1 2 Previous Next 40 Replies Latest reply on May 16, 2017 9:24 AM by SanchezMusics
    Out of Memory error after upgrading to Reader X
    cyberlopez6
      We have several PDF documents that work fine on Reader 9.  But after upgrading to Reader X, the files will not open.  Instead, they report an Out Of Memory error and a blank document opens instead.  Removing Reader X and re-installing Reader 9 corrects the issue. This has been reproduced on 3 different PCs running both Windows XP and Windows 7.
      Any suggestions?
        • 1. Re: Out of Memory error after upgrading to Reader X
          Scott_SomeLargeNumber
          Reader X issue:
          Same issue. Some pdf documents will not open after upgrading to Reader X. "out of memory" error given. The error has no correlation to the size of the PDF or OS. This happens on XP64, XP, Win7 x64.  It does correlate to where I get the pdf from. IF my copy machine scans documents into a pdf then there is an issue.
          The workstations work fine with 9.x versions of reader when downgraded from X
          Reboot does nothing
          Reinstall does nothing
          pdf from copy machine work in all versions of reader 7 8 and 9 not X
          Size of pdf does not matter.
          Will Adobe be issuing a fix?
          Is there a simple solution?
          • 2. Re: Out of Memory error after upgrading to Reader X
            ManishPali Adobe Employee
            could you please share any sample PDF with which you are seeing the problem?
            • 3. Re: Out of Memory error after upgrading to Reader X
              Scott_SomeLargeNumber Level 1
              Here it is. Attached as example.pdf.
              • 5. Re: Out of Memory error after upgrading to Reader X
                Brandon.Campbell
                Same here. I released this to a test group and
                those people are complaining about certain documents getting out of memory. Some were also complaining about access
                denied error on network documents but found a temporary solution for that on another blog.
                • 6. Re: Out of Memory error after upgrading to Reader X
                  Joseph McNamara
                  I am using an HP Laserjet 4ML postscript printer and Windows 7. Since upgrading to Adobe X, PDF statements from Chase credit cards give this error, while some from other banks don't.  The only sure way to print pdf is using a print image.  Downgrading again to 9.4.1 solves the problem, obviating the need to select "print as image". ( Reducing the size of the selected amount of text does not help, nor does following any other of the error message suggestions.)
                  • 7. Re: Out of Memory error after upgrading to Reader X
                    Manish,
                    I sent the file. Any progress?
                    Thanks.
                    • 8. Re: Out of Memory error after upgrading to Reader X
                      Hi Scott,
                      Thanks for sharing the test file. Bug is logged for this problem and hopefully fix would be provided in future update of Reader X.
                      Manish Pali | Lead Quality Engineer | +91-120-2444711 Extn: 34337 | Adobe Systems India
                      • 9. Re: Out of Memory error after upgrading to Reader X
                        LFroberg
                        Hi Manish
                        Is there any news regarding this issue?
                        We started seing the problem a couple of days ago, have been using Reader 10/X for a month.
                        I updated Reader 10 to the latest version yesterday and it didn't change the result, still getting the Out of Memory error.
                        Lasse
                        • 10. Re: Out of Memory error after upgrading to Reader X
                          Since it was a late finding, it missed the timeline for Reader 10.0.1 update.
                          • 11. Re: Out of Memory error after upgrading to Reader X
                            carlenejs Level 1
                            unfortunately thats not a great answer,
                            due to the wide spread nature of the issue, we are needing a little more clarification to when Adobe will fix the bug.
                            is that in the next day, week month?
                            because a lot of people see this as a huge error, enough to downgrade to adobe reader 9 to get away from it.
                            • 12. Re: Out of Memory error after upgrading to Reader X
                              rrapati
                              Is there any solution for this issue?
                              The out of memory error happens when opening a pdf file of 2mb or larger.
                              When opening the same file in version 9.3.0 the document opens without any errors.
                              • 13. Re: Out of Memory error after upgrading to Reader X
                                LFroberg Level 1
                                As far as I know there isn't a solution yet.
                                The size of the file doesn't seem to be the problem in our case. I have seen the problem with 230KB and a 2MB file. I am thinking that it might be caused by the program that made the PDF file, for example a PDF printer, Word or something different???
                                • 14. Re: Out of Memory error after upgrading to Reader X
                                  rrapati Level 1
                                  That could also be the cause.
                                  The document that doesn't open is made by EFI Cyclone, pdf version 1.3
                                  I've opened that same document in Adobe reader 9.3.0, used a pdf printer to convert it and now it opens.
                                  Now the document is made by GNU Ghostscript 7.06, pdf version is still 1.3
                                  The document has grown from 2,5mb to 6,9mb.
                                  So indeed, it looks like it is not the size that causes the Out of memory error.
                                  • 15. Re: Out of Memory error after upgrading to Reader X
                                    LFroberg Level 1
                                    I have received 3 PDF files from our users, where they have the problem. I can see that they are all made with EFI Cyclone, two with version 1.3 and one with version 1.6.
                                    I have had other users with the same problem, but haven't checked which program that made the file.
                                    It's starting to look like a problem between Reader X and EFI Cyclone. Anybody seen the problem with other PDF creators than EFI Cyclone?
                                    I have no experience with EFI Cyclone, but is it just another PDF printer?
                                    We use Win2PDF or the built-in PDF function in Office 2007 and those files we can open without any problems.
                                    To be continued!
                                    • 16. Re: Out of Memory error after upgrading to Reader X
                                      LFroberg Level 1
                                      I have done some further testing :-)
                                      A scan from our MFP
                                      A PDF from a business partner
                                      A PDF created in Word 2007
                                      A PDF created with Win2PDF
                                      Reader X can open all the above files, and when I check which program that made the files, none of them was made by EFI Cyclone.
                                      Now it's weekend, but monday I will look for a demo of EFI Cyclone to see if it works in Reader X.
                                      Have a nice weekend :-)
                                      • 17. Re: Out of Memory error after upgrading to Reader X
                                        carlenejs Level 1
                                        at my end, i have files made distiller 4.05 and 5.05 on Mac.
                                        any that have the following fail:
                                        Application: FrameMaker 5.5 PowerPC: PCPrinter 8.3.1
                                        PDF Producer: Acrobat Distiller 4.05 for Macintosh
                                        PDF Version 1.3
                                        so all the files made with distiller 4.05 for Mac are failing it seems.
                                        where as the files created as following and fine.
                                        PDF Producer: Acrobat Distiller 5.05 for Macintosh
                                        PDF Version 1.3
                                        any docs that are made with distiller 4.05 for mac it seems are failing with the out of memory error.
                                        having said that, i am not sure and havnt found any distiller 4.05 for PC etc. (if that even exists)
                                        is there anyway to upload a couple of PDF's here?
                                        • 18. Re: Out of Memory error after upgrading to Reader X
                                          LFroberg Level 1
                                          I don't think that it's possible to upload files to the forum.
                                          I have just tried with a file created in Adobe InDesign CS5 and it works. The file info is Adobe PDF Library 9.9, PDF version 1.4.
                                          I am looking forward to the solution. Could an Adobe employee confirm that the problem is getting solved and will be included in the next Adobe Reader update?
                                          • 19. Re: Out of Memory error after upgrading to Reader X
                                            averysmalldog
                                            I can confirm that files of any size as produced by the Fiery EFI Cyclone PDF Wrapper (version 1.3) fail to open in Acrobat Reader X. The symptom is that Reader displays a dialogue box with the message "Out of memory." After the "OK" button is clicked, a single blank page appears. The blank page cannot be printed or annotated. This affects both versions of Reader X (10.0.0 and 10.0.1) on any Windows OS that can cun Reader X (XP SP3, Vista, 7).
                                            The workaround I use for employees at the company I support is either to downgrade to Reader 9 or use an alternative free PDF viewer. For individuals who wish to keep Reader X, I simply open the file using Reader 9 and print to PDF using PDFMaker. The resulting re-encoded PDF file is viewable in Reader X. This process should also work with any other PDF encoder.
                                            I am curious to see if Adobe is aware of this issue and if they plan to implement a solution. The EFI Cyclone wrapper is somewhat common in Canon and Ricoh business multifunction units produced in the late '00s. Therefore, the issue affects many business users at my company and others. A solution integrated in the next upgrade (10.0.2) would be optimal.
                                            • 20. Out of Memory error after upgrading to Reader X
                                              rrapati Level 1
                                              Looks like it will not be fixed in 10.0.2 according to the following document:
                                              http://kb2.adobe.com/cps/837/cpsid_83708/attachments/Acrobat_Reader_ReleaseNote_10.0.2.pdf
                                              The document says that there are no bugfixed and that 10.0.2 only is a security fix.
                                              • 21. Re: Out of Memory error after upgrading to Reader X
                                                carlenejs Level 1
                                                i agree, from the article, the 10.0.2 update doesn't not look like it will fix the issues.
                                                i am trying to get a copy of the release to test in case the security fix somehow miraculously fixes the issue as well... (hoping and praying it will)
                                                otherwise we will have to revert back to reader 9 until adobe brings out an actual release version with the fixes instead of what feels like beta's.
                                                maybe adobe cannot find the fix, or they are plain ignoring the forums like this one.
                                                i am chasing another issue, which i have seen no resolve for.
                                                adobe please respond to this forum discussion...
                                                • 22. Re: Out of Memory error after upgrading to Reader X
                                                  averysmalldog Level 1
                                                  After submitting a bug report to Adobe, I have received an initial response from one of their senior software developers. She asked for example files (which I provided) and confirmed that she had forwarded those files to the appropriate group. While this may not mean an immediate fix, Adobe is seemingly aware of the issue. Hopefully they will find a solution in the near future, saving us all a lot of headache. I will continue to update this thread as new information comes in.
                                                  • 23. Re: Out of Memory error after upgrading to Reader X
                                                    carlenejs Level 1
                                                    thats great that you have been able to get that far!!
                                                    look forward to your update
                                                    • 24. Re: Out of Memory error after upgrading to Reader X
                                                      GFF_Architects
                                                      Just to throw in my 2 cents... Adobe has known about the out of memory bug at least since 01/12/2011 because that is when I reported the problem to them.  I even had an escalated support case #181995624 and bug#2800823.  Our problem comes from a EFI Fiery E7000 attached to our Lanier LD460c Copier.  Any pdf's made from that copier will not open in Acrobat X, although they will open in lower versions of Acrobat just fine.  Our only workaround is to keep Acrrobat 9 on office computers, or you can open the offending pdf in Acrobat 9 or earlier and print it to pdf, and then it will open in Acrobat X!!!  They acknowledged that this was a bug, see my email chain below.  This was the last update I received from Adobe, very frustrating...
                                                      Sent: Wednesday, February 09, 2011 9:12 AM
                                                      To:
                                                      Cc:
                                                      Subject: RE: Case 181995624; Unable to open PDF
                                                      Hi Phil,
                                                      We do not have this information or estimate time by our Engineering team yet.
                                                      Regards,
                                                      Neeraj
                                                      Sent: Monday, February 07, 2011 8:19 PM
                                                      To:
                                                      Cc:
                                                      Next major release as in the next patch for Acrobat X, or as in Acrobat 11?
                                                      Sent: Saturday, February 05, 2011 4:31 AM
                                                      To:
                                                      Cc:
                                                      Subject: Case 181995624; Unable to open PDF
                                                      Hi Phil,
                                                      You can get back to us with the Bug Number provided you earlier based on which we will give you the update by our Engineering team. However, the update for now is that it is decided to fix in our next major release.
                                                      Regards,
                                                      Neeraj
                                                      Sent: Thursday, February 03, 2011 1:33 AM
                                                      To:
                                                      Can you send me a link to where I can find information on the bug?
                                                      Sent: Tuesday, February 01, 2011 10:14 AM
                                                      To:
                                                      Cc:
                                                      Hi Phil,
                                                      Hope you are doing well.
                                                      I have researched on your issue and found that it is a BUG with Acrobat X. I have logged it on your behalf so that our Engineering team can have a look on that. Please find the Bug Number #2800823 for any update on this in future. I am closing this case on your behalf.
                                                      Have a nice day.
                                                      Regards,
                                                      Neeraj
                                                      Sent: Tuesday, February 01, 2011 12:22 AM
                                                      To:
                                                      Cc:
                                                      Any updates on this case?
                                                      Sent: Friday, January 14, 2011 2:03 PM
                                                      To:
                                                      Cc:
                                                      The EFI Fiery E-7000 Controller version is 1.2.0 and it handles the scanning and printing functionality of our Lanier LD160c copier.  I have attached two sample files.  One is a 1 page scan from our copier.  The other is a combined pdf that I just created in Acrobat 9.  The first two pages of the combined pdf consists of a webpage that I printed using Acrobat 9 and then the scan from the copier is on the 3rd page.  In Acrobat X, once you get to the 3rd page you will receive the Out of Memory error.  It will open in previous versions of Acrobat just fine though.
                                                      Sent: Friday, January 14, 2011 11:52 AM
                                                      To:
                                                      Cc:
                                                      Hi Phil,
                                                      Thanks for the information.
                                                      I have the PDF file provided by you and able to reproduce the behavior. I tried to call you at 214-303-1500 but got voice mail.
                                                      Please let me know when you will be available so that I could call you and continue further with this issue.
                                                      Regards,
                                                      Neeraj
                                                      Sent: Thursday, January 13, 2011 6:57 AM
                                                      To:
                                                      Cc:
                                                      Subject: Re: Case 181995624; Unable to open PDF
                                                      It is a walk up copier and we scan to email.  The EFI Fiery controller E7000 handles pdf conversion for the copier, but yes it has the latest firmware.  The bottom line is that we have 3 or 4 years worth of pdfs created from that copier rendered useless by Acrobat X.  They open fine in previous versions of Acrobat.  Did you get the test pdf file when this case was created?
                                                      -- Sent from my Palm Pre
                                                      On Jan 12, 2011 6:12 PM, Acrobat Support <acrots@adobe.com> wrote:
                                                      Hi Philip,
                                                      Thank you for choosing Adobe Support we have got your concern, we see that you are facing an issue with opening PDF files in Acrobat X, created from Lanier (Ricoh) LD160c copier. A technical support case 181995624 has been created for your reference. In order to assist you further. We would like to have the following information.
                                                      ·         Are you using the latest scanner driver ?
                                                      ·         What is the exact scanning workflow ?
                                                      Regards
                                                      Acrobat Support
                                                      • 25. Re: Out of Memory error after upgrading to Reader X
                                                        GFF_Architects Level 1
                                                        After I posted my last message, I decided to send Adobe another email about the issue.  I
                                                        received a response that they are fixing the issue as early as June!  Yay finally!
                                                        Sent: Monday, May 30, 2011 5:08 AM
                                                        To:
                                                        Hi Phil,
                                                        The bug logged for the issue is fixed in Acrobat X 10.1.0, and the tentative release date of Acrobat X 10.1.0 is mid June(this year). But this is not confirmed, yet.
                                                        Regards
                                                        Acrobat Support.
                                                        • 26. Re: Out of Memory error after upgrading to Reader X
                                                          I can confirm that it is fixed with Acrobat 10.1 patch that came out yesterday.  Yay finally!
                                                          • 27. Re: Out of Memory error after upgrading to Reader X
                                                            mellah124
                                                            Running Reader X in a Windows 7/64 bit environment, out of memory error resolved by updating Reader by going to Help > Check for Updates.  Problem solved.
                                                            • 28. Re: Out of Memory error after upgrading to Reader X
                                                              denveritguy
                                                              I had a similar issue with a web based GIS App that my company uses.  When you loaded the pdf map, Iexplore.exe would crash and then Acrobat 11 would return the Out of Memory error.  I do not know the cause, but I did find a workaround that may provide Adobe engineers a clue.  The user is on a Windows 7 64 bit machine.  He was using the 32-bit version of Internet Explorer.  I loaded the same page using the 64-Bit version and voila, it successfully opened the PDF file.
                                                              • 29. Re: Out of Memory error after upgrading to Reader X
        LFroberg Level 1
        Tak for Deres henvendelse.
        Lasse Froberg er fratrådt sin stilling hos HjulmandKaptain.
        Deres mail vil automatisk blive videresendt til Heine Madsen
        [private data removed]
        • 30. Re: Out of Memory error after upgrading to Reader X
        DevinGilmer
        I'm not sure if this will help, but I find that the files I have this same problem with were created and saved in Photoshop CC as a pdf, with no layers, and not preserving photoshop capabilities.  This has been a problem for several months.  I have had to save files a scaled down in quality jpeg to send off to printers because the pdf's wont open.  Any help soon would be much appreciated.
        • 31. Re: Out of Memory error after upgrading to Reader X
        Abraham123
        SOLVED: OUT OF MEMORY ISSUE
        I feel, Its not an adobe related issue... its likely to be a memory problem.
        Just solved this issue. Has been troubling me for quite sometime. Whenever I export files to pdf, it used to bring up the "out of memory" pop up.
        This worked for me.
        To force windows to use all the available RAM memory:
        Step1: Go to Start Button and Type "Run"
        Step 2: In the Run Box: Type "msconfig"  (I'm using windows 7)
        Step 3: Go to Boot tab in the System configuration window.
        Step 4: Click advanced option and Check the "Maximum memory" Check box (This works for me as i'm working on 4Gb RAM system)
        Step 5: Restart when prompted.
        OR Watch video on how to do it
        https://www.youtube.com/watch?v=SudiKa8HipI
        • 32. Re: Out of Memory error after upgrading to Reader X
        yogeshnmakwana
        Hi All,
        I have MacBook Air with OS X 10.9.5. I have installed Adobe Reader 11.0.10 version. Now I am getting error "Out of Memory" while opening my credit card statement PDF file. This file is protected with password, after entering the password its shows the error "Out of memory" and after that I am unable to print the file.
        Please help on this
        Thanks in advance for all your help on this.
        • 33. Re: Out of Memory error after upgrading to Reader X
        Sande@SandeLollis.com
        Related to this. If I trash a pdf, empty the trash, and then export a new pdf from Indesign and use the same name, when I open the new pdf it is the old version. I have to name it something different for it to appear different. I just did a test with a newly exported correct version of my pdf with a new name. I opened it and it was correctly the new version. I tried to then do a save as and use the old name, I got a message that said I couldn't do that because the file was open, but it wasn't, it had been trashed and the trash emptied. I then closed the doc and did a quick duplication of the file (where it adds the number 2 after the title), and then clicked on the name and titled it the old name. When I tried to open that file I got the "out of memory" message.
        This is crazy!!!
        • 34. Re: Out of Memory error after upgrading to Reader X
        Ian_Barron
        Opening PDF's from clients and suppliers constitutes about 80% of what I currently use Creative Cloud for. Since NONE of them will open on my Win7 pc it represents a pretty useless subscription !! The latest failure was a 127k file !!!!!!!!!!
        • 35. Re: Out of Memory error after upgrading to Reader X
        alanh24097471
        Can anyone confirm if Abraham123's solution work? I have been having this issue with GIS file for a long time. Won't stop running out of memory.
        • 36. Re: Out of Memory error after upgrading to Reader X
        melanieo66340248
        This is happening to a lot of people. This keeps us from using acrobat. Surely, there is a fix from the R&D team so that the program is functional?
        • 37. Re: Out of Memory error after upgrading to Reader X
        Blaxer
        I didn't work for me.  :-(
        • 38. Re: Out of Memory error after upgrading to Reader X
        whattheheckdoihavetotypeh
        This "out of memory" error from Adobe pops up every so many months or years for us (since ~2001 if memory serves). I've tried a lot of different workarounds and programs such as Nitro, Foxit, Sumatra, .... So far the only one which has worked every single time is GSview, a graphical user interface for the open source Ghostscript interpreter. (Windows only. There are similar programs for other platforms, but I haven't needed to evaluate them.) GSView doesn't have the sophisticated widgets and so on that we've become accustomed to, but it gets the job done.
        • 39. Re: Out of Memory error after upgrading to Reader X
        ryanj3333
        We recently ran into the "out of memory" issue with certain PDF's that were exported from our GIS program. We are using Adobe Acrobat X Pro Version 10.1.8. The PDFs in question would crash during opening when using our desktop computers but would open when using a laptop. Our theory was that it was a difference in video drivers between the two systems and how they interacted with Adobe. So to make a long solution short, the fix for us was to turn off the "Smooth images" setting. After that was turned off, our desktops were able to open the PDFs with no errors.
        Edit > Preferences > Page Display > Uncheck Smooth images.
        1 2 Previous Next
