10 Replies Latest reply on Feb 9, 2011 7:04 AM by asifdegr8
    Item Rendering component
    asifdegr8
      In my datagrid I used Inline item rendering to create text link. code is given
      <mx:DataGridColumn headerText="Nomenclature">
                  <mx:itemRenderer>
                       <mx:Component>
                            <mx:Label htmlText="&lt;u&gt;{data.NOMENCLATURE}&lt;/u&gt;" color="blue" click="newBrowserWindow(data.CALL_URL);" >
                            <mx:Script>
                            <![CDATA[
                                 private function newBrowserWindow(url:String):void{
                                    var urlRequest:URLRequest = new URLRequest(url);
                                    navigateToURL(urlRequest,"_blank");
                            </mx:Script>
                            </mx:Label>
                       </mx:Component>
                  </mx:itemRenderer>
      </mx:DataGridColumn>
      I have to replicate this functionality in multiple datagrids in  multiple applications, I am trying to create component for it and use that component in datagrid column. How can i do this?
        • 1. Re: Item Rendering component
          Flex harUI Adobe Employee
          Copy everything inside the mx:Component tag to a new MXML file.
          • 2. Re: Item Rendering component
            Kumar Pratik
            You can create a component for this which would look something like this:
            <mx:Canvas>
            <mx:Script>
                                  <![CDATA[
                                  </mx:Script>
            </mx:Label>
            </mx:Canvas>
            and then you can call this component inside your datagrid column, somethig like this:
            <mx:datagridcolumn headertext = "TEXt" itemrenderer = "<name of component created?>/>
            Cheers,
            Pratik
            • 3. Re: Item Rendering component
              asifdegr8 Level 1
              I have done the same but that didn't work. because i don't know how to pass data.NOMENCLATURE and data.CALL_URL to component from main mxml file?
              <mx:DataGridColumn headerText="Nomenclature" itemRenderer="components.LinkRenderer">
              • 4. Re: Item Rendering component
                If you have a file called component.mxml, then itemRenderer="component"
                • 5. Re: Item Rendering component
                  asifdegr8 Level 1
                  I have achieved this. but my issue is
                  if someother datagrid has field data.EMPLOYEE_NAME instead of data.NOMENCLATURE, then how can i achive this. the component should be reuseable for any other datagrid having different field names.
                  • 6. Re: Item Rendering component
                    Abhrodip Paul-cXMMf1 Level 2
                    You have to override the data setter method.
                    Please refer the below link.
                    http://cookbooks.adobe.com/post_Reusable_date_item_renderer-12757.html
                    • 7. Re: Item Rendering component
                      asifdegr8 Level 1
                      Can u please mention or give me code for set data method. I am unable to understand in given link.
                      • 8. Re: Item Rendering component
                                    <mx:itemRenderer>
                                         <mx:Component>
                                              <mx:Label  >
                                              <mx:Script>
                                              <![CDATA[
                                                   override public function set data(value:Object):void
                                                       super.data = value;
                                                        if (value.hasOwnProperty("NOMENCLATURE"))
                                                           // your code here like add click listener.
                                                      else if (value.hasOwnProperty("EMPLOYEE_NAME"))
                                                               // your code here like showing the employee name etc
                                              </mx:Script>
                                              </mx:Label>
                                         </mx:Component>
                                    </mx:itemRenderer>
                        Is this what you required ?
                        • 9. Re: Item Rendering component
                          Add implements="mx.controls.listClasses.IDropInListItemRenderer"
                          And use:
                              DataGrid(owner).columns[listData.columnIndex].dataField
                          You may have to move that code to commitProperties for owner to be valid.
                          • 10. Re: Item Rendering component
                            asifdegr8 Level 1
                            perhaps you misunderstand what i want. Actually NOMENCLATURE, EMPLOYEE_NAME are fields of data provider on which we have to create text link and call the url CALL_URL(another filed of data provider). e,g if NOMENCLATURE=GOOGLE, CALL_URL="http://www.google.com", then text link should appear like this in data grid
                            GOOGLE  (its blue color underlined text)
                            when i click this link it will open the page http://www.google.com
                            - Now what i want is that the data provider field name can by any thing. It may be NOMENCLATURE, may be EMPLOYEE_NAME, may be COUNTRY_NAME. It can be any thing, I have to create link on it, and link field name can also be any thing, it can be CALL_URL, it can simply be URL etc. I like to make it more dynamic in my component
