2 Replies Latest reply on Feb 1, 2011 5:36 AM by caranpon
    hello world Force to close (see logcat)
    caranpon
      Hi experts,
      Finally I can connect burrito to my device BUT I always get black screen and Force to close in all apps (test generated by burrito...). That app works fine on the emulator.
      I am runnig cyanogen7 (android 2.3) over htc Legend (I´ve tried with both windows7 and machintosh).
      Any help will be thaked !!!
      See my logcat (I hope I did right, I am not sure):
      Microsoft Windows [Versión 6.1.7600]
      Copyright (c) 2009 Microsoft Corporation. Reservados todos los derechos.
      C:\Users\tadu>cd C:\Program Files\Android\android-sdk-windows\platform-tools
      C:\Program Files\Android\android-sdk-windows\platform-tools>adb logcat -c
      C:\Program Files\Android\android-sdk-windows\platform-tools>adb logcat *:w
      --------- beginning of /dev/log/main
      W/GTalkService(  289): [GTalkConnection.27] doConnect: caught XMPPError connecti
      ng to mtalk.google.com:5228.: (502)
      W/GTalkService(  289):   -- caused by: java.net.SocketTimeoutException: Connecti
      on timed out
      --------- beginning of /dev/log/system
      W/ActivityManager(  148): No content provider found for:
      W/NativeHelper(  148): Native ABI mismatch from package file
      W/PackageManager(  148): Code path for pkg : air.GeoTest1.debug changing from /d
      ata/app/air.GeoTest1.debug-1.apk to /data/app/air.GeoTest1.debug-2.apk
      W/PackageManager(  148): Resource path for pkg : air.GeoTest1.debug changing fro
      m /data/app/air.GeoTest1.debug-1.apk to /data/app/air.GeoTest1.debug-2.apk
      W/ResourceType(  148): Failure getting entry for 0x7f0a0000 (t=9 e=0) in package
      0 (error -75)
      W/RecognitionManagerService(  148): no available voice recognition services foun
      d
      W/dalvikvm( 4499): No implementation found for native Lcom/adobe/air/AndroidActi
      vityWrapper;.nativeSetVisible (Z)V
      W/dalvikvm( 4499): threadid=1: thread exiting with uncaught exception (group=0x4
      0018560)
      E/AndroidRuntime( 4499): FATAL EXCEPTION: main
      E/AndroidRuntime( 4499): java.lang.UnsatisfiedLinkError: nativeSetVisible
      E/AndroidRuntime( 4499):        at com.adobe.air.AndroidActivityWrapper.nativeSe
      tVisible(Native Method)
      E/AndroidRuntime( 4499):        at com.adobe.air.AndroidActivityWrapper.SetVisib
      le(AndroidActivityWrapper.java:651)
      E/AndroidRuntime( 4499):        at com.adobe.air.AndroidActivityWrapper.onSurfac
      eInitialized(AndroidActivityWrapper.java:614)
      E/AndroidRuntime( 4499):        at com.adobe.air.AIRWindowSurfaceView.surfaceCha
      nged(AIRWindowSurfaceView.java:438)
      E/AndroidRuntime( 4499):        at android.view.SurfaceView.updateWindow(Surface
      View.java:549)
      E/AndroidRuntime( 4499):        at android.view.SurfaceView.dispatchDraw(Surface
      View.java:348)
      E/AndroidRuntime( 4499):        at android.view.View.draw(View.java:6883)
      E/AndroidRuntime( 4499):        at android.view.SurfaceView.draw(SurfaceView.jav
      a:334)
      E/AndroidRuntime( 4499):        at android.view.ViewGroup.drawChild(ViewGroup.ja
      va:1646)
      E/AndroidRuntime( 4499):        at android.view.ViewGroup.dispatchDraw(ViewGroup
      .java:1373)
      va:1644)
      .java:1373)
      E/AndroidRuntime( 4499):        at android.widget.FrameLayout.draw(FrameLayout.j
      ava:357)
      va:1646)
      .java:1373)
      ava:357)
      E/AndroidRuntime( 4499):        at com.android.internal.policy.impl.PhoneWindow$
      DecorView.draw(PhoneWindow.java:1862)
      E/AndroidRuntime( 4499):        at android.view.ViewRoot.draw(ViewRoot.java:1522
      E/AndroidRuntime( 4499):        at android.view.ViewRoot.performTraversals(ViewR
      oot.java:1258)
      E/AndroidRuntime( 4499):        at android.view.ViewRoot.handleMessage(ViewRoot.
      java:1859)
      E/AndroidRuntime( 4499):        at android.os.Handler.dispatchMessage(Handler.ja
      va:99)
      E/AndroidRuntime( 4499):        at android.os.Looper.loop(Looper.java:123)
      E/AndroidRuntime( 4499):        at android.app.ActivityThread.main(ActivityThrea
      d.java:3647)
      E/AndroidRuntime( 4499):        at java.lang.reflect.Method.invokeNative(Native
      Method)
      E/AndroidRuntime( 4499):        at java.lang.reflect.Method.invoke(Method.java:5
      07)
      E/AndroidRuntime( 4499):        at com.android.internal.os.ZygoteInit$MethodAndA
      rgsCaller.run(ZygoteInit.java:839)
      E/AndroidRuntime( 4499):        at com.android.internal.os.ZygoteInit.main(Zygot
      eInit.java:597)
      E/AndroidRuntime( 4499):        at dalvik.system.NativeStart.main(Native Method)
      W/ActivityManager(  148):   Force finishing activity air.GeoTest1.debug/.AppEntr
      y
      E/InputDispatcher(  148): channel '40718818 air.GeoTest1.debug/air.GeoTest1.debu
      g.AppEntry (server)' ~ Consumer closed input channel or an error occurred.  even
      ts=0x8
      g.AppEntry (server)' ~ Channel is unrecoverably broken and will be disposed!
      on timed out
        • 1. Re: hello world Force to close (see logcat)
          Anirudh Sasikumar Adobe Employee
          Looks like the AIR runtime has not been installed correctly.
          Does uninstalling AIR and then doing a debug launch from Flash Builder help?
          P.S: We haven't tested this on cyanogen7 Android builds at all as they are not officially supported.
          • 2. Re: hello world Force to close (see logcat)
            caranpon Level 1
            Thank's for your answer. I have read about someone successfully using
            cyanogen 7, But it is very likely that the problem is in the air
            installation. I´ve noticed that my air is 5.82 mb, and I guess it should be
            about 12 mb (as i saw in some tutorials). The problem is that I can´t find
            air it in the market!!! Is the Burrito which is trying to install It.
            I will try to uninstall and reinstall air and some other pieces of sw.
            2011/2/1 Anirudh Sasikumar <forums@adobe.com>
            help?
