2 Replies Latest reply on Feb 3, 2011 1:59 AM by otisme
    Email with Flex 4 and PHP
    otisme
      I'm running into some problems attempting to convert flex 3 email tutorial file to flex 4 fx and spark code. Is there a tutorial out there that does email with flex4 and php?
      thx
      Colm
        • 2. Re: Email with Flex 4 and PHP
          otisme Level 1
          Hello Ivan,
          Thanks for your email, I'm building out a small website at
          http://www.cbweb.net at the moment and the contact form can be tested
          there. I've left a comment as otisme on your url below, here's the
          comment:
          The best tutorial for building a simple contact form was one I found here:
          http://www.riacodes.com/flex/create-an-email-form-in-flex-with-php/
          But above is built in Flex 3. I needed one for Flex 4, so I've updated
          the code to support Flex 4 fx type layout and code, here it is, works
          well
          and extremely fast
          <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
                     xmlns:mx="library://ns.adobe.com/flex/mx" >
               <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                    <mx:HTTPService id="emailService" url="php/mail.php" method="POST"
          resultFormat="xml" result="emailResult()" useProxy="false"/>
                    <mx:EmailValidator id="mailValidator"
                                           source="" property="text"
                                           requiredFieldError="Enter your email" required="true" />
                    <mx:StringValidator id="nameValidator"
                                             requiredFieldError="Enter your name" required="true"/>
                    <mx:StringValidator id="emailValidator"
                                             requiredFieldError="Enter your message" required="true"/>
               </fx:Declarations>
                    <fx:Style  source="css/style.css">
                         @namespace s "library://ns.adobe.com/flex/spark";
                         @namespace mx "library://ns.adobe.com/flex/mx";
                    </fx:Style>
                    <fx:Script>
                              <![CDATA[
                              import mx.events.ValidationResultEvent;
                              import mx.controls.Alert;
                              private function sendMail():void{
                              var _senderName:String = senderName.text;
                              var _senderEmail:String = senderEmail.text;
                              var _emailMessage:String = emailMessage.text;
                              var _emailSubject:String = emailSubject.text;
                              var evValidMail:ValidationResultEvent = mailValidator.validate();
                              var evValidName:ValidationResultEvent = nameValidator.validate();
                              var evValidMessage : ValidationResultEvent = mailValidator.validate();
                              if (evValidMail.type == ValidationResultEvent.VALID
                              && evValidName.type == ValidationResultEvent.VALID
                              && evValidMessage.type == ValidationResultEvent.VALID){
                              emailService.send({senderName: _senderName,
          senderEmail:_senderEmail, emailSubject:_emailSubject, emailMessage:
          _emailMessage});
                              else{
                              resultLabel.text="There are Form errors";
                              resultLabel.setStyle("styleName", "invalid");
                              private function emailResult():void{
                              Alert.show("Thank you for your submission ");
                              clearForm();
                              private function clearForm():void{
                              resultLabel.text="";
                              emailSubject.text="";
                              emailMessage.text="";
                              </fx:Script>
                    <mx:Panel height="401" width="400" layout="absolute" title="Contact
          us" backgroundColor="#050505">
                         <mx:Form x="9" y="10" width="360" backgroundColor="#BCB5B5">
                              <mx:FormItem label="Name :" contentBackgroundColor="#1E1C1C">
                                   <mx:TextInput id="senderName" contentBackgroundColor="#DEDEDE"/>
                              </mx:FormItem>
                              <mx:FormItem label="Email :">
                                   <mx:TextInput id="senderEmail" contentBackgroundColor="#DEDEDE"/>
                              </mx:FormItem>
                              <mx:FormItem label="Subject :">
                                   <mx:TextInput id="emailSubject" contentBackgroundColor="#DEDEDE"/>
                              </mx:FormItem>
                              <mx:FormItem label="Message :">
                                   <mx:TextArea id="emailMessage" height="132" width="213"
                              </mx:FormItem>
                         </mx:Form>
                         <mx:Button label="Send" click="sendMail()" x="138" y="274"/>
                         <mx:Label id="resultLabel" x="212" y="276"/>
                    </mx:Panel>
               </s:Group>
          and the php file you point above at should have:
          <?php
             $senderName = $_POST['senderName'];
             $senderEmail =  $_POST['senderEmail'];
             $sendToEmail = "colmbrazel@gmail.com";
             $subject = $_POST['emailSubject'];
             $emailMessage = $_POST['emailMessage'];
             $recipient = "$sendToEmail";
             $headers = "From: $senderEmail ";
             $message = "From: $senderName, \nEmail Address:
          $senderEmail\nSubject: $subject\n\nMessage: $emailMessage";
             $message = stripslashes($message);
             mail($recipient, $subject, $message, $headers)
          and you can create your own style.css to suit above
