8 Replies Latest reply on Jan 31, 2011 5:09 AM by Waldviertler
    delete textframes on every page, depending on it's size
    Waldviertler
      Hello!
      I've got an catalogue to change, with 500 pages that contains on every page a textframe on the same position with the same size.
      I want to delete this paricular textframe on every page.
      How can I start ?
      Many thanks for help
      Regards
      Martin
        • 1. Re: delete textframes on every page, depending on it's size
          Harbs. Level 6
          Loop through the text frames and check their geometricBounds. If the bounds fit the frame location remove() the frame...
          (Include the inner loop inside an outer loop which loops through all pages in the doc...)
          Harbs
          • 2. Re: delete textframes on every page, depending on it's size
            Waldviertler Level 1
            Hello Harbs.
            I got this part of code, but it does not work.
            var doc = app.activeDocument;
            var tFrames = doc.pages[0].textFrames;
            for (var n = tFrames.length-1; n >= 0 ; n--) {
                var gb = tFrames[n].geometricBounds;
                var w = gb[3]-gb[1];
                var h = gb[2]-gb[0];
                if (h == 20 && w == 20){
                    tFrames[n].remove();
            Can you imagine, what is wrong?
            /Edit: the size is in mm ----> could that be the mistake?
            Martin
            • 3. Re: delete textframes on every page, depending on it's size
              Harbs. Level 6
              Two things:
              1) Yes. Make sure your measurement units are correct.
              2) Due to rounding errors do not check for exact values.
              try something like this:
              if (h > 19 && h < 21 && w > 19 && w < 21){
              Harbs
              • 4. Re: delete textframes on every page, depending on it's size
                Ok, I got it to work:
                doc.viewPreferences.rulerOrigin = RulerOrigin.PAGE_ORIGIN;
                doc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS;
                doc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
                     if (h == 20  && w == 20 )
                     {          tFrames[n].remove();     }
                Now I have to look how to loop through pages.
                thx.
                Martin
                • 5. Re: delete textframes on every page, depending on it's size
                  Harbs. Level 6
                  Keep in mind what I wrote about rounding errors, but here's the idea:
                  function removePageFrames(page){
                    var tFrames = page.textFrames;
                    for (var n = tFrames.length-1; n >= 0 ; n--){
                      if (h == 20  && w == 20 ){
                  for(var i=0;i<doc.pages.length;i++){
                  removePageFrames(doc.pages[i]);
                  • 6. Re: delete textframes on every page, depending on it's size
                    A Big Thank You! Harbs.
                    This works:
                    regards
                    Martin
                    • 7. Re: delete textframes on every page, depending on it's size
                      Marijan Tompa [tomaxxi] Level 4
                      I wrote short function to check if the number is between two numbers:
                      Number.prototype.between = function(first,last){
                          if(this >= first && this <= last)
                              return true;
                          else
                              return false;
                      And simply use:
                      var myNum = 315;
                      if(myNum.between(300,320)){
                        //if true
                      }else{
                        //if false
                      I just missed Between function from MySQL
                      tomaxxi
                      http://indisnip.wordpress.com/
                      http://inditip.wordpress.com/
                      • 8. Re: delete textframes on every page, depending on it's size
                        Harbs. Level 6
                        Hi Marijan,
                        You probably know that I'm not into prototype functions, but just for the heck of it, you can make that function a bit shorter:
                            return (this >= first && this <= last);
                        Harbs
