D708-58EC58EB9514> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
      0x901a7000 - 0x901aaff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B624AACE-991B-0FFA-2482-E69970576CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x901ab000 - 0x901bdff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x901be000 - 0x901c4ff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <DACD11D8-4B64-CD3B-C988-B1041E07D13A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
      0x901c5000 - 0x90206ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <16DAE1A5-937A-1CA2-D98F-2AF958B62993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x90241000 - 0x90676ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x90677000 - 0x90874ff7  com.apple.JavaScriptCore 6533.19 (6533.19.1) <85A6BFDD-CBB6-7490-748D-8EA8B9B7FDD8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x90875000 - 0x90875ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x90876000 - 0x90892fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x9093b000 - 0x90a3ffe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
      0x90a4e000 - 0x90d6eff3  com.apple.CoreServices.CarbonCore 861.23 (861.23) <B08756E4-32C5-CC33-0268-7C00A5ED7537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x90d6f000 - 0x90deafff  com.apple.AppleVAFramework 4.10.12 (4.10.12) <89C4EBE2-FE27-3160-0BD1-D0C2ED5F3605> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x90e17000 - 0x90e7bffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x90eb1000 - 0x90eb1ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x90eb2000 - 0x90ef9ffb  com.apple.CoreMediaIOServices 134.0 (1160) <D4F40A28-4E31-3210-7C2B-59D8A1903FB2> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
      0x90efa000 - 0x9116dfe7  com.apple.Foundation 6.6.4 (751.42) <ACC0BAEB-C590-7052-3AB2-86C207C3D6D4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x9116e000 - 0x91172ff7  libGFXShared.dylib ??? (???) <9E14BE2F-C863-40E9-41A6-1BE9045663A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x91173000 - 0x911d0ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x911d1000 - 0x9120fff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x91210000 - 0x912c6ff7  libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x912c7000 - 0x9146eff7  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
      0x9146f000 - 0x914b2ff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x914b3000 - 0x914d2ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x914d3000 - 0x914d3ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x914d4000 - 0x914d5ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x916f6000 - 0x9172cfff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
      0x9172d000 - 0x91776fe7  libTIFF.dylib ??? (???) <AC1FC806-F7F4-174B-375F-FE5D6008666C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x91777000 - 0x9177aff7  libCoreVMClient.dylib ??? (???) <973B9E1F-70B3-2E76-B14B-E57F306AD2DF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x9177b000 - 0x9178bff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
      0x9178c000 - 0x9178cff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x9178d000 - 0x9183dff3  com.apple.ColorSync 4.6.3 (4.6.3) <0354B408-665F-8B3F-87FF-64E6322276F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x9183e000 - 0x91b62fef  com.apple.HIToolbox 1.6.4 (???) <4699C8BB-DE74-C530-564B-D131F74C9B54> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x91b63000 - 0x91b64ff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <BE4C2495-B758-AD22-DCC0-56A6791E948E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x91b65000 - 0x91b98ff7  com.apple.AE 496.4 (496.4) <C73D124C-C722-41D8-3465-4CE0D0BA9307> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x91e08000 - 0x91e40fe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <242954AD-3BE1-29E8-E2E0-08063201F105> /usr/lib/libcurl.4.dylib
      0x91f65000 - 0x91f65ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
      0x92038000 - 0x92085feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <E2632F3E-6B5C-2E92-CD11-15BC0CE109CA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x92086000 - 0x920bdfe7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
      0x920be000 - 0x92240fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
      0x92282000 - 0x922b3ff7  libGLImage.dylib ??? (???) <E3EC8E92-4DDD-E7B8-3D38-C5A5160A4930> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x924bc000 - 0x924bfffb  com.apple.help 1.3.1 (41) <EF92C648-2085-C085-8EA7-A1AF37AE94F4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x924c0000 - 0x924e7ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0x924e8000 - 0x925eafef  com.apple.MeshKitIO 1.1 (49.2) <D0401AC5-1F92-2BBB-EBAB-58EDD3BA61B9> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
      0x92663000 - 0x9271cfe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
      0x9271d000 - 0x92bd6ffb  com.apple.VideoToolbox 0.484.20 (484.20) <E7B9F015-2569-43D7-5268-375ED937ECA5> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x92cc6000 - 0x92cdaffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <0DBE17D5-17A2-8A0E-8572-5A78408B41C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x92d2f000 - 0x92d39fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x92e02000 - 0x92e70ff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
      0x92e71000 - 0x93660557  com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x93661000 - 0x93671ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
      0x93672000 - 0x936afff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x936b0000 - 0x9375dfe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <C8925910-B927-968B-4B71-D83A4CEF8646> /usr/lib/libobjc.A.dylib
      0x9375e000 - 0x93808fe7  com.apple.CFNetwork 454.11.5 (454.11.5) <D8963574-285A-3BD6-6B25-07D39C6F67A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x93809000 - 0x9388bffb  SecurityFoundation ??? (???) <A8D248DE-8670-970D-39E3-A9738CFDBEE1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x9388c000 - 0x9388cff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x9388d000 - 0x9391ffe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x93920000 - 0x94872fef  com.apple.QuickTimeComponents.component 7.6.6 (1756) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
      0x94873000 - 0x94879fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x94964000 - 0x949aaff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
      0x95408000 - 0x95420ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x95421000 - 0x95684fff  com.apple.security 6.1.1 (37594) <B6F2A8BF-C1B7-A0E2-83FB-4FF265E9BDDC> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x958b4000 - 0x95c1fff7  com.apple.QuartzCore 1.6.3 (227.34) <CC1C1631-D8D1-D416-171E-A1683274E479> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x95c20000 - 0x95d4ffe3  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x95d50000 - 0x95dcafff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x95dcb000 - 0x95e2cfe7  com.apple.CoreText 3.5.0 (???) <BB50C045-25F5-65B8-B1DB-8CDAEF45EB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x95e2d000 - 0x95e34ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x95e76000 - 0x95e9eff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
      0x95e9f000 - 0x95eadff7  com.apple.opengl 1.6.12 (1.6.12) <9F13B279-F289-18AC-5D86-DCD52BAF087D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x95eae000 - 0x95f08fe7  com.apple.CorePDF 1.3 (1.3) <EA168671-F44F-BFE4-AA7D-3801DA29A650> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x95f1c000 - 0x95f29ff7  com.apple.NetFS 3.2.1 (3.2.1) <94A52A6D-F071-09D7-E80F-F633F17233FE> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x95f2a000 - 0x95f62ff7  com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
      0x95f9f000 - 0x95f9fff7  com.apple.Carbon 150 (152) <2539A94A-34D9-45CB-8F3E-AD53149E0BD5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x960ed000 - 0x96143ff7  com.apple.MeshKitRuntime 1.1 (49.2) <CB9F38B1-E107-EA62-EDFF-02EE79F6D1A5> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
      0x961cc000 - 0x96245ff7  com.apple.PDFKit 2.5.1 (2.5.1) <A068BF37-03E0-A231-2791-561C60C3ED2B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x96246000 - 0x9624cfe7  com.apple.CommerceCore 1.0 (6) <41C2A87D-93D8-56C1-9292-0400699F23C1> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
      0x9624d000 - 0x9626dfe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <BF7FF2F6-5FD3-D78F-77BC-9E2CB2A5E309> /usr/lib/libresolv.9.dylib
      0x9626e000 - 0x96294ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x96295000 - 0x962d8ff7  libGLU.dylib ??? (???) <BB66EDB2-D5FE-61C9-21BE-747F9862819C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x962d9000 - 0x962e3ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x96354000 - 0x96357fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x96358000 - 0x96393feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x96394000 - 0x967aaff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x967ab000 - 0x967edff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x9681a000 - 0x96828fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
      0x96b23000 - 0x96bd1ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x96be4000 - 0x96c1dff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <E0D512DD-365D-46A0-F50C-435BC250424F> /usr/lib/libcups.2.dylib
      0x96c1e000 - 0x96d2aff7  libGLProgrammability.dylib ??? (???) <A077BFEA-19C6-9F48-2F36-8E4E55376F49> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x96f08000 - 0x96f0cff7  libGIF.dylib ??? (???) <DA5758A4-71B0-DD6E-7402-B7FB15387569> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x96f0d000 - 0x96f22fff  com.apple.ImageCapture 6.0.1 (6.0.1) <E7ED2AC1-834C-A44E-531E-EC05F0496DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x96f23000 - 0x9714eff3  com.apple.QuartzComposer 4.2 ({156.28}) <08AF01DC-110D-9443-3916-699DBDED0149> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x9714f000 - 0x97157ff7  com.apple.DisplayServicesFW 2.3.0 (283) <48D94761-7340-D029-99E3-9BE0262FAF22> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x97158000 - 0x97284ffb  com.apple.MediaToolbox 0.484.20 (484.20) <D67788A2-B772-C5DB-B12B-173B2F8EE40B> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x97285000 - 0x973b3fe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x973b4000 - 0x973d5fe7  com.apple.opencl 12.3 (12.3) <DEA600BF-4F54-66B5-DB2F-DC57FD518543> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x973d6000 - 0x97400ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x97417000 - 0x97428ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x97429000 - 0x975a4fe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x975a5000 - 0x975f5ff7  com.apple.framework.familycontrols 2.0.2 (2020) <AF7F86F1-F7BF-CBA8-7A4A-D8F7A19F9601> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x975f6000 - 0x976c0fef  com.apple.CoreServices.OSServices 357 (357) <3A26F553-722D-3536-EEDE-FB41FCDAA7FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x976c1000 - 0x97719fe7  com.apple.datadetectorscore 2.0 (80.7) <F7416A84-E91C-5BDC-10E3-4940EB7AE5C9> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x9771a000 - 0x97724ff7  com.apple.HelpData 2.0.4 (34) <001A7163-C977-C30F-1B4B-4F5647F72E96> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x97758000 - 0x97797ff7  com.apple.ImageCaptureCore 1.0.3 (1.0.3) <7E02D104-F31C-CF72-71B4-DA5DF7B48337> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x97894000 - 0x97903ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x97926000 - 0x9796aff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x9797d000 - 0x97ac0fef  com.apple.QTKit 7.6.6 (1756) <4D809734-4E1B-8E18-C825-86C5422FC3DC> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x97acb000 - 0x97c84feb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C145139E-24C4-5A3D-B17C-809D528354B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x97c85000 - 0x97d20ff7  com.apple.ApplicationServices.ATS 4.4 (???) <ECB16606-4DF8-4AFB-C91D-F7947C26040F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x97d3f000 - 0x97d5aff7  libPng.dylib ??? (???) <E14178E0-B92D-94EA-DACB-04F346D7534C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x97d5b000 - 0x97dc5fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x97ef6000 - 0x9802dff7  com.apple.CoreAUC 6.04.04 (6.04.04) <050D9D16-AAE7-3460-4318-8449574F26C7> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
      0x9802e000 - 0x98035ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <C43D8F35-D0DB-37F3-5058-A8308A377303> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x98036000 - 0x980deffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x980df000 - 0x981bafeb  com.apple.DesktopServices 1.5.9 (1.5.9) <CED00AC1-924B-0E45-7D5E-1CEA8929F5BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x981c3000 - 0x98260fe3  com.apple.LaunchServices 362.2 (362.2) <F3952CAB-322F-A12F-57AF-8B91B1D76DDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x982bb000 - 0x982fffe7  com.apple.Metadata 10.6.3 (507.15) <A23633F1-E913-66C2-A073-E2B174C09B18> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x98351000 - 0x9835aff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x9835b000 - 0x9837fff7  libJPEG.dylib ??? (???) <46AF3A0F-2B8D-87B9-62D4-0905678A64DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x98380000 - 0x98679fef  com.apple.QuickTime 7.6.6 (1756) <F08B13B6-31D7-BD18-DA87-A0CDFCF13B8F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x98693000 - 0x98794fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <ED8E45C6-B078-15E8-938D-99D8FD1EAE64> /usr/lib/libxml2.2.dylib
      0x98795000 - 0x9882dfe7  edu.mit.Kerberos 6.5.10 (6.5.10) <DC19F49B-184E-FD0F-13F8-3A31924A3B66> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x9882e000 - 0x9910eff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x9910f000 - 0x99113ff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x99114000 - 0x99116ff7  com.apple.securityhi 4.0 (36638) <E7D83480-77BB-72F9-72F3-AEE198CE589F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x99117000 - 0x99149fe3  libTrueTypeScaler.dylib ??? (???) <6E9D1A50-330E-F1F4-F93D-9ECC8A61B21A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x9915a000 - 0x9915bff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
      0x9915c000 - 0x99168ff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
      0x99169000 - 0x9934bfff  com.apple.imageKit 2.0.3 (1.0) <B4DB05F7-01C5-35EE-7AB9-41BD9D63F075> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x9934c000 - 0x99351ff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x99352000 - 0x99382ff7  com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
      0x99383000 - 0x993d4ff7  com.apple.HIServices 1.8.2 (???) <F6EAC2D1-902A-9374-FC4B-43B50E054416> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x993d5000 - 0x994b2ff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x994b3000 - 0x998c9fef  com.apple.RawCamera.bundle 3.5.0 (551) <C9970A79-B1D4-60B0-68C4-01FADDE2E0E3> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x998ca000 - 0x998caff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x998cb000 - 0x998d6ff7  libGL.dylib ??? (???) <48405993-0AE9-292B-6705-C3525528682A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x998e2000 - 0x998e4ff7  libRadiance.dylib ??? (???) <10048B4A-2AE8-A4E2-21B8-C6E7A8C5B76F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x999da000 - 0x999daff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x999db000 - 0x99a5bfeb  com.apple.SearchKit 1.3.0 (1.3.0) <2F5DE102-A203-7905-7D12-FCBCF17BAEF8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x99a5c000 - 0x99a70fe7  libbsm.0.dylib ??? (???) <821E415B-6C42-D359-78FF-E892792F8C52> /usr/lib/libbsm.0.dylib
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
        • 1. Re: Crashes when bouncing down
          _durin_ Adobe Employee
          How much RAM does this system have and how large/complex are these sessions?  The last few commands in the crashed thread indicate the OS is attempting to allocate more memory.  Since the public beta was released, significant improvements have been made to memory handling in multitrack which should drastically reduce the memory overhead required for more complicated sessions.
          • 2. Re: Crashes when bouncing down
            Scott-C-UK Level 1
            Thanks for the reply - I did think it would be something along those lines, because when I simplify the project - taking unused media out etc, the project will sometimes save (rarely, but it has happened once or twice.)
            The Mac was brand new at the start of December, and so it is an i5 with 4gb of RAM.
            I was planning to add more RAM at some point in the future, but surely 4gb should be enough?
            It is to run Audition 3 on Windows 7?
            You mentioned the last public beta - and I was wondering about this the other day - has/is the beta being updated, or is it still the original version that was released first?  I haven't updated/changed my installation of Audition for Mac since I originally installed it, so is there now a new or updated version of the beta?  The download page suggested it was still version 1.
            (Audition shows that I am running Version 4.0 Build 10 - is there anything to update to from this?)
            best
            sc
            • 3. Re: Crashes when bouncing down
              Scott-C-UK Level 1
              PS - in relation to the complexity of the sessions - that really doesn't make much difference.
              I regularly have problems with mixing down a 45 minute programme that had probably hundreds of edits, with many many crossfades, music beds with envelopes etc, but then today I had a 10 minute interview with probably about 20 edits in it, that caused a crash again.
              I've even tried to simplify the bounce, by bouncing the 45 minutes into three 15 minute chunks to re-mix and bounce again, but have even had crashes when bouncing down one of these.
              • 4. Re: Crashes when bouncing down
                Scott-C-UK Level 1
                Any other suggestions on what the cause of this is?  Have had many further crashes, and today's (details below) is just the latest:
                Process:         Adobe Audition [11858]
                Path:            /Applications/Adobe Audition.app/Contents/MacOS/Adobe Audition
                Identifier:      com.adobe.Audition.4.0
                Version:         4.0x10 (4.0)
                Code Type:       X86 (Native)
                Parent Process:  launchd [108]
                Date/Time:       2011-02-25 16:37:36.251 +0000
                OS Version:      Mac OS X 10.6.6 (10J567)
                Report Version:  6
                Interval Since Last Report:          265626 sec
                Crashes Since Last Report:           5
                Per-App Interval Since Last Report:  88675 sec
                Per-App Crashes Since Last Report:   2
                Anonymous UUID:                      407C9472-0847-4483-B6F1-2E0B2311DDC5
                Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
                Exception Codes: KERN_INVALID_ADDRESS at 0x0000000074890000
                Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
                0   ???                           0x74890000 0 + 1955135488
                1   AuUI                          0x03a6cc94 aui::UpdateTimer::Impl::OnTimer() + 196
                3   com.adobe.dvacore.framework   0x00134337 dvacore::threads::(anonymous namespace)::RunLoopAdaptor::Execute(__CFRunLoopTimer*, void*) + 23
                4   com.apple.CoreFoundation      0x9924eadb __CFRunLoopRun + 8059
                5   com.apple.CoreFoundation      0x9924c464 CFRunLoopRunSpecific + 452
                6   com.apple.CoreFoundation      0x9924c291 CFRunLoopRunInMode + 97
                7   com.apple.HIToolbox           0x994e4004 RunCurrentEventLoopInMode + 392
                8   com.apple.HIToolbox           0x994e3dbb ReceiveNextEventCommon + 354
                9   com.apple.HIToolbox           0x994e3c40 BlockUntilNextEventMatchingListInMode + 81
                10  com.apple.AppKit              0x981b678d _DPSNextEvent + 847
                11  com.apple.AppKit              0x981b5fce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
                12  com.apple.AppKit              0x98178247 -[NSApplication run] + 821
                13  com.adobe.exo.framework       0x01924c87 exo::app::OS_AppBase::RunEventLoop() + 71
                14  AuUI                          0x03469460 AudMacMain(int, char**) + 608
                15  com.adobe.Audition.4.0        0x00002ecd main + 93
                16  com.adobe.Audition.4.0        0x00002c66 start + 54
                0   libSystem.B.dylib             0x9004f982 kevent + 10
                1   libSystem.B.dylib             0x9005009c _dispatch_mgr_invoke + 215
                2   libSystem.B.dylib             0x9004f559 _dispatch_queue_invoke + 163
                3   libSystem.B.dylib             0x9004f2fe _dispatch_worker_thread2 + 240
                4   libSystem.B.dylib             0x9004ed81 _pthread_wqthread + 390
                5   libSystem.B.dylib             0x9004ebc6 start_wqthread + 30
                Thread 2:
                0   libSystem.B.dylib             0x900570a6 __semwait_signal + 10
                1   libSystem.B.dylib             0x90056d62 _pthread_cond_wait + 1191
                2   libSystem.B.dylib             0x900589f8 pthread_cond_wait$UNIX2003 + 73
                3   ...ple.CoreServices.CarbonCore 0x91db051e TSWaitOnCondition + 126
                4   ...ple.CoreServices.CarbonCore 0x91d9bea5 TSWaitOnConditionTimedRelative + 202
                5   ...ple.CoreServices.CarbonCore 0x91d97873 MPWaitOnQueue + 250
                12  libSystem.B.dylib             0x9005685d _pthread_start + 345
                13  libSystem.B.dylib             0x900566e2 thread_start + 34
                Thread 3:
                Thread 4:
                0   libSystem.B.dylib             0x900290fa mach_msg_trap + 10
                1   libSystem.B.dylib             0x90029867 mach_msg + 68
                2   com.apple.CoreFoundation      0x9924d37f __CFRunLoopRun + 2079
                3   com.apple.CoreFoundation      0x9924c464 CFRunLoopRunSpecific + 452
                4   com.apple.CoreFoundation      0x9924c291 CFRunLoopRunInMode + 97
                5   com.apple.audio.CoreAudio     0x9068396e HALRunLoop::OwnThread(void*) + 162
                6   com.apple.audio.CoreAudio     0x9066f4a4 CAPThread::Entry(CAPThread*) + 140
                7   libSystem.B.dylib             0x9005685d _pthread_start + 345
                8   libSystem.B.dylib             0x900566e2 thread_start + 34
                Thread 5:
                2   ....audio_hijack_server.hermes 0x067c54e1 ah_serv_loop + 161
                3   libSystem.B.dylib             0x9005685d _pthread_start + 345
                4   libSystem.B.dylib             0x900566e2 thread_start + 34
                Thread 6:
                6   com.adobe.dvacore.framework   0x001442fa dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
                7   com.adobe.dvacore.framework   0x0014018a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
                8   com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
                9   com.adobe.dvacore.framework   0x0013cbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
                10  com.adobe.dvacore.framework   0x0013daf0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
                11  ...obe.boost_threads.framework 0x0005d6fd thread_proxy + 141
                Thread 7:
                Thread 8:
                Thread 9:
                Thread 10:
                2   libSystem.B.dylib             0x900568b5 pthread_cond_timedwait$UNIX2003 + 72
                3   com.adobe.aubackend.framework 0x02041a32 abe::afs::AudioFileSystem::CacheServices() + 322
                4   com.adobe.dvacore.framework   0x000cc519 boost::function0<void>::operator()() const + 41
                11  libSystem.B.dylib             0x9005685d _pthread_start + 345
                12  libSystem.B.dylib             0x900566e2 thread_start + 34
                Thread 11:
                Thread 12:
                Thread 13:
                Thread 14:
                Thread 15:
                Thread 16:
                Thread 17:
                0   libSystem.B.dylib             0x9002915a semaphore_timedwait_signal_trap + 10
                1   libSystem.B.dylib             0x90056ce5 _pthread_cond_wait + 1066
                2   libSystem.B.dylib             0x90085ac8 pthread_cond_timedwait_relative_np + 47
                3   ...ple.CoreServices.CarbonCore 0x91d9becd TSWaitOnConditionTimedRelative + 242
                4   ...ple.CoreServices.CarbonCore 0x91d97873 MPWaitOnQueue + 250
                Thread 18:
                3   com.apple.audio.CoreAudio     0x9066f3c7 CAGuard::WaitFor(unsigned long long) + 219
                4   com.apple.audio.CoreAudio     0x906723f9 CAGuard::WaitUntil(unsigned long long) + 289
                5   com.apple.audio.CoreAudio     0x9066fcf6 HP_IOThread::WorkLoop() + 1892
                6   com.apple.audio.CoreAudio     0x9066f58d HP_IOThread::ThreadEntry(HP_IOThread*) + 17
                7   com.apple.audio.CoreAudio     0x9066f4a4 CAPThread::Entry(CAPThread*) + 140
                8   libSystem.B.dylib             0x9005685d _pthread_start + 345
                9   libSystem.B.dylib             0x900566e2 thread_start + 34
                Thread 19:
                0   com.adobe.aubackend.framework 0x022c069f px_ippsMinMaxIndx_32f + 91
                Thread 20:
                Thread 21:
                Thread 22:
                Thread 23:
                Thread 24:
                1   libSystem.B.dylib             0x90082ee5 nanosleep$UNIX2003 + 188
                5   libSystem.B.dylib             0x9005685d _pthread_start + 345
                6   libSystem.B.dylib             0x900566e2 thread_start + 34
                  eax: 0x06de0710  ebx: 0x0345a6bb  ecx: 0x74890000  edx: 0x00000000
                  edi: 0xbfffe404  esi: 0x2b20dd34  ebp: 0xbfffe658  esp: 0xbfffe32c
                   ss: 0x0000001f  efl: 0x00010202  eip: 0x74890000   cs: 0x00000017
                  cr2: 0x74890000
                Binary Images:
                0x67c0000 -  0x67ccff7 +com.rogueamoeba.audio_hijack_server.hermes 3.0.1 (3.0.1) <3C697B6F-34D4-569F-B40F-F6B6C1D886A7> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
                0x67f3000 -  0x67f7ff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F402CF88-D96C-42A0-3207-49759F496AE8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                0x8d7a000 -  0x8d7bff7  com.apple.bluetooth.IOBluetoothSCOAudioDriverPlugIn 2.3.8 (2.3.8f7) <F5A88E18-9A3C-774E-43A3-8579B88CAB79> /System/Library/Extensions/IOBluetoothFamily.kext/Contents/PlugIns/IOBluetoothSCOAudioDri ver.kext/Contents/Resources/IOBluetoothSCOAudioDriverPlugIn.bundle/Contents/MacOS/IOBlueto othSCOAudioDriverPlugIn
                0x8d80000 -  0x8d86ffb  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <82BFF5E9-2B0E-FE8B-8370-445DD94DA434> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                0x192ae000 - 0x192e1fe3 +com.adobe.pip ??? (5.5.0.0) <6FCBB4C5-7EEF-1AF8-02C6-38E429E66EA9> /Applications/Adobe Audition.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                0x192ef000 - 0x19356fe7 +com.adobe.amt.services AMTServices 3.5.0.34 (BuildVersion: 3.5; BuildDate: Tue Sep 14 2010 21:49:00) (3.5.0.34) <F56D7855-B0F7-4E7E-1997-D4FC2F5ACB2D> /Applications/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
                0x194a3000 - 0x194a4ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                0x1d221000 - 0x1d23afef +com.adobe.AmioWav.bundle 1.0 (1.0) <1E0D749D-B1D0-7CD1-6B26-2AE69B9129E8> /Applications/Adobe Audition.app/Contents/Amio Plug-Ins/AmioWav.bundle/Contents/MacOS/AmioWav
                0x2078d000 - 0x20905fe7  GLEngine ??? (???) <3A6C5513-7428-2242-2892-B429C72343CB> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                0x20937000 - 0x20d3cfe7  libclh.dylib 3.1.1 C  (3.1.1) <745CBD72-DF1F-EC12-BE51-4EEA9847EADF> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
                0x20db4000 - 0x2170bff3  com.apple.driver.AppleIntelHDGraphicsGLDriver 1.6.26 (6.2.6) <ACD5A3C8-28DA-4098-3564-D0470FE9E0C6> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelH DGraphicsGLDriver
                0x21de7000 - 0x21e0bfe7  GLRendererFloat ??? (???) <1274B762-2FB9-48FE-EAFD-C459B2B4BECC> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                0x22061000 - 0x22062ff7 +com.sophos.cmplugin 7.2.4 (7.2.4) <9ABA7BA0-ACD4-CEFE-D477-1DD8DE551CF1> /Library/Contextual Menu Items/Sophos Anti-Virus.plugin/Contents/MacOS/Sophos Anti-Virus
                0x2385e000 - 0x238acffb +com.adobe.SesxNative.bundle 1.0 (1.0) <D95F8CB9-96FE-E515-FD10-35E0020FBDDF> /Applications/Adobe Audition.app/Contents/Session Plug-Ins/SesxNative.bundle/Contents/MacOS/SesxNative
                0x23b30000 - 0x23b3dfe7 +com.getdropbox.finderplugin ??? (169) <DC86A475-1C47-7285-D1DC-52A50D0321A7> /Users/scott/Library/Contextual Menu Items/DropboxPlugin.plugin/Contents/MacOS/DropboxPlugin
                0x90003000 - 0x90027ff7  libJPEG.dylib ??? (???) <46AF3A0F-2B8D-87B9-62D4-0905678A64DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                0x90028000 - 0x901cfff7  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
                0x901d0000 - 0x901daff7  com.apple.HelpData 2.0.4 (34) <001A7163-C977-C30F-1B4B-4F5647F72E96> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                0x901db000 - 0x901e6ff7  libGL.dylib ??? (???) <48405993-0AE9-292B-6705-C3525528682A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                0x90228000 - 0x90292fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
                0x90348000 - 0x90358ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
                0x90359000 - 0x90363fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                0x90617000 - 0x9061affb  com.apple.help 1.3.1 (41) <EF92C648-2085-C085-8EA7-A1AF37AE94F4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                0x9061b000 - 0x9063aff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                0x90649000 - 0x90649ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                0x9064f000 - 0x906c9fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                0x91149000 - 0x9114aff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <BE4C2495-B758-AD22-DCC0-56A6791E948E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                0x9136c000 - 0x917a3fef  com.apple.RawCamera.bundle 3.6.0 (558) <CCF48B69-6B02-B0A5-45DF-5C5327AD16F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                0x917a4000 - 0x917abff7  com.apple.agl 3.0.12 (AGL-3.0.12) <C43D8F35-D0DB-37F3-5058-A8308A377303> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                0x917ac000 - 0x91be1ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                0x91d55000 - 0x92075ff3  com.apple.CoreServices.CarbonCore 861.23 (861.23) <B08756E4-32C5-CC33-0268-7C00A5ED7537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                0x92076000 - 0x9222ffeb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C145139E-24C4-5A3D-B17C-809D528354B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                0x92230000 - 0x9226dff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                0x9226e000 - 0x92349feb  com.apple.DesktopServices 1.5.9 (1.5.9) <CED00AC1-924B-0E45-7D5E-1CEA8929F5BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                0x92646000 - 0x92646ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                0x92647000 - 0x92748fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <ED8E45C6-B078-15E8-938D-99D8FD1EAE64> /usr/lib/libxml2.2.dylib
                0x92749000 - 0x9278cff7  libGLU.dylib ??? (???) <BB66EDB2-D5FE-61C9-21BE-747F9862819C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                0x9278d000 - 0x929f0fff  com.apple.security 6.1.1 (37594) <B6F2A8BF-C1B7-A0E2-83FB-4FF265E9BDDC> /System/Library/Frameworks/Security.framework/Versions/A/Security
                0x929f1000 - 0x929f5ff7  libGIF.dylib ??? (???) <DA5758A4-71B0-DD6E-7402-B7FB15387569> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                0x929f6000 - 0x929f6ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                0x92a38000 - 0x92a54fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                0x92a55000 - 0x92a60ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <CB2510BD-A5B3-9D90-5917-C73F6ECAC913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                0x92a61000 - 0x92aa4ff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                0x92aa5000 - 0x92b27ffb  SecurityFoundation ??? (???) <A8D248DE-8670-970D-39E3-A9738CFDBEE1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                0x92cac000 - 0x92cb5ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                0x92e72000 - 0x92ea5ff7  com.apple.AE 496.4 (496.4) <C73D124C-C722-41D8-3465-4CE0D0BA9307> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                0x92eae000 - 0x92eb5ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                0x92eb6000 - 0x92eeefe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <242954AD-3BE1-29E8-E2E0-08063201F105> /usr/lib/libcurl.4.dylib
                0x930f8000 - 0x9318afe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                0x93195000 - 0x931d6ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <16DAE1A5-937A-1CA2-D98F-2AF958B62993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                0x931d7000 - 0x93210ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <E0D512DD-365D-46A0-F50C-435BC250424F> /usr/lib/libcups.2.dylib
                0x93258000 - 0x93364ff7  libGLProgrammability.dylib ??? (???) <A077BFEA-19C6-9F48-2F36-8E4E55376F49> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                0x9345a000 - 0x9346cff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                0x9346d000 - 0x9350cfff  com.apple.Bluetooth 2.3.8 (2.3.8f7) <2F9EAC9C-ECD2-21CD-8957-BFFD20E2A772> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                0x93686000 - 0x936b8fe3  libTrueTypeScaler.dylib ??? (???) <6E9D1A50-330E-F1F4-F93D-9ECC8A61B21A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                0x93863000 - 0x93ad6fe7  com.apple.Foundation 6.6.4 (751.42) <ACC0BAEB-C590-7052-3AB2-86C207C3D6D4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                0x93ad7000 - 0x93adaff7  libCoreVMClient.dylib ??? (???) <973B9E1F-70B3-2E76-B14B-E57F306AD2DF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                0x93adb000 - 0x93bdffe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
                0x945d3000 - 0x945d5ff7  libRadiance.dylib ??? (???) <10048B4A-2AE8-A4E2-21B8-C6E7A8C5B76F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                0x945fd000 - 0x94625ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
                0x94626000 - 0x9463bfff  com.apple.ImageCapture 6.0.1 (6.0.1) <E7ED2AC1-834C-A44E-531E-EC05F0496DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                0x94660000 - 0x94674ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <0DBE17D5-17A2-8A0E-8572-5A78408B41C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                0x94675000 - 0x9467aff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                0x9467b000 - 0x946bffe7  com.apple.Metadata 10.6.3 (507.15) <A23633F1-E913-66C2-A073-E2B174C09B18> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                0x946c0000 - 0x947effe3  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                0x947f0000 - 0x947fdff7  com.apple.NetFS 3.2.1 (3.2.1) <94A52A6D-F071-09D7-E80F-F633F17233FE> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                0x947fe000 - 0x94820fef  com.apple.DirectoryService.Framework 3.6 (621.9) <F2EEE9D7-D4FB-14F3-E647-ABD32754F557> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                0x948cb000 - 0x9494bfeb  com.apple.SearchKit 1.3.0 (1.3.0) <2F5DE102-A203-7905-7D12-FCBCF17BAEF8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                0x9498c000 - 0x949dcff7  com.apple.framework.familycontrols 2.0.2 (2020) <AF7F86F1-F7BF-CBA8-7A4A-D8F7A19F9601> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                0x94a2e000 - 0x94a30ff7  com.apple.securityhi 4.0 (36638) <E7D83480-77BB-72F9-72F3-AEE198CE589F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                0x94a31000 - 0x94aa0ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                0x94aa1000 - 0x94ab2ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                0x94ab3000 - 0x94ab3ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
                0x94ab4000 - 0x94b4fff7  com.apple.ApplicationServices.ATS 4.4 (???) <ECB16606-4DF8-4AFB-C91D-F7947C26040F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                0x94b50000 - 0x94b8bfeb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                0x94b91000 - 0x94b91ff7  com.apple.Carbon 150 (152) <2539A94A-34D9-45CB-8F3E-AD53149E0BD5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                0x94b92000 - 0x94bd8ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
                0x94bd9000 - 0x94c1bff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                0x94c1c000 - 0x94c60ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                0x94c61000 - 0x94cc2fe7  com.apple.CoreText 3.5.0 (???) <BB50C045-25F5-65B8-B1DB-8CDAEF45EB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                0x94cc3000 - 0x94d7cfe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
                0x94d7d000 - 0x94d7dff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                0x94fa7000 - 0x95071fef  com.apple.CoreServices.OSServices 357 (357) <3A26F553-722D-3536-EEDE-FB41FCDAA7FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                0x950c4000 - 0x954daff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                0x954db000 - 0x954effe7  libbsm.0.dylib ??? (???) <821E415B-6C42-D359-78FF-E892792F8C52> /usr/lib/libbsm.0.dylib
                0x954f0000 - 0x95539fe7  libTIFF.dylib ??? (???) <AC1FC806-F7F4-174B-375F-FE5D6008666C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                0x9553a000 - 0x9553aff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                0x9553b000 - 0x95572fe7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
                0x95573000 - 0x95577ff7  libGFXShared.dylib ??? (???) <9E14BE2F-C863-40E9-41A6-1BE9045663A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                0x95578000 - 0x95582ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                0x955d4000 - 0x9567efe7  com.apple.CFNetwork 454.11.5 (454.11.5) <D8963574-285A-3BD6-6B25-07D39C6F67A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                0x956bd000 - 0x956c0ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B624AACE-991B-0FFA-2482-E69970576CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                0x956da000 - 0x95718ff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                0x95721000 - 0x9577eff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                0x9577f000 - 0x9578bff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
                0x959d7000 - 0x95a74fe3  com.apple.LaunchServices 362.2 (362.2) <F3952CAB-322F-A12F-57AF-8B91B1D76DDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                0x96a78000 - 0x96ba6fe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                0x96db4000 - 0x96ddeff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                0x96ddf000 - 0x96e87ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                0x96e88000 - 0x96f65ff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                0x97142000 - 0x9718ffeb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <E2632F3E-6B5C-2E92-CD11-15BC0CE109CA> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
                0x97190000 - 0x971f4ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                0x971f5000 - 0x97203ff7  com.apple.opengl 1.6.12 (1.6.12) <9F13B279-F289-18AC-5D86-DCD52BAF087D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                0x97204000 - 0x9756fff7  com.apple.QuartzCore 1.6.3 (227.34) <CC1C1631-D8D1-D416-171E-A1683274E479> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                0x975ec000 - 0x9763dff7  com.apple.HIServices 1.8.2 (???) <F6EAC2D1-902A-9374-FC4B-43B50E054416> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                0x9763e000 - 0x97644fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                0x97762000 - 0x97812ff3  com.apple.ColorSync 4.6.3 (4.6.3) <0354B408-665F-8B3F-87FF-64E6322276F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                0x97813000 - 0x97816fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
                0x97817000 - 0x9781dfe7  com.apple.CommerceCore 1.0 (6) <41C2A87D-93D8-56C1-9292-0400699F23C1> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                0x9781e000 - 0x9800d557  com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                0x9800e000 - 0x980c4ff7  libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                0x980c5000 - 0x980d3fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
                0x98123000 - 0x98154ff7  libGLImage.dylib ??? (???) <E3EC8E92-4DDD-E7B8-3D38-C5A5160A4930> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                0x9816e000 - 0x98a4eff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                0x98b93000 - 0x98c2bfe7  edu.mit.Kerberos 6.5.10 (6.5.10) <DC19F49B-184E-FD0F-13F8-3A31924A3B66> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                0x98c2c000 - 0x98c64ff7  com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                0x98c65000 - 0x98c86fe7  com.apple.opencl 12.3 (12.3) <DEA600BF-4F54-66B5-DB2F-DC57FD518543> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                0x98c87000 - 0x98d34fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <C8925910-B927-968B-4B71-D83A4CEF8646> /usr/lib/libobjc.A.dylib
                0x98e27000 - 0x98e28ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                0x98f30000 - 0x98f50fe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <BF7FF2F6-5FD3-D78F-77BC-9E2CB2A5E309> /usr/lib/libresolv.9.dylib
                0x98f51000 - 0x990d3fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
                0x991a7000 - 0x991abff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                0x991ac000 - 0x991c7ff7  libPng.dylib ??? (???) <E14178E0-B92D-94EA-DACB-04F346D7534C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                0x99210000 - 0x9938bfe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                0x9938c000 - 0x993b2ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                0x993b5000 - 0x99463ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                0x9946d000 - 0x994a3fff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
                0x994ae000 - 0x994aeff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                0x994af000 - 0x997d3fef  com.apple.HIToolbox 1.6.4 (???) <4699C8BB-DE74-C530-564B-D131F74C9B54> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                0x99917000 - 0x9992fff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                Model: MacBookPro6,2, BootROM MBP61.0057.B0C, 2 processors, Intel Core i5, 2.4 GHz, 4 GB, SMC 1.58f16
                Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 256 MB
                Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
                Memory Module: global_name
                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.10.131.36.1)
                Bluetooth: Version 2.3.8f7, 2 service, 19 devices, 1 incoming serial ports
                Network Service: AirPort, AirPort, en1
                Serial ATA Device: TOSHIBA MK3255GSXF, 298.09 GB
                Serial ATA Device: MATSHITADVD-R   UJ-898
                USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd100000
                USB Device: USB-PS/2 Optical Mouse, 0x046d  (Logitech Inc.), 0xc00e, 0xfd130000
                USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd120000
                USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8507, 0xfd110000
                USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfa100000
                USB Device: MobileMate Micro, 0x0781  (SanDisk Corporation), 0xb7b1, 0xfa140000
                USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0237, 0xfa120000
                USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000
                USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8218, 0xfa113000
                USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0xfa130000
